Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 03-18-2010, 14:30   #1 (permalink)
Member: 742476
n82 phone startup
i have n82 via this info
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
WMDRM_PD seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST passed
when repair simlock this error
SIMLOCK_DATA corrupted!
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
Product: V 06wk41v51 28-01-08 RM-313 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: A8C1D6713E691FF8
Calculating SIMLOCK using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 9.671 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-313_358082015535780_SIM.RPL"
Updating SIMLOCK...OK
Reading Simlock info ...
please instruction me
Old 03-18-2010, 14:33   #2 (permalink)
NIMESHFONOTLY's Avatar
Member: 760274
Post your full bus check log here...
Old 03-18-2010, 14:36   #3 (permalink)
Member: 742476
full log for repair sim lock
end via this error
Old 03-18-2010, 15:04   #4 (permalink)
gbluez's Avatar
Member: 73565
ONE
TWO
hope all is clear.
The Following User Says Thank You to gbluez For This Useful Post:
Old 03-18-2010, 15:48   #5 (permalink)
Member: 742476
APE Data :
SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2]
ASIC MODE ID: 00
PUBLIC ID: 7F58DCB9F2B8B46CEDA75B1DB0C446C7956D61F6
ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0FA0000B3EAA0058808963FAC182AB41A0F263E0
ASIC MODE ID: 00
 SecondaryBoot: RAPIDOv11_2nd.fg [BB5]  version: 1.37.1 revision: 0.0 size: 0x3B80
 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0001 0035  - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
 Algorithm: RAPIDOv11_algo.fg [XSR 1.5]  version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED
 SecondaryBoot: omap2420_m1_2nd.fg [BB5]  version: 1.41.0 revision: 0.0 size: 0x7C00
 Supported APE Ids: 24200703, 24200704, 24200705, 24200706
FlashID0: 00EC 0040  - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE
ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG
 Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG]  version: 1.57.0 revision: 0.0 size: 0x2E248
APE PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED
Total erase size: 128.00 KB
CMT NOR area [00FE0000-00FFFFFF] erased in 0.797 s
after erase eprom repair sd via this error end
Calculating SUPERDONGLE using security server ...
Completed in 11.453 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-313_358082015535780_SIMSD.RPL"
Updating SUPERDONGLE_KEY ...error 0x0
Old 03-18-2010, 15:51   #6 (permalink)
gbluez's Avatar
Member: 73565
post here the log from SCAN
Old 03-18-2010, 16:07   #7 (permalink)
Member: 742476
whats scan ?
Old 03-18-2010, 16:10   #8 (permalink)
Member: 1028430
you have erase full flash
and try to repair sd
if failed again
upload your rpl here
we will help you
Old 03-18-2010, 16:14   #9 (permalink)
Member: 742476
if failed again
we will help you
i done this act but same problem
n82 white screen
and this rpl my phone
RapidShare: 1-CLICK Web hosting - Easy Filehosting
Old 03-18-2010, 16:22   #10 (permalink)
Member: 1028430
it means after flash white screen
same problem like n73 ,if you flash with higher version
your phone goes white
try to downgrade your phone firmware version
after process
post result
Old 03-18-2010, 16:24   #11 (permalink)
Member: 742476
phone is phone startup no white screen
please help for solve phone start up this phone.
Old 03-18-2010, 16:31   #12 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Have you try , mr ravi gupta idea
some times works
Old 03-18-2010, 17:35   #13 (permalink)
alasmmar's Avatar
Member: 231153
1 back rpl
2 full erase on mxkey
3 flash this eno sw (rm313_ENO_x_2008wk06updv0.030) then writ this eno too (normalize_susd_eno_sharaku_urel.fpsx) then full flash
4 writ rpl
5 mxkey>serves>imei&securty>imei rebuild>repair sd
6 go to pm >click sd auth writ pm (wait 2mnt)
7 full factory
Old 03-18-2010, 18:30   #14 (permalink)
alasmmar's Avatar
Member: 231153
Originally Posted by alasmmar View Post
1 back rpl
4 writ rpl
7 full factory
sory u do it ago
writ this rpl 4shared.com - online file sharing and storage - download BB5_rm-313_BACK.rpl
then mxkey>serves>imei&securty>imei rebuild>repair sd
go to pm >click sd auth writ pm 1and309 (wait 2mnt) full factory
Old 03-20-2010, 10:04   #15 (permalink)
Member: 655817
Originally Posted by gbluez View Post
ONE
TWO
hope all is clear.
how to restore my orig.imei.?
i have a rpl back-up but i cant restore it....please help....
N73 Phone Startup filer also phone not boot mode alavukt Cyclonebox 7 02-01-2010 08:51
flashing e51 on usb.phone flashing complete but show phone startup failed ravin j tejura Universalbox 1 12-14-2009 13:43
credits lost and now phone is on phone startup failed vikas chadha Universalbox 9 03-18-2009 12:29
Phone Startup Failed Contact Retailer N82 (Plz Help How to Repair via MT-BOX) Shayesta197 Nokia Base Band 5 ( BB-5 ) 21 01-11-2009 03:48
Page generated in 0.72742 seconds with 11 queries
