03-18-2010, 12:32 | #1 (permalink) |
Insane Poster Join Date: Jul 2009
Member: 1080109 Status: Offline Thanks Meter: 22 | N93i stay in "NOKIA" LOGO,MANOLE please help! I flash it again and again,and the problem is not solved. here is the Log: APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: A05815E0053DBE33E026ADC1A030BA3F957CD4F2 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM1 ID: 00000295 EM2 ID: 00000B21 PUBLIC ID: 09500117D08E0154178A819ECFDC02909C5C2AED ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: FC19729CFB3603BDCBCF34CB6B5030C5E11CA306 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.39.0 revision: 0.0 size: 0x7B00 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 RX2 enabled. FlashID0: 00EC 0030 - 0011 0000 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: NAND,APE ALG [35]: OMAP2420 UNISTORE-II-1.2.1 ALG Algorithm: teflon_sam_nand_xsr_m1.fg [OMAP2420 UNISTORE-II-1.2.1 ALG] version: 1.46.0 revision: 0.0 size: 0x27B20 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS HASH: FC19729CFB3603BDCBCF34CB6B5030C5E11CA306 Original Imei: 35325001028957 Original Product code: 0545559 Bluetooth ID: 0019796E4E1D WLAN ID: 001979721EAD Phone Type: RM-157 (Nokia N93i) SW Version: V 06wk15v42.2 06-08-07 RM-157 (c) Nokia. Imei plain: 35325001028957-1 Product Code: 0540893 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei: 353250010289571 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
03-18-2010, 14:12 | #5 (permalink) |
Junior Member Join Date: May 2009 Location: inland
Member: 1024615 Status: Offline Thanks Meter: 4 | No Need ENO Software.... After You Erased APE Section You Need TO Recover Certificate APE Variant Or APE R&D Certificate You Can Find This Button AT MX-KEY .... br... |
The Following User Says Thank You to W@hyudin For This Useful Post: |
03-18-2010, 14:39 | #6 (permalink) | |
Member: 1080109 Status: Offline Thanks Meter: 22 | Quote:
but,Can MX-KEY recover APE Certificate? and I use "Recover CERT",MX says "ERROR: No certificate found in the database !" I beg MANOLE can solve this,or I have to pay 200 dollars to customer | |
03-18-2010, 14:50 | #7 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Be MXKey Expert only in one day: MXkey Tips and Tricks - HOT SOLUTION ONLY HERE Write your CRT by other method. RPL_collection_V1__without_NPC_DATA__made_by_MxKey |
The Following User Says Thank You to gbluez For This Useful Post: |
03-18-2010, 15:37 | #8 (permalink) | |
and I write "N93i_without_NPC_DATA__made_by_MxKey.rpl", but still not work... oh,***! this phone made me carzy! | |
03-19-2010, 03:58 | #12 (permalink) |
Member: 1080109 Status: Offline Thanks Meter: 22 | here the full rpl I backup: [CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=0545559 PSN=SHF568325 HWID=6101 NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303534353535394300000000 NPC_DATA_2=0000000000000000000000008939E0944DDACA4 5AA9A3200000000000000000009500117D08E0154 NPC_DATA_3=178A819ECFDC02909C5C2AEDFC19729CFB3603B DCBCF34CB6B5030C5E11CA306A7208D9C9C042016 NPC_DATA_4=DCC349388DA43B0BA232C69A000000000000000 000000000000000000400000047534D0000000000 NPC_DATA_5=3335520001825917FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=1D4E6E791900000000000000000000000000000 0000000000000000000000000574C414E5F494400 NPC_DATA_7=AD1E72791900000000000000000000000000000 0000000000000000000000000434F4D5F53430000 NPC_DATA_8=D85E103E01EFAE0CE123526F8E9C1B5CCD8BDD4 5A7BA24DEC2BB92722B25F9D573DF840EF6D01CF0 NPC_DATA_9=32FB48AB20AA6D1159231AD89DC6A9F1C6B4A9D 7B17AAD2CB9CA021F387D763DBF3E28AC7C27D1FD NPC_DATA_10=1FF718944C8C06794BBE8ECF74BCFB2091AD3F F1694F83D702B53C53EE85AE6B2BE9BD154D300A38 NPC_DATA_11=8B48E4C176B98583F4804EA2968D07CDC60AB4 39B5D0FF235BF79E74CD4AEF4907038295951F27FE CCC_DATA_1=4343434302004150010000009138E094BC5E814 5385B020000CA9B00000060010000000000000000 CCC_DATA_2=000000000000000000000000000000000000000 00000000000000000000000003035343535353943 CCC_DATA_3=101A09450000000000000000030000000E00000 00100000000000000000000000000000000000000 CCC_DATA_4=000000000000000000000000000000000000000 00000000000000000000000000000000000000000 CCC_DATA_5=000000000000000000000000000000000000000 00000000000000000000000000000000000000000 CCC_DATA_6=000000000000000000000000000000000000000 000000000ADFA761E7E4319317CA01509EC9636BC CCC_DATA_7=CAD4ACE3D8DC3396C82AF7FA82F2324D9FA8D69 6BD9631B4D0B9031670DB572F49270B415E74B7D7 CCC_DATA_8=338E50BFE885C6E5C8D96064FDD137512096CB6 57759A6882083CB3A483424057FAB2AC1E045E4F0 CCC_DATA_9=990B80761815188B3CB54CC7CE8D21B2C4C13AE E8C454CFDCC1CCA401154015D HWC_DATA_1=4348574305004150010000008939E0944FDACA4 5AB9A320000000000000000000000000000000000 HWC_DATA_2=000000000000000009500117D08E0154178A819 ECFDC02909C5C2AED303534353535394300000000 HWC_DATA_3=000000004A4FE4D8F85091908523A1350A5AFB2 E528C0C7574F05B4D222E467D7BA90A1F916873A0 HWC_DATA_4=22657B353C4220BFA85017DAD8C72AE4F6F7550 7ABB6EC2D2674C3E078F24777888B121C3856EFBB HWC_DATA_5=974343120B0DE984A3CA58973B869BAAAAC6C25 887F453F10ADEDA9F42FA838C9D18979C9A204CCF HWC_DATA_6=3FA3235BC2BD8FA265D14C5A CHECKSUM=-1 [CERT_PROG_DATA_OUT_APE] PRODUCTCODE=0545559 PSN=SHF568325 HWID=6101 CHECKSUM=-1 [MISC_PROG_DATA_OUT] RF_DATA_1=00010011000000721BB400000000000000000000 000000000000000000000000000000000000FFC7 RF_DATA_2=FFEDFFF2FFFC0000FFF7FFE3FFD2FFCD00000000 0000000000000000000000000000000000000000 RF_DATA_3=0000000000000000000000000000000000000000 000000000000000000000000000000000000FFD3 RF_DATA_4=007700020062FF3FFF0D40004000FF7200410000 247A247A247A247A1FFF1C2818F51709147A128F RF_DATA_5=11470FFF0EB80E140CCC0C280B840AE1247A247A 247A242F21731CDC19501697144B125010AD0F3F RF_DATA_6=0E050CD90BE30B000A4009740005242F000621E2 00071F020004006E1AEF00000000000000000000 RF_DATA_7=000000000000000000000000000000000000FFA6 FFD6FFF1FFEC00040000001B001B000E00000000 RF_DATA_8=0000000000000000000000000000000000000000 0000000000000000000000000000000000000000 RF_DATA_9=0000000000000000000000000000000000000006 00620000FF7940BD403E0599003D0000247A1EB7 RF_DATA_10=1AE017AD151E128F11470F5B0E140D700C280B8 40AE10A3D0A3D099909990999272E23881E621A9E RF_DATA_11=1754142711E2100A0E890D4A0C330B4C0A9A0A0 C098E08EA099909990000272E00012432000220D5 RF_DATA_12=0008006E1B0A000000000000000000000000000 00000000000000000000000000000FFD6FFF7FFFC RF_DATA_13=FFF7000000000000FFF7FFBB000000000000000 00000000000000000000000000000000000000000 RF_DATA_14=000000000000000000000000000000000000000 00000000000000000000000000000000D00620012 RF_DATA_15=FF794000404B0629003D0000247A1EB71AE0185 115C2133211EB0FFF0EB80E140CCC0C280B840AE1 RF_DATA_16=0AE10A3D0A3D0A3D272923421E151A73172C13F 711BC0FEB0E720D390C260B420A920A07098B08EA RF_DATA_17=0A3D0A3D00002729000123F2000220880010006 2FF3FFF0D40004000FF72004300001A3D1A3D1A3D RF_DATA_18=1A3D1A3D1A3D1A3D185115C213D6128F10A30F5 B0EB80D700CCC0C280B841A3D1A3D1A3D1A3D1A3D RF_DATA_19=1A3D1B4218AF160E13C711DF10360EB00D6F0C6 10B680A9709B900081B42000918FE000A17440012 RF_DATA_20=00620000FF7940BD403E0599004100001AE01AE 01AE01851166613D611EB10A30F5B0E140D700C28 RF_DATA_21=0B840B840AE10A3D0A3D0A3D1AE01AE01E3F1AE 11822153D12E510FB0F600E0D0CDB0BE20B270A8C RF_DATA_22=0A0409870A3D0A3D00021E3F00031C68000419E 5001400620012FF794000404B0629004100001AE0 RF_DATA_23=1AE01AE018511666147A128F11470FFF0EB80E1 40CCC0C280C280B840AE10AE10AE11AE01AE01D5A RF_DATA_24=1A5317C314F012A110CE0F610E210CCE0BD20B1 F0A890A04098A0AE10AE100021D5A00031BB40004 RF_DATA_25=196F00160010003D00000000000000000022000 0000000170004FFFFFFFF00180054000000000000 RF_DATA_26=000000000000000000000000000000000000000 0000000000000000000000000FFED000000000000 RF_DATA_27=000000000000000000000000000000000000000 00000000000000000000000000000000000000019 RF_DATA_28=0004016F000E001D00060001000100030021002 4000C000000000000000000000000000000000000 RF_DATA_29=000000B00000000000000000000000000022005 00001000100DD0000000000000000000000000000 RF_DATA_30=000000000000000000000000000000000000000 00000000000000000000000000000000000000000 RF_DATA_31=000000000000000000000000000000000000000 0002C00B6FFF50000FFFB063503FD000300010006 RF_DATA_32=031E00F2004E00EB01D101B4160415491541001 F0018000E005CFFBB00400150FFF0327DFFF00004 RF_DATA_33=0041000F003A00180036002000310028002D003 0002900370026003E002300440021004B001E0050 RF_DATA_34=001C00570019005C00180061001700660015006 A0015006D00160070001600730016007600150078 RF_DATA_35=0016007D0015008200130089000F008F000C009 50009009B000700A0000400A5000200ABFFFF00AF RF_DATA_36=FFFE00B5FFFA WARRANTY_DATA_1=00020001000001B8000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_2=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_3=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_4=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_5=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_6=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_7=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_8=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_9=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_10=000000000000000000000000000000000 00000000000000000000000000000000000000000000000 WARRANTY_DATA_11=000000000000000000000000000000000 00000000000000000000000000000000000000000000000 WARRANTY_DATA_12=0000000000000000 PROD_DATA_1=000400070000000101000100347F98011A344A E67F2A3D001C215250451010309021109E00010305 PROD_DATA_2=0503FC0B00004500D00100F02F832084440420 0000460000000003000A5348463536383332350000 PROD_DATA_3=04000830353435353539000005000830353335 373332000006000830323033303437000009000536 PROD_DATA_4=31303100 BT_DATA_1=00C1000400020008FFFFFFFFFFFFFFFF00030020 FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_2=FFFFFFFFFFFFFFFFFFFFFFFF00040020FFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_3=FFFFFFFFFFFFFFFF00090040FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_4=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF LOCK_DATA_1=01340009000000010300012000300000000000 0000110000000000000019F815E800000000000000 LOCK_DATA_2=00000000000000000000000000000000000000 0000E0000000800000000200000002000000AB0FBD LOCK_DATA_3=96AF2AC271D26264AFDEAD03006A0D0D77E77C 91FF88774BC23AD377FAC692EED4EBE0826D5D16B5 LOCK_DATA_4=D7476D9A218282F0D65552510DF54A39F65626 6B5AA39611CE368AAEDCC46F328BA90ADBD44B6270 LOCK_DATA_5=1D68C176103F55C902F345BDB7E66424880694 38B143895F02158044D8126D7192CF8B7E53A892F5 LOCK_DATA_6=88881FD99603C819E9FC066E3917A0C7FAA5AA 330152EE95FFEAFC5D6F5545AE53D2F2D215E00C00 LOCK_DATA_7=00D00B00000100000002000000AB0FBD96AF2A C271D26264AFDEAD080069547845E7551D2CFD8603 LOCK_DATA_8=190D3E517377D72D1C227291244777D95BF942 87DADA4E0E8D950981BB4C32AD704F33E0D4BCCE33 LOCK_DATA_9=7490C01CA6A92E95964983855BA7679BFA3491 1221CC3285BCA02FE94B563340F3AF9193B0572559 LOCK_DATA_10=D34F948B333BADDB60947A1C018BABFAD1FD5 D5507ED0B77A9DDF0DE35080D3BDB372B55F87ADDF8 LOCK_DATA_11=8800FCB7BC2967C5028EEFCA11B65F5C524B8 E5E07090DD54F924F1C286D298A29789F84824F6620 LOCK_DATA_12=F5429DD481937765404397ECC44135F363F66 562D7413C3CEF5FC0E82783E242811CD76DFE2E6BD6 LOCK_DATA_13=180B0B4F0B7CB6C97EF09FDDAD32FD4F06290 B4FBA705E9794EF77720B3B3311B031317DEAA9804B LOCK_DATA_14=96D7F9A26BA15A4CF68D3E0C2563459D81D19 2FF23DC4355829B385C016B009BEDD1A7E89F947CAD LOCK_DATA_15=891032B03D52F48A74650745F4F1B3515A4A4 745F32976CDFBA7109C407202E2A4B5EF0D9583249A LOCK_DATA_16=1DFCD99E555CF58CD5E1CFF1B8ED29CB93CAF 79176F52F76B3D50BB0546A3BC9B2CA9FF832226577 LOCK_DATA_17=B4079EF2BDFF3B78EC65AD2433ACB7D1FE68F E0959FEBB7DE30ADCC5C46435DAA2CC2869DA04EF02 LOCK_DATA_18=D0FA7CCA27F94D05BB260A218A7131A223902 969BF0EC8E232AEF2F502801C9E61E4F74A0923480F LOCK_DATA_19=BCC0B6861D9F1D76D1B0219AE098EEB73C72C 168E5D6A41DFE6550678C97360974D984CBB4B653C7 LOCK_DATA_20=AFA280C7845046126ED804DED41C54CAAE155 6252F3D3FD6A8A82C15EE2173A79A0AEE346F358C21 LOCK_DATA_21=4A1CF263A949B1AF2D7E30987FD1A9CBE2B35 E0233DBA5B18B496EE4DD93B9054BBF520D79DCAC64 LOCK_DATA_22=DEAF5BADDCA9DCC10ACB3ABF995E5C28B1CF4 0D5A05F7753CF29D393E1606C8C5B72409B8A36B31E LOCK_DATA_23=8DBFBC1F8DA7972D813008BBB7E2A3EA14612 12EE8F7C05840D0B4DC05DAFD7E285C758505E83CEA LOCK_DATA_24=6818DFA1B8544E4211AE1045479D4DFD60486 73C38CEEE4EBB1AEE23D9669F3F75415ECA4A955679 LOCK_DATA_25=569D32DB1C4B4A51432B5FE38D5132D8AB08D 5465916C5E8E6C993CA0F1CC0940D7A182C42BF8BF6 LOCK_DATA_26=DF67AFC9B0A2CC8F005C496506EBA24056DB1 4E7BA19695AB1A9934145872721B973B6B19688CD18 LOCK_DATA_27=6DE1F4AC590B04DE6A0CB8C87C0C6A75836ED 84D0A2E0ADA60A85BF009305D68D05B494D6307E4B1 LOCK_DATA_28=AFAE448F3823D42D5242D5124B9463C7490CF 4FA721AFBAA80416B0970A2A63578D3B7F691ADC063 LOCK_DATA_29=1A11D26817B8B08708234F92CAC2F51782B89 B45F927375C34C507AFA36930B943FFF066D6D3E511 LOCK_DATA_30=4704764D98EE3C8D8A8052FFEC001A2702376 241FDD09155590B6A2B4BA9D227DEB4A602F3FFBC36 LOCK_DATA_31=70A3D299976A25C3565990DEEB860E314C300 0F22D023B7CB567DA0B454D4D6E9755AE11528EA357 LOCK_DATA_32=01B0BBB86E98C80467AF035CF9273419F3B9F 89408B264B2CD11692296DE02A458099497077FDD9B LOCK_DATA_33=95C4039EB4408E24C5AAB02A401F7458AE6AB 542FE240469B6254913CE1919E9AE7BDE953D6B2B59 LOCK_DATA_34=68E40B1B8C3AB372FE5F8B346E8FBD9EB7ACF 818605F45EB0466B6D84A55E54ACFA5E6E568E5F0EE LOCK_DATA_35=C3AAAFCDF07A1DD50B7FAEE21612836364CD3 9515FE20364BCD2BD151E17F30594E0CC051DAFD983 LOCK_DATA_36=9F83190EDFF3583A0BEDD94A670D53A8E7831 05F25E9E7FD6FFB126B97FD668DB2707E61017D89E1 LOCK_DATA_37=D28327E55417F15BBFF22AA08A6F0DF7B7B65 3472ECE6BEB1F39898C27BD0BE48DA98EAC55F0A6C4 LOCK_DATA_38=5EA69AC67DA4482214F2AE8C48EE01F848774 0A1E36FBE30B3949B080BB00B1C0C1C55B3AAA4E833 LOCK_DATA_39=5A9109A2072979E990ACC91A3C8F6915E81B6 98E679FDF2529E89284D046821A7A6F4F882DD38D33 LOCK_DATA_40=6030C27EC36685F5A864D6F189503A554409A BECEC1EB6FBB449D4EB66A084177FBADF7019B63605 LOCK_DATA_41=EEC87D1AF7A2D9FA0E1995EEBD11EEF29E978 F2E43F3E8B4578B75E23696F3CCF942937072E08ADE LOCK_DATA_42=BBCD71C5E3E8085FE64D80B27D559B5D9BD0B 40F7281888287AFDE196EFEA35D844C88C586216171 LOCK_DATA_43=D8A6B41F3444EAC4EA4F161EADE48B813DD45 482637E985F5A3338E805FA06172407DABCAB9EA791 LOCK_DATA_44=6A7F3EE5B1FE6B439D285779917D6769C5351 8CB9A5F33451CB56CD0F6E4628D39FF944F60678F50 LOCK_DATA_45=DD051875879825A1781FC87C383B85FBB10D3 894AED500483A8F43AEBACE48EBC30AC7A88C408F87 LOCK_DATA_46=D66C6AC0E5CEB0658DEAF538EB43E1950C37E 7FB6A3629A18AAE35A07F9E8D2684FCABBD1979AB1E LOCK_DATA_47=F2039DFBD14FA02C3AD937449AD521EFE69C3 DE73F8D0DEC584DE966222A3C1135EC3ACD7247C8B4 LOCK_DATA_48=748506FFC0597D07D8F48699CD617DA557E65 4E047DF403BC10FFD66F8186B364B88C9FE156AF5EE LOCK_DATA_49=154E738E550EDADD1EE1550E0EF3BDBCE7B14 180BEEED1A3F298DDEAF427E4DC8BF6642B936D0C59 LOCK_DATA_50=1F39F135A495100688F0F0DB983A2643B5259 49CB01D224E7EF76A3858702A7949790C3E4CBD33E1 LOCK_DATA_51=14D55E42C2C623BB79E18A00F18DDD40FDB64 B079FF87CF05E66C2A4B145CB51513D304150526809 LOCK_DATA_52=CF9BFB3E5357504CCCFDE0F89EDCDA50BFB36 61A6D9EDA52578C2B315705A6738C5B98B393022F14 LOCK_DATA_53=BDDD5FE7541727D8F559DE4BC4BCB20B439F1 428666EC880BC8338F54416AC351270468370D121F1 LOCK_DATA_54=3B48F72BDC5F2F13C4A28F259B4504CE72CCA 640B341314B1C1FC2C813F2B5C7442FD122250C9EAD LOCK_DATA_55=D4ABE0681875EAD139E9816C3EDE734E3EFDC AF4A558F09480E501CF872BD05F546AEC1978E4E6DA LOCK_DATA_56=DDB1D562EF5481BF1504A6149BEFDAF8B02F2 6B8D2D148344292A804A886CA533DF8D9DE124A62BA LOCK_DATA_57=DBA70E8A3E17E8F67AB1EC6B8294E62BB5C75 51615F9CFC1310A4C000BED332D5263AA16A89B1F4E LOCK_DATA_58=B42B58D64B842DF2D8189507A26775693D321 6AA29AEA1E035B7A1BF4C214AB35EA8FD3BC8A005AC LOCK_DATA_59=E100485D8ABE726661F3C80618F793967C863 5C873D07AA7F9EAF78C2CC77BFBBB0C38B5024F90F4 LOCK_DATA_60=9CD4CE66A0FB516AD287F95E6820332DA4CD5 CF592EFD03118731EF29834DABA125FF599148278E3 LOCK_DATA_61=BB0B31DE6C678112EFCDD8442B8FA0DC07350 5E30C3A3B8FF79A3CF7971D70488A52593EEB700DA3 LOCK_DATA_62=0AC44615766F057E49D0FA9EC217D8C2FE021 0FA75FD34115E62727F2AD179F3AC5BA14129956674 LOCK_DATA_63=87328F992799A1CCBA578416E592AF7CCD746 FC0C810BFB61B3DE1C5DD615575468A9EC19542D3DD LOCK_DATA_64=FE88E872705011A08A587A0A7AEDB27539948 45A1BE981670F0C2B39B671A2CCAD435953BD23924B LOCK_DATA_65=113779FD1DD6EC100B101150CF8BCB6EC10EF C53EFBC715C1E58A35CF204ADECCABF469B74230E8E LOCK_DATA_66=18BAA4148E8225BD36B16E6C999C38A600B02 98F27CA8FF720BE82C32392F639E97BFD04782C69EF LOCK_DATA_67=AE81641CE7CE33C7D4898895B25170B956F8C 53E9DFD80C9A30FFB9FCD5CC51C2A602BA8937E7306 LOCK_DATA_68=BA8E2AE6977B78A29A1B3599CFF70FF05E452 D30B488BC3AFF13B6D1661B9468A7CADC469F87E8FF LOCK_DATA_69=33D2CAD0F0EED78A3B6E42610362BE95EBD09 19FD2BB1D1966AC43118EA5E5D7B3A2D7DF987965D8 LOCK_DATA_70=C09421E97A65AF932638D332995492CF883EE 52C9F6845DA6BA2A2674A74051F687E7E64CDD6D994 LOCK_DATA_71=03522B233CC435464A51F8D932D8413F838CA FC538CCF23C6D5E1B47317166357F3AF6D1ED5C04EA LOCK_DATA_72=A3E96F1435C1678B75D48C5DAA10336751530 1FB0130967D12F0289A5AE03DE8A0F02E86099DD8A8 LOCK_DATA_73=1020C418ECD08457346F2CF1C296E66F1A1CC B8FDF6F9B5D26EEC2C891BF0844BDAB90B1C44F9700 LOCK_DATA_74=2F72A62DBA87D541FEB800FE7030B18C3F947 9AE89899D02A2476F9B3F45416B920284EF0D50CB2D LOCK_DATA_75=36674F74CEAD678E3DD25F86C649DB1D49852 8509317FA6A5640801E818573EDF51343B50FAAE811 LOCK_DATA_76=F037CD7273393A978BB9F36029AF7F505A7B6 F79BC1CA2BF18EA7814A7BA5E6CBF14513D33F30A0A LOCK_DATA_77=F70928D5077A5D9C140112A23F7A7FD6D2D67 965F64BDF66E43378EAAA8658D69028711797747DA1 LOCK_DATA_78=0129A912F4AF3BFA0DA3813FC8E41DF5C8088 7E4A9819DD25EE2FD1E5F30E8AF9E46F780C721784D LOCK_DATA_79=28B92C3A3BB00ABE892817F531626FF2AAFFE 65358E8D0954DE05C313C2908D8248B90191DC08DF8 LOCK_DATA_80=7B474AA772CBD569FDFA713B09F23F8601917 970356AD8B541823A316F0DBD5BAFD42C3A58F20964 LOCK_DATA_81=F9BDA9234926D0E2C434EAD9332E4175D6A20 D51F3406003AB71C01FC9085D0CB53C9867637A5D98 LOCK_DATA_82=4A495808CD5C59CF99E4A13A001F8A693356E B8F07959DB6D2CEA3F4AEF2439D30818FD599E4D0B7 LOCK_DATA_83=C2F9B17537A6B337461151AB5B1BC7153754F D7CCD126A430AA528A6491015000000080000010000 LOCK_DATA_84=0002000000AB0FBD96AF2AC271D26264AFDEA D0400CF5DCF65910668E798332D519F7DC010B0C823 LOCK_DATA_85=56C53F0A5CFE51711BBAEF8BB20D1A131FD9D 41B15B30B60598F490B555B51A56B9190748A604F99 LOCK_DATA_86=13B5AB5E5725B145C0201F154EE03F9BD901D B94915A31704864221819686B57457D77434649228B LOCK_DATA_87=3ABFE1552B92E09B098C1A22D4B39212BF34C FA519FD5CFB19F553E95507FF52EF469C64389C9678 LOCK_DATA_88=EFF66E55037E8FE796FE72C4314EA95BF4013 6239A6672DC2F5E17FB6980005049942712F206C5A0 LOCK_DATA_89=4D15F0991726C6D58BE362C085CD4BBFE418A 318EC91D9565C0F7348634F3337D95EF6F9515A6F4B LOCK_DATA_90=A62837B56010AB288D01252B44FD0217F6DDE 26A514EF73D2E455A9D5431CAC8387C91272B322F19 LOCK_DATA_91=AF6365BF7DB42C7C187EB33649A2D9460F770 D13337BEB0101EE1ABA1DFF6304D6EE7BD5B477D381 LOCK_DATA_92=41992FF4A8C248907464DE7CACDA4AF4EDA5A FD982B540FB724507FE91A6C202C550D7F8AFB7B6DF LOCK_DATA_93=58482109237EE16EF4EFB7E981F03CC73FFCA 899C2D40648A91D0404281A25B2BD0AC5175C4A4680 LOCK_DATA_94=D9C4FCB1B2DFCA04680E0F0EFF401EC721646 BCEEBAE31CF0B58AA2122F344EE7083D8F4DF27CCA2 LOCK_DATA_95=156039EC1F0DFA461D3CC9CF300DDF2DCCCB3 CDFB845526666FE3F69C219A2BF7986954FBDDC8A55 LOCK_DATA_96=BCCF8AD56FC10DB96993D34A1BA94B098E675 9C299C680D670F846A8537E68CA9F0D4EFC5AF03EBF LOCK_DATA_97=CFAC48A8F16C72D227F85B99681BBC6D3892E 65209198F153BA91F79F7441EA499745326F06564DD LOCK_DATA_98=806332022616522EA6A8B6D6F46D67BF1BD4D D736A43EB5D018251A8B1C1BD5DF96A45AAB4ACBEF1 LOCK_DATA_99=3CA04493F91E2FB3B968923DEAA5EF0AD29DF 1529A9ADDF622A323B34F9F27CBEDD3D90394DAECBD LOCK_DATA_100=0D1C45E3A79AA95D317662000AF515673432 AAED4C393A4135F7E3F6148A686A4F20BF42D0424D81 LOCK_DATA_101=6E0E2A1820E74E0B765F503F48F3FCE7B8B8 15442FAA31C217CB6C9D345EDB334DB51719A0E9F6FC LOCK_DATA_102=CDC52244E64FBC84CC56F1CF9AFAE0E203BD 0C403C0C769C6203E57C82160CE9CC7F27D61460B7D8 LOCK_DATA_103=827622D520FDFAB75DA2AF4F500C8E7A314D B0C7577FD61EF0ACF37C95C9ACA98F42DAC810C41E87 LOCK_DATA_104=282494D0E38062A34BB5A6D706B40B4250FA 3D90457AB20E76F6DE98AE65D6D03821010A63FDB135 LOCK_DATA_105=B74B154E8E84E5A3DF951080D99B2549437C AF95B46296502B5685B8D96ECB1C3BEC6A6734F62FB4 LOCK_DATA_106=F297E44A8ADD22F85669004C3E14B79187EB E628A0CB989B30634D2DF823478B60994A30FD89B70E LOCK_DATA_107=FDEB9E51CE9E467434B5F368B91DF4538692 F8D2DCDC1DB21442E5E3A337455608E2DAD2EACCE1CF LOCK_DATA_108=91E0E468E41717519015E6E86F5A849343E4 8E1CC5EF6B8E3A86A96F5E20A4A8AA7E44BF45AE3B3F LOCK_DATA_109=E5C772EFEEF88F03081290B16802FB96F7E4 07C2AECA2BBFEBBAD034F99C3993CACD48525FABA7E4 LOCK_DATA_110=06FD8F41B18DBD977300706226613E667009 4A11AB3642FB7491988058AD7923B0AF4A31BE77769D LOCK_DATA_111=C7426FB1168E863639BD0E03521138B75D26 0DC391282ED7E3196F7A503D81A98CDC4E8C6BF72D55 LOCK_DATA_112=E6E7F8126EEA4DFB58F7941BA6721F333DD8 3FF941B8ED42E9137B13710ADFF0FD6450C67B0F2A7F LOCK_DATA_113=72245ADE4949001F591DB1AFE1D3E05828DF F197A0AC6D21287E5B8C1D24ABB1214AF9913C00512A LOCK_DATA_114=BAD4EE86466CE57AC4F799E6937B6C8561B2 F1DB701A3DF97A9603FE39F83AB31BA9CFC51ECF444B LOCK_DATA_115=C10751CD8814DF85EBB922B5EB104380D533 B6917150E159553339CE7A14BFDDDFC9E5404DB9E3CC LOCK_DATA_116=C8B81F9F9D662B890E5D48C870BABAEEA9C2 44B67F792E8B1606F9F48377F36D9C953303986CA3A7 LOCK_DATA_117=E726A558F351458A8E392FFC055235FB2148 D8917CDF4EB78AC70DE42E46D5F6585B4FB4D2D58C3B LOCK_DATA_118=F486459A2610C4E7CFD3723E80F05B56FAF0 CBD8A4B7CC005DC41182F84031326A65BCA54F356BE1 LOCK_DATA_119=C5CDD6800D83D031D9DA6359B477188E506F D808DABD0B49592580F11455F9DEA708E4E08B7BE679 LOCK_DATA_120=B3033FF443140E2C34801E1292299416402D E9FD8DD24EC36CC1CA4E92B5A9D2CD9F8985FD6D2C5C LOCK_DATA_121=01A5C880EC2C0E2BE8B660E9B77444C17BAB 97C28B4FFE886592429CBB05000F0F1E754A060EBE55 LOCK_DATA_122=80208F347A8BFD6EDCCAA7E714B9B931C9D1 E1CD005A22D174C7DC5457DCF4ACD098B7FDDE66A7E8 LOCK_DATA_123=15D6BDCFC800066E1AF7B731CFAC32CC77D5 88103D84E710521F1BB7E8403AE0D4F0D6BFFA2CCE98 LOCK_DATA_124=C713262CA25319AE44B347B98837624D23C7 5035E6E39C55FC781159306091A533070ED93FE41BD4 LOCK_DATA_125=3C831E5D7CA193CBCF037DBF8D909620C2C1 B1C70E3B44CCA04E07E08BDE95FF87D4401FC814108D LOCK_DATA_126=F78F5C74720CF29258F160861A0203B1002B 2FC1590B7FAE8E1BCAFB4C4AF282DCAD8B8792A4C065 LOCK_DATA_127=7F2D66B48290ADC0CF26AF21C3CFE29E1215 66DA368ECE5440C383B2B24367DB08EA1515D387C9C8 LOCK_DATA_128=511E39745BF4FAEAC318A4D7E424B3CECC93 0C3008515C86DB24C88BE8157E3D869D739F332FA49B LOCK_DATA_129=B2162A762026E58D73E01A41595BBBF398CA 033EA14F058FEF992817AC48A0B0FA99A1C7BB0C2584 LOCK_DATA_130=4805E307EE61D3BFB9F59BDD03EE98F4B6A3 BA215F6F5B75E13180C9464C84F22E18E65C79C99837 LOCK_DATA_131=F785F9BF25B23440B3A41E64938DDAEFB4EC 2254F9DBC011F01704A2A8899999C19BE9E341E9625E LOCK_DATA_132=6D0CC27CC2F2323C4B10B9806D872B81245C 7FCFF9FE7AB5858913118DB35DCA66AD8B10C5322447 LOCK_DATA_133=98ADDCB9B227125AAD566E3F2255475B1B90 62046DD639AA306974BAFE236C73701A64DA08D9442A LOCK_DATA_134=6EF548C4006FACE882263D9F00C48EDA35FA C9A8B340D7D7DA4160D042396138A24BB1687828CE59 LOCK_DATA_135=2BAE7C4C5F4D029D235B3041AD3E752F210A DB5603B18B8827A5D103E2146F422B8582DC16E0DA46 LOCK_DATA_136=2542A84611D0170000900200000300000002 000000AB0FBD96AF2AC271D26264AFDEAD07008E592F LOCK_DATA_137=7AEF23EFE72C0D6F1219980C1602AF9FAEAD EE1A2DC92D270D12335BCB5BDF32D2B41177CF16BE1A LOCK_DATA_138=FDA5178218E881AFF2A7390FC051275A3D80 CAD467881F379ECB6ED0027CB06D6EE3ADA702E5B1F9 LOCK_DATA_139=CF17330DE111E25194B91A2E50D81D6C728B A7D927F71F8290F838B0C4FA44216D40AE458978E89E LOCK_DATA_140=2DB47CC823E7B0AC65DBE9C34C44280965D9 176CFB552FB7A5F1A5CA58373CF6FE6053515FF79237 LOCK_DATA_141=915CDA6FC032011CB2DB1AC42984F3A50720 D6E7C48C18DAF4D15DEE596127E3A39A1D9A7242A414 LOCK_DATA_142=69294CDB2F5CC275F03F743822ACDB3B9150 43D623C6C3A98BB89EA542AD4D05D0B0F54D5F60B34C LOCK_DATA_143=66B1CC4649C10D422A9C8ACB8C3FD2499B65 19E4D9D62D0F8C8350BCA46EDC0A0735DEA5AD84E27F LOCK_DATA_144=EAB840A8286C082D704CCFAC0527FA040AC7 62C3F9990F818261A0AA24446651C5AE1E4868CCADFF LOCK_DATA_145=CD5A4AEDD725EC093707BB46BD00B13A5E9F 5AD37029D580E2AF4949D190F116AA7F1D62DF7D2C5D LOCK_DATA_146=85E41FC85D040C3D1D29C1D47A346C878B26 515AA0AE97F0EF4312E42CD3342D9913F58A0EFDC857 LOCK_DATA_147=5ED8C3B78F3C583B87F56D38501FBE3C3FE1 1364793DED887A8B2E5EE5F062E6498FFBC3D714EB05 LOCK_DATA_148=178358C53EC8EE71B5E1690DCF3F23B7CCE6 6E1E52F26D9D325F7B630B9759A33A29A5EA37A068A5 LOCK_DATA_149=7BB11D8C6BF66CC2B75C9717DC343154B9A6 9EA30FA43A77849D03C36F8FC654B9F5795B389321F4 LOCK_DATA_150=BBE3E27478BAAB9C21FD3CB2BB2855C079F1 13FC16E46F84D22023D346BA71CD6EFBFFE3F92735E4 LOCK_DATA_151=41C2AE9DA245AF12AA6584241862F949E2F0 26BCCA50E40BB263B96270DDEB485CFD2922ECCDB434 LOCK_DATA_152=B957CD887D8F5A97645A6C5B21A8F19D2586 50CB7477D9FC59E4996EB1E7F9174C54293732F772E5 LOCK_DATA_153=70804C958837AF0EF815BAF0456DF19BF4D5 D9D2F4B64FBD15B5CF7E38FFFFFFFFC0000000040000 LOCK_DATA_154=0002000000AB0FBD96AF2AC271D26264AFDE AD06001C630E6C1FE13007AC23DC171B1B026A56B1D1 LOCK_DATA_155=75FAA22C04A4822CF987785798DB56D1DBF6 0DD1A07F37EE093DE429D12D46542FFE6689616042E9 LOCK_DATA_156=E78362FA86149DBCDB2DA3767ADCCDD0820E 6875B7009DE587357F67F201A8499AAF5FC4FDE582B3 LOCK_DATA_157=AE6151D00D7022839F2B8277390451D9494A 5176967AEC40E2E82E0FAF878B173A4FD4E57DA76300 LOCK_DATA_158=F17D3DE90D570BF463553775A57D856FB01A E1BA4E5B67C9A7F9890750F543F18723E2AC0DAFC0F0 LOCK_DATA_159=EA25F9F633769844F281C6FDC33284310EA0 6979E3C709ECEE273CBF1A0000000000000000000000 LOCK_DATA_160=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_161=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_162=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_163=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_164=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_165=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_166=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_167=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_168=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_169=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_170=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_171=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_172=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_173=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_174=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_175=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_176=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_177=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_178=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_179=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_180=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_181=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_182=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_183=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_184=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_185=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_186=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_187=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_188=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_189=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_190=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_191=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_192=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_193=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_194=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_195=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_196=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_197=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_198=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_199=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_200=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_201=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_202=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_203=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_204=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_205=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_206=000000000000030001030004000107000500 0A313233343500000000000006000000070000000800 LOCK_DATA_207=010000090028000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_208=000000000000 BB_DATA_1=0135000900000004010000000001000201190002 000CFE05010002000000773300000004000C0101 BB_DATA_2=0100CD090000D35300000005000C020101000000 000046F901000007000C04020200950400000000 BB_DATA_3=00000008000C050303004F08D20F2A0100000011 000C0E06010000000000A32500000016000C1301 BB_DATA_4=010000000000204E0000 |
Z6m CDMA cellphone how to flash it? is in M logo only, please help first time on CMDA | Unlockemall | Scout | 4 | 11-06-2009 00:47 |
Mr.Manole please help... | GsmXplorer | Ultima Box Light | 3 | 08-15-2007 10:43 |
c115 logo erase please help | jrulli | Motorola ODM | 0 | 12-03-2005 05:36 |
