Old 06-30-2010, 11:15   #1 (permalink)
shahabuddin's Avatar
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
n900
i think i m first in world flash n900 in mx-key.
mx-key flashed it with in 114 sec
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
SW version in image: RX-51_2009SE_3.2010.02-8_PR_MR0
Image 'kernel', size 1704 kB
 Version 2.6.28-20094803.3+0m5
Image 'rootfs', size 158336 kB
 Version RX-51_2009SE_3.2010.02-8_PR_MR0
Image 'cmt-2nd', size 81408 bytes
 Version BB5_09.36
Image 'cmt-algo', size 519808 bytes
 Version BB5_09.36
Image 'cmt-mcusw', size 5824 kB
 Version rx51_ICPR82_09w47
Image '2nd', size 14720 bytes
 Version 1.4.14.4.4+0m5
Image 'xloader', size 14848 bytes
Image 'secondary', size 109440 bytes
USB device found at bus-0, device address \\.\libusb0-0002--0x0421-0x0105.
Found device RX-51, hardware revision 2101
NOLO version 1.4.14
Version of 'sw-release': RX-51_2009SE_3.2010.02-8_PR_MR0
Sending xloader image (14 kB)...
Sending secondary image (106 kB)...
Flashing bootloader... done.
Sending cmt-2nd image (79 kB)...
Sending cmt-algo image (507 kB)...
Sending cmt-mcusw image (5824 kB)...
Flashing cmt-mcusw... done.
Sending kernel image (1704 kB)...
Flashing kernel... done.
Sending and flashing rootfs image (158336 kB)...
Finishing flashing... done
Erasing CMT ...
Programming CMT ...
CMT flashed successfully
Waiting for phones to boot up ...
Flashing completed in 1 min 54.640 s
The Following 29 Users Say Thank You to shahabuddin For This Useful Post:
Old 06-30-2010, 11:29   #2 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Congratulations if u are 1st one in the world.
Best Regards
The Following User Says Thank You to Shakeel_pattoki For This Useful Post:
Old 06-30-2010, 11:36   #3 (permalink)
kaleem munir's Avatar
Member: 720201
Sonork: 100.0000000
Thanks Meter: 643
thanks for test reporte here
Old 07-01-2010, 07:28   #4 (permalink)
Member: 1149774
Sonork: 0313-9541047
Thanks Meter: 1,163
thnx for updated info
Old 07-01-2010, 08:40   #5 (permalink)
kadricom's Avatar
Member: 526292
Sonork: 100.1597116
Thanks Meter: 444
Thanks for info bro.Mxkey is very nice tool
Old 07-01-2010, 10:18   #6 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
thanks you for your feed back with posting here
br,
Old 07-01-2010, 12:48   #7 (permalink)
Member: 1127720
thanx for the info, i want to test one with hang on nokia
Old 07-01-2010, 12:56   #8 (permalink)
kadricom's Avatar
Member: 526292
Sonork: 100.1597116
Thanks Meter: 444
Thanks again bro
What about the imei? IS it ok
REGARDS
Old 07-01-2010, 13:04   #9 (permalink)
Member: 336741
Thanks Meter: 152
@shahabuddin, whats the procedure to flash this n900 phone???
Old 07-01-2010, 13:10   #10 (permalink)
Member: 996278
Sonork: 192.168.1.1
Thanks Meter: 40
Old 07-01-2010, 13:23   #11 (permalink)
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
REGARDS
good question dear. when i flashed its show sl data currupted and imei show plain. when i power on the set and check imei it show correct imei. but the problem is i don't check the set in simcard. so becareful.
The Following User Says Thank You to shahabuddin For This Useful Post:
Old 07-01-2010, 13:26   #12 (permalink)
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
very easy procedure dear, start the mx-key with nokia usb rom,
put the correct file in mcu, press flash, press and hold '' u '' button from the set and insert the cable,
don't release u button until show usb icon in screen.
best regard.
The Following 5 Users Say Thank You to shahabuddin For This Useful Post:
Old 07-01-2010, 13:36   #13 (permalink)
kadricom's Avatar
Member: 526292
Sonork: 100.1597116
Thanks Meter: 444
when i put the flash its only MCU right?
THANKS
Old 07-01-2010, 13:41   #14 (permalink)
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
THANKS
yes dear. its only one file to flash.
The Following 2 Users Say Thank You to shahabuddin For This Useful Post:
Old 07-01-2010, 14:41   #15 (permalink)
rashad333's Avatar
Member: 1313964
Sonork: 100.1600702
Thanks Meter: 27
Thanks for info bro...........
The Following 2 Users Say Thank You to rashad333 For This Useful Post:
6230i CAMERA NOT WORKING - N900, N901 AND C907 MISSING fusion007 Nokia Hardware & Hardware Repair 5 02-15-2008 15:01
N900 akcel Chinese Cocktail 9 01-05-2008 09:14
nec n900 wanted mikezito Wanted Products 1 05-02-2006 22:45
1 x brand new N900 for sale stanic Sell ur Old and Used Stuff 1 11-23-2005 20:20
Nec N900 Phone ali42 NEC 1 08-29-2005 12:30
Page generated in 0.25130 seconds with 10 queries
