Old 02-09-2010, 13:28   #1 (permalink)
Member: 292640
Thanks Meter: 18
N85 problem
N85 PROBLEM
PLEASE SEE LOG
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 18B0010912C20158A488211DC182C96F818C55B9
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: B5385A493D2188678E1FD88DA506480F874E2949
Reading RAP NPC (0x190 bytes)
Begin Certificate Request ...
Connecting to server ...OK, Login ...
ERROR: No certificate found in the database !
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
TimeStamp: 2009-11-11T13:22:14+00:00
SW Version: 31.002
Variant Version: 001
ProductProfile:
Simlock: simlock_3gstandard_bb5.bin
Imei net: 355708022774706
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-09-2010, 14:45   #2 (permalink)
HAROON's's Avatar
Member: 100592
Sonork: 1578498
Thanks Meter: 245
manole please give any solution for this model i have same problem
br
Old 02-09-2010, 15:40   #3 (permalink)
Member: 50772
Sonork: 100.1590990
Thanks Meter: 304
same problem
Phone Type: RM-333 (Nokia N85)
SW Version: V ICPR72_09w18.6 15-10-09 RM-333 (c) Nokia
Imei plain: 356**********-4
Product Code: 0569331
ApeCoreSw: 31.002
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 35************
Counter: 0/3, 0/10
Old 02-10-2010, 00:58   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,774
if u try with searching button , u will have same answer
1.do SX-4 and write PM without [308] area
in case after Superdongle repair , please use "SUPER SD Auth"
2.Check BB5 Secure Validation
[MXKEY - INFO] !!! NEW magic button inside mxkey !!!
this is have important info, where the real problem
3.if "Recover CERT" doesn't work ??
check this
Just in case if Recovery via Server doesn't work.......
need more file about CCC,HWC and VARIANT
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair
br,
n85 problem masterspargo Nokia Hardware & Hardware Repair 22 12-20-2010 12:18
please help me, n85 problem mele5 Nokia Base Band 5 ( BB-5 ) 4 10-09-2010 09:31
Nokia N85 problem !!!!!!! k2cause Cyclonebox 39 02-22-2010 14:24
please- n85 RM-333 - HWC AND CCC DATplease- n85 RM-333 - HWC AND CCC DATA GSMSAMI MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-18-2010 17:27
Page generated in 0.27835 seconds with 8 queries
