10-04-2009, 10:44 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: uae Age: 37
Member: 361731 Status: Offline Thanks Meter: 204 | N95 8 gb after flashing fone dead EM1 ID: 00000295 EM2 ID: 00000B22 PUBLIC ID: 0AD001125A75005207388439B974FA32DAC7E7C4 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0020 8804 - 0000 6B21 [ST 58LR128U,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.35.0 revision: 0.0 size: 0x272B0 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS is blank/erased. SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.39.0 revision: 0.0 size: 0x7B00 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 RX2 enabled. FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.52.0 revision: 0.0 size: 0x2DB80 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS is blank/erased. Total erase size: 123.00 MB CMT NOR area [00080000-007CF385] erased in 3.719 s CMT NOR area [00000000-0005FFFF] erased in 1.203 s CMT NOR area [00880000-00FDFFFF] erased in 1.547 s APE NAND area [00000200-0000AFFF] erased in 0.063 s APE NAND area [0000B800-000AFFFF] erased in 0.047 s APE NAND area [00000000-00000FFF] erased in 0.046 s APE NAND area [0000D800-0000E9FF] erased in 0.047 s APE NAND area [00080000-000BFFFF] erased in 0.047 s APE NAND area [000E0000-0045FFFF] erased in 0.063 s APE NAND area [004C0000-0073FFFF] erased in 0.062 s APE NAND area [00A40000-06F3FFFF] erased in 1.094 s Flash programming ... Selecting first PAPUB block with matching CMT RootKey CMT PAPUBKEYS, RAP Certificate 96 v1 written. Error chk C7012D0103CD000010000000B1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x000E0000, Result: 0010 Flashing terminated with error(s) in 39.375 s RX Buffer: C7012D0103CD000010000000B172 THANKS |
10-04-2009, 17:09 | #4 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | The software told already you the problem Error chk C7012D0103CD000010000000B1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x000E0000, Result: 0010 It is cable problem BR Alex |
10-04-2009, 18:24 | #5 (permalink) | |
Member: 361731 Status: Offline Thanks Meter: 204 | Quote:
thanks | |
10-04-2009, 19:06 | #8 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | Quote:
i have the same problem in n73 , dead after flash but now it's ok.My be it work for you. | |
09-23-2010, 14:46 | #11 (permalink) |
Junior Member Join Date: Jun 2010 Location: nepal
Member: 1330995 Status: Offline Sonork: 242456 Thanks Meter: 6 | NOKIA 6303 flash from 7 pin cable with mxkey.....and phone is dead ........showin this error plz any solution sir............................................... ............................... Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.899(24-06-2010), 1.0.0.1454(24-06-2010) Processing file: rm443__09.10.mcusw as MCU [BB5,BB5 ALGORITHM] size: 24.61 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C19211033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0960021608E0A5683B912C4B14C040B2E48C7FB ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCF6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF8F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: E8E6E2ABC2D394BC82633D2B4965E7E519E2FB2 TransmissionMode: DDR&TX2 Storing certificate [NPC, R&D, CCC, HWC] ...OK Erase size: 28.25 MB CMT NOR area [00000000-0001FFFF] erased in 0.781 s CMT NOR area [00040000-0005FFFF] erased in 0.141 s CMT NOR area [00060000-0007FFFF] erased in 0.140 s CMT NOR area [00080000-0015FFFF] erased in 3.578 s CMT NOR area [00160000-0023FFFF] erased in 0.297 s CMT NOR area [01740000-0191FFFF] erased in 9.578 s CMT NOR area [00240000-0173FFFF] erased in 1 min 1.406 s CMT NOR area [022E0000-0261FFFF] erased in 0.844 s Flash programming ... CMT PAPUBKEYS: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 (RAP Certificate 140 v.1) written. Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00CE0400, Result: 0010 Flashing terminated with error(s) in 3 min 31.875 s RX Buffer: C7012D0103CD000010000000F172 |
N79 RM-348 after flash fone dead? | Alexxxxxxxx | Nokia Base Band 5 ( BB-5 ) | 1 | 10-15-2009 18:31 |
3500c after flash fone dead?? | ~mr_Ten$ion~ | Nokia Base Band 5 ( BB-5 ) | 14 | 10-15-2009 10:47 |
Nokia N95 8 GB shows nothing after Davinci | majidaleem | Nokia Base Band 5 ( BB-5 ) | 2 | 03-28-2009 13:01 |
Nokia n95 8 gb no power on & not get flashing ... | irfanb20 | Nokia Hardware & Hardware Repair | 5 | 03-20-2009 11:17 |
