Old 02-11-2010, 08:47   #1 (permalink)
aao1308's Avatar
Member: 580020
Thanks Meter: 27
N95-8g : log ok but contact retailer ??!!
ApeVariant: 31.0.015, ApeTest: rm320_eno_Cust2008wk14updv0
ContentPack: RM320_020_000_M015
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 3568420xxxxxxxx
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
what can i do ?
Old 02-11-2010, 08:58   #2 (permalink)
aao1308's Avatar
Member: 580020
Thanks Meter: 27
and then when i made full rpl backup i got this log :
Reading RAP NPC (0x1B8 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Reading APE NPC (0x200 bytes).
Reading APE VARIANT (0x0 bytes).
Reading APE CCC (0x200 bytes).
Reading APE HWC (0x200 bytes).
Flash Imei: 3568420xxxxxxx
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
NPC_DATA saved OK
VARIANT_DATA is empty.
CCC_DATA saved OK
HWC_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA is empty.
WLAN_DATA saved OK
Old 02-11-2010, 09:11   #3 (permalink)
aao1308's Avatar
Member: 580020
Thanks Meter: 27
just another unlocker gave this log :
ST_SIM_LOCK_TEST : PASSED!
ST_SECURITY_TEST : FAILED!
SUPERDONGLE DATA : VALID!
who's right ?
Old 02-11-2010, 09:12   #4 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 388
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RF_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA is empty.
WLAN_DATA saved OK
Format file system
and post results
hope it works
Old 02-11-2010, 09:12   #5 (permalink)
Member: 241650
Thanks Meter: 71
MINE TOO.. IT STUCK ON NOKIA LOGO.. IT WAS MALFUNCTIONED (SIMLOCK DATA CORRUPTED) DUE TO UNLOCKING BY ZULEA'S CRACKED SOFTWARE.. I TRIED COUNTLESS TIMES TO FIX THIS PROBLEM.
HERE'S THE BB5 CERTIFICATE VALIDATION'S LOG:
Phone Type: RM-159 (Nokia N95)
SW Version: V 06wk41v59.1 02-06-08 RM-159 (c) Nokia
Imei plain: 35483501653192-4
Product Code: 0536086
ApeVariant: 30.0.01513.01
ApeTest: rm159_eno_2007wk16v0.220
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST passed
TimeStamp: 2007-07-20T15:16:27+03:00
SW Version: 12.0.013
Variant Version: 131
ProductProfile: RM159_0536086_12.0.013_131.spr
Simlock: simlock_3gstandard_bb5.bin
Imei net: 354835016531924
Counter: 0/3, 0/10
APE Data :
SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2]
ASIC MODE ID: 00
PUBLIC ID: 3162259FEB8AD1EC8013AA0A4C41A9F81F7E51D2
ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 15B00101CF6B0058B17AD9C374065821AE9CA828
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: A8C1D6713E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00
Supported APE Ids: 24200703, 24200704, 24200705, 24200706
FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE
ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG
Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248
APE PAPUBKEYS HASH: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
Original Product Code: 0547399
VARIANT empty !
Product Code: 0558372
Product Code missmatch !
Old 02-11-2010, 09:13   #6 (permalink)
Member: 391445
Sonork: 100.1583575
Thanks Meter: 388
who's right ?
well you need to do SX4 then write PM with filed 1, 135
use any tool for SX4
Old 02-11-2010, 09:18   #7 (permalink)
aao1308's Avatar
Member: 580020
Thanks Meter: 27
are you sure for pm 135 ? It seems very strange
Old 02-11-2010, 09:19   #8 (permalink)
Member: 762819
Thanks Meter: 232
No dear only RPL without NPC field and SD Repair and then Super SD Auth and then write full pm. Enjoy. Your problem will 100% solved.
Old 02-11-2010, 10:59   #9 (permalink)
aao1308's Avatar
Member: 580020
Thanks Meter: 27
now this what i get after following your advice
"SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST failed!
SIMLOCK_DATA corrupted!"
maybe there is a problem with cert which prevent from fixing other pb. What do you think ?
Nokia 6630 unlock ok but contact retailer prem2007 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 02-16-2010 06:07
n95 8g phone start-up failed contact the retailer sfeansfean Cyclonebox 3 01-09-2010 19:30
Nokia N95 8g PHONE START UP FAILED CONTACT THE RETAILER biscotte64 Nokia Base Band 5 ( BB-5 ) 9 08-22-2009 20:54
N95 8G Phone start-up failed.contact the retailer yx724 Nokia Base Band 5 ( BB-5 ) 4 04-30-2009 17:26
N95 8g phone start-up failed contact the retailer miguel_john1975 Nokia Base Band 5 ( BB-5 ) 15 04-13-2009 11:35
Page generated in 0.48002 seconds with 8 queries
