Old 02-23-2010, 22:10   #1 (permalink)
sajidashraf's Avatar
Member: 501674
Sonork: THEIF OF HEART
Thanks Meter: 883
Thumbs up N91 sd repair success
N91 SD REPAIR SUCCESS
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
APE Data :
SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0]
ASIC MODE ID: 00
PUBLIC ID: 47B2CF8A62BA4527472873F86442AA9B6B470D5E
ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000
ROM ID: 1DFD66132C872FD4
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2]
EM0 ID: 00000232
EM1 ID: 00000352
PUBLIC ID: 05F000196D8B4F51464AEB2E2A52BF6B320D399C
ASIC MODE ID: 00
ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID: F28A211FCEA7B19D
SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: B2E0D53F2FDDF1FC8E55510130F0D06771352435
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
FlashID0: 00EC 0036 - 00A5 00C0 [Samsung KAL00R00EM-DGXX,512 Mbits] type: NAND,APE
ALG [35]: OMAP1710 UNISTORE-II-1.2.1 ALG
ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000
Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0
APE PAPUBKEYS HASH: B2E0D53F2FDDF1FC8E55510130F0D06771352435
Original Imei: 35363301029784
Original Product code: 0523187
Phone Type: RM-158 (Nokia N91)
SW Version: V w33_06w24v2 24-07-06 RM-158 (c) Nokia.
Imei plain: 35363301029784-5
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
"RM-158" folder created.
Imei net: 353633010297845
Version: SIMLOCK SERVER VERSION 62
Provider: Hutchinson 3G (3), Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2342000000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN, DATA=23420F
BLOCK 2: 1=OPEN, DATA=23594F
BLOCK 3: 1=OPEN, DATA=23420F
BLOCK 4: 1=OPEN, DATA=23594F
SD REPAIR
Product: V w33_06w24v2 24-07-06 RM-158 (c) Nokia.
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 6.750 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-158_353633010297845_SIMSD.RPL"
Updating SUPERDONGLE_KEY ...OK
Updating SIMLOCK...OK
AFTER SD REPAIR
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000352
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST failed!
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
AFTER WRITE PM SECURITY TEST FAILED OK
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000352
ASIC MODE ID: 00
Product Code: 0539387
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
..::S@JID::..
Old 02-24-2010, 02:42   #2 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
can you share here in your pm write
Successfully Repaired 3110c Security Test failed after SD Repair romeoluv56 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 05-14-2012 12:37
Nokia 7210c sd repair successfully JINDALGSM™ Genie Universal 0 03-05-2010 16:49
3110c sd repair successfully with genie JINDALGSM™ Genie Universal 1 03-05-2010 10:34
3110c sd repair successfully with mx-key JINDALGSM™ MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-04-2010 09:11
Page generated in 0.21459 seconds with 9 queries
