01-14-2013, 18:59 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 45
Member: 166436 Status: Offline Thanks Meter: 28 | N9 unlock problem - SL3 !!! MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C087A25B Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0100D3DF Connection status: EHCI:HUB:HUB:HUB:USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.75 Library ver: 1.0.0.14337(12-12-2012) Phone type: RM-696 (Nokia NoRM6) SW version: V 92_11w50_1 16-12-11 RM-696 (c) Nokia ApeCoreSw: 30.2012.07.1.417.1 Found device in Sync and connect mode, rebooting device ... Waiting for USB bootloader ... Found device RM-696, hardware revision 1603 NOLO version 2.3.6 Version of 'sw-release': DFL61_HARMATTAN_30.2012.07-1.417.1_PR_417 Sending ape-algo image (7032 kB)... Waiting for USB phonet ... Verifying communication to device ... Server application: 1.6.3 Found product: RM-696 rev. 1603 Server implements softupd protocol version 1.8 Battery level 30 %, continuing. Fetching error list: ======================================== bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed Simlock ON: cannot flash unsigned image ======================================== Device connected: nmwcdc\Nokia N900 USB Phonet, PORT_ID: 382FFAC0 PUBLIC ID: 0000000000000000000000000000000000000000 PRIVATE ID: 0000000000000000000000000000000000000000 HASH: 88326E274CB96D25DA7C51D2AD07CB403903EA8B Hash file saved to "C:\mobileEx\3.5-2.5\data\SL3\RM-696_357923049186564.sha" |
01-14-2013, 19:05 | #2 (permalink) |
Member: 166436 Status: Offline Thanks Meter: 28 | need my credits back or review the problem please: Job Details: Imei: 357923049186564 Hash: 88326E274CB96D25DA7C51D2AD07CB403903EA8B Status: done with error(no results due to bad hash) Uploaded: 2013-01-10 11:24:50, used credits: 70 |
01-15-2013, 08:49 | #7 (permalink) |
Junior Member Join Date: Oct 2011 Location: Shanghai
Member: 1672513 Status: Offline Thanks Meter: 0 | I can calculated the hash for you. You send me the IMEI and the hash which are contained in a sha (or log or bcl )file, when I finished the calculation, I will send you a COD.txt file. You can use MXkey (or ATF or cyc) to convert this COD.txt file to a unlock string which you can type on the Nokia phone to unlock it. |
