Old 06-20-2011, 11:43   #1 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
N900 NOT ABLE TO FLASH WITH NEW Mx-KEY UPDATE
CHECK PIC
WBR
sahil2000ind
Old 06-20-2011, 12:45   #2 (permalink)
shybet's Avatar
Member: 492380
Thanks Meter: 184
Try using Maemo Flasher. Get it here: tablets-dev.nokia.com restricted downloads
Tutorial here: Updating or re-flashing the firmware using the Flasher
The Following User Says Thank You to shybet For This Useful Post:
Old 06-20-2011, 13:18   #3 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\NASA>cd c:\Program Files\maemo\flasher-3.5
C:\Program Files\maemo\flasher-3.5>flasher-3.5.exe -F RX-51_2009SE_20.2010.36-2.
002_PR_COMBINED_002_ARM.bin -f -R
flasher v2.5.2 (Sep 24 2009)
SW version in image: RX-51_2009SE_20.2010.36-2.002_PR_002
Image 'kernel', size 1705 kB
        Version 2.6.28-20103103+0m5
Image 'rootfs', size 185856 kB
        Version RX-51_2009SE_20.2010.36-2.002_PR_002
Image 'cmt-2nd', size 81408 bytes
        Version BB5_09.36
Image 'cmt-algo', size 519808 bytes
        Version BB5_09.36
Image 'cmt-mcusw', size 5826 kB
        Version rx51_ICPR82_10w08
Image '2nd', size 14720 bytes
        Valid for RX-51: 2217, 2218, 2219, 2220, 2120
        Version 1.4.14.9+0m5
Image 'xloader', size 14848 bytes
Image 'secondary', size 109440 bytes
        Valid for RX-51: 2101, 2102, 2103
Image '2nd', size 14848 bytes
        Valid for RX-51: 2307, 2308, 2309, 2310
        Valid for RX-51: 2407, 2408, 2409, 2410
        Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306
        Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406
        Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2
113, 2114, 2115, 2116, 2117, 2118, 2119
        Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506
        Valid for RX-51: 2607, 2608, 2609, 2610
        Valid for RX-51: 2507, 2508, 2509, 2510
        Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2
210, 2211, 2212, 2213, 2214, 2215, 2216
        Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606
Suitable USB device not found, waiting.
USB device found found at bus bus-0, device address \\.\libusb0-0001--0x0421-0x0
105.
Found device RX-51, hardware revision 2101
NOLO version 1.4.14
Version of 'sw-release': RX-51_2009SE_20.2010.36-2.002_PR_002
Sending xloader image (14 kB)...
100% (14 of 0 kB, avg. 14 kB/s)
Sending secondary image (106 kB)...
100% (106 of 0 kB, avg. 106 kB/s)
Flashing bootloader... done.
Sending cmt-2nd image (79 kB)...
100% (79 of 0 kB, avg. 79 kB/s)
Sending cmt-algo image (507 kB)...
100% (507 of 0 kB, avg. 507 kB/s)
Sending cmt-mcusw image (5826 kB)...
100% (5826 of 0 kB, avg. 5826 kB/s)
Flashing cmt-mcusw... done.
Sending kernel image (1705 kB)...
100% (1705 of 0 kB, avg. 1705 kB/s)
Flashing kernel... done.
Sending and flashing rootfs image (185856 kB)...
100% (185856 of 0 kB, avg. 185856 kB/s)
Finishing flashing... done
CMT flashed successfully
Phone Type: RX-51 (Nokia N900)
SW Version: 20.2010.36.2 V 0.0.000 RX-51 (c) NOKIA
Imei plain: 35693803234225-6
Product Code: 0580952
Battery voltage: 0 mV, current: 0 mA
ApeCoreSw: Nokia N900 (RX-51 rev 2101)
Language Pack:
- not available.
Detected as PA_SL3 phone.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
TimeStamp: 2010-09-13T06:07:23+00:00
Variant Version: 001
ProductProfile:
Simlock: simlock_3gstandard_bb5.bin
Imei net: 356938032342256
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
SUCESSFULLY FLASHED WITH MAEMO FLASHER
PLS MX-KEY TEAM FIX ALL THE MXJOR AND MINOR BUGS IN NEXT UPDATE
ALL USERS ARE SUFFERING FROM MX-KEY BUGS
WBR
sahil2000ind
The Following User Says Thank You to sahil2000ind For This Useful Post:
Old 06-21-2011, 06:55   #4 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
STILL NO ANSWER FROM THE SUPPORT TEAM
WBR
sahil2000ind
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
Page generated in 0.17253 seconds with 11 queries
