02-27-2010, 10:01 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | N85 SECURITY_TEST failed ??? SW Version: V ICPR72_09w18.6 15-10-09 RM-333 (c) Nokia Imei plain: 35570802554829-7 Product Code: 0560502 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355708025548297 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF 1. make Simlock RPL repair 2. make SD RPL repair 3. make SUPER SX4 Auth then write PM1 and PM309 PROBLEM SAIM SECURITY_TEST failed!....... Help me Mx-key tem |
02-27-2010, 10:06 | #2 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: Sri Lanka
Member: 1074229 Status: Offline Sonork: 100.1605299 Thanks Meter: 62 | Quote:
simply press sdkeys repair note use testmode coming cable 10pin cable | |
02-27-2010, 10:08 | #3 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | Recover CERT RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 04A00104B6DA0158D80AFE631A1BDC6B2FEFBFC6 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: B5385A493D2188678E1FD88DA506480F874E2949 Reading RAP NPC (0x190 bytes) Begin Certificate Request ... Connecting to server ...OK, Login ... ERROR: No certificate found in the database ! |
02-27-2010, 17:43 | #7 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: QQ:2557307931
Member: 1010502 Status: Offline Sonork: whats this?! Thanks Meter: 316 | Quote:
http://forum.gsmhosting.com/vbb/show...00&postcount=1 | |
02-27-2010, 17:49 | #8 (permalink) |
Banned Join Date: Oct 2009 Location: Inside Digital GSM Age: 35
Member: 1149774 Status: Offline Sonork: 0313-9541047 Thanks Meter: 1,163 | try this all procedure then post result thanks http://forum.gsmhosting.com/vbb/show...35#post5383535 |
02-27-2010, 17:52 | #9 (permalink) | |
Freak Poster Join Date: Nov 2008
Member: 898963 Status: Offline Thanks Meter: 69 | Quote:
scurity tes failed after repair sd SUPER SX4 Auth then write PM1 and PM309 can't solved write rpl without npc by mx key br; | |
03-03-2010, 05:56 | #10 (permalink) |
Member: 1074229 Status: Offline Sonork: 100.1605299 Thanks Meter: 62 | i gotta n96 security test fail and its automatically restart after 3mins. 1st i did in mxkey repair sd 2nd super sd auth 3rd write modified pm now phone is no restart woking gud condition |
SECURITY_TEST failed! on n85 | 电源ic | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 02-26-2010 09:40 |
N85 SECURITY_TEST failed! | kumar_gsm_kumar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-08-2010 13:54 |
SECURITY_TEST failed!" and "warning: SD authorized but verify failed solution | ..::Rizwan::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-03-2010 15:58 |
SIMLOCK invalid!, SIMLOCK_TEST failed!, SECURITY_TEST failed! | Raven21 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 01-27-2010 08:15 |
