10-29-2009, 10:14 | #1 (permalink) |
No Life Poster Join Date: Jul 2002
Member: 13999 Status: Offline Thanks Meter: 74 | n82 no local mode... i flashed now v31 again but phone doesn't go in local mode or test mode. tested many cable with 5, 7.7, 10 k resistor without good results. phone flashed perfect but don't finalize flash with AFP.... i have full rpl backup but it not helped to restore phone in working condition. i flashed ENO v30 and fullflash v31 but not solved, no local mode, no AFP |
10-29-2009, 10:39 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | looks like your phone has APE problem: this normally happens when Fbus and usb get connected in the same moment to the mobile but I think is not your situation. Try a full erase, ENO, Flash V31 and afterward RPL back-up. The mobile using this route should get again the nokia logo and the local mode as the certs are all in the only issue will be the Imei. Once you got the local mode (if you got it) you can use any escamotage to write back the PM308 back-up BR (Buon Lavoro) Alex |
10-29-2009, 14:24 | #3 (permalink) |
Member: 13999 Status: Offline Thanks Meter: 74 | unsolved after full erase with mx-key advanced flash tab. flashed eno and v31 but problem is the same that phone is new and working before downgrade/crossflash this is log bus check... Using device: UFS_USB V2.8 (c) SarasSoft 2007. APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: AA41F714D65359F589C2557FDA5159DC34F52507 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.x] EM1 ID: 00000296 EM2 ID: 00000B22 PUBLIC ID: 0490010B3B418B528BE6C7880C85367C40D4662C ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0020 8804 - 0000 6B21 [ST 58LR128U,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.35.0 revision: 0.0 size: 0x272B0 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.39.0 revision: 0.0 size: 0x7B00 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 RX2 enabled. FlashID0: 00EC 0040 - 0121 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.52.0 revision: 0.0 size: 0x2DB80 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED Original Imei: 35318803191xx Original Product code: 0560975 Bluetooth ID: 0025D048Fxxx WLAN ID: 0025D0499xxx |
10-29-2009, 17:55 | #4 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: HWKBOX,MX-KEY,CYCLONE SL3 ;-)
Member: 217461 Status: Offline Thanks Meter: 150 | Quote:
Hi, seem problem after downgrade n96 no local mode repair only with firmware original present. B.R. | |
10-29-2009, 19:03 | #5 (permalink) |
Member: 13999 Status: Offline Thanks Meter: 74 | firmware original present? do you mean firmware version of the phone before downgrade? firm is v31 but already flashed again with v31 but problem isn't solved. by the way, i have successfully done SCAN anfter flash this afternoon. only one time....and no more. |
10-29-2009, 19:31 | #6 (permalink) | |
seem product code v31? | |
10-31-2009, 15:42 | #7 (permalink) |
Member: 13999 Status: Offline Thanks Meter: 74 | after full erase, ENO and reflash v31 now local mode are ok, restored imei but phone blick white screen when power on. this is scan log Phone Type: RM-313 (Nokia N82) SW Version: V 06wk41v64.4 07-11-08 RM-313 (c) Nokia Imei plain: 35318803xxxxxx-x ApeCoreSw: 31.0.016 VariantId: 31.0.01601.01 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei: 3531880319xxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF what's wrong now? |
10-31-2009, 19:39 | #8 (permalink) |
Member: 13999 Status: Offline Thanks Meter: 74 | and jaf says: LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN |
10-31-2009, 21:04 | #9 (permalink) | |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
BR Alex | |
11-01-2009, 17:06 | #12 (permalink) |
No Life Poster Join Date: May 2002 Location: dont ask!
Member: 12411 Status: Offline Sonork: 100.113572 Thanks Meter: 813 | @pitone02 flash it on mxkey via usb using a full battery.. use this version RM-313_31.0.016_PR.C0R br freddy www.gsmph.com |
11-01-2009, 17:14 | #13 (permalink) | |
Member: 13999 Status: Offline Thanks Meter: 74 | Quote:
how flash with usb if phone doesn't power ON? n82 doesn't support dead usb flashing i will post it this evening. now phone dead again after last test.... | |
11-01-2009, 18:45 | #14 (permalink) | |
Member: 12411 Status: Offline Sonork: 100.113572 Thanks Meter: 813 | Quote:
run mxkey - choose nokia usb ROM - click connect - click nokia service tool choose model - click market else choose mcu-ppm-cnt - and the last one is click flash... still you cant follow my instruction better read here or download this PS.. YES mxkey support dead USB flashing.... br freddy www.gsmph.com | |
11-01-2009, 19:00 | #15 (permalink) | |
if phone doesn't power ON and N82 doesn't support DEAD USB FLASHING (i mean N82, not mxkey). PS. I KNOW Mxkey support dead usb flashing but...but...with phone/mcu that support dead usb flashing | |
Mr Odia N95 no local mode no test mode need Help | nzeiga | HWK | 21 | 02-06-2009 14:55 |
N95 8g no local mode no test mode | emilio00 | HWK | 6 | 08-21-2008 14:37 |
3100 no local mode or test mode | arturo011 | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 10-30-2006 04:16 |
