08-01-2010, 02:35 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 750497 Status: Offline Sonork: lohanpham Thanks Meter: 14 | N95 8gb can't sx4 to fix security test failed Phone Type: RM-320 (Nokia N95 8GB) SW Version: V 06wk41v64.20 01-10-09 RM-320 (c) Nokia Imei plain: 35294602091858-5 Product Code: 0561948 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 352946020918585 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 8EE1F4D7D4D5C66FABA0D87361AD69502F58DBB6 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1D700107E7540052DA438802BD93DA424E68B697 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 TransmissionMode: DDR&TX2 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Reading RAP NPC (0x1B8 bytes) Original Product Code: 0561948 Reading RAP VARIANT (0x0 bytes) VARIANT empty ! Reading RAP CCC (0x160 bytes) Product Code: 0561948 CCC seems to be valid Reading RAP HWC (0xD4 bytes) Product Code: 0561948 HWC seems to be valid LOG SUPER SD AUTH. SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Product: V 06wk41v64.20 01-10-09 RM-320 (c) Nokia Using cached productData[1D700107E7540052DA438802BD93DA424E68B697] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 1 (4 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 5 (4 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 15 (4 bytes) Warning: failed to write 1 - 16 (98 bytes) Warning: failed to write 1 - 18 (98 bytes) Warning: failed to write 1 - 20 (98 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 27 (4 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (98 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (80 bytes) Warning: failed to write 1 - 44 (182 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 0.641 s Anyone help me ? thanks |
08-01-2010, 02:44 | #3 (permalink) |
Member: 750497 Status: Offline Sonork: lohanpham Thanks Meter: 14 | just same with the modified PM , failed at section 1 & 309 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Product: V 06wk41v64.20 01-10-09 RM-320 (c) Nokia Using cached productData[1D700107E7540052DA438802BD93DA424E68B697] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 1 (4 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 5 (4 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 15 (4 bytes) Warning: failed to write 1 - 16 (98 bytes) Warning: failed to write 1 - 18 (98 bytes) Warning: failed to write 1 - 20 (98 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 27 (4 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (98 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (80 bytes) Warning: failed to write 1 - 44 (182 bytes) Section: 2 - Key: 0, size 440 bytes written. Section: 4 - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 9, size 5 bytes written. Section: 8 - Key: 0, size 12 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 128 bytes written. - Key: 4, size 8 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 8 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 16 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 2 bytes written. - Key: 8, size 2 bytes written. - Key: 9, size 2 bytes written. - Key: 10, size 2 bytes written. - Key: 11, size 2 bytes written. - Key: 12, size 1 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 1 bytes written. - Key: 15, size 1 bytes written. - Key: 16, size 1 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 1 bytes written. - Key: 19, size 2 bytes written. - Key: 20, size 2 bytes written. - Key: 21, size 1 bytes written. - Key: 22, size 1 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 1 bytes written. - Key: 30, size 1 bytes written. - Key: 31, size 1 bytes written. - Key: 32, size 1 bytes written. - Key: 33, size 1 bytes written. - Key: 34, size 1 bytes written. - Key: 35, size 1 bytes written. - Key: 36, size 1 bytes written. - Key: 37, size 1 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 4 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 1 bytes written. - Key: 47, size 16 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 20 bytes written. - Key: 51, size 10 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 20 bytes written. - Key: 54, size 10 bytes written. - Key: 55, size 1 bytes written. - Key: 56, size 1 bytes written. - Key: 57, size 1 bytes written. - Key: 58, size 1 bytes written. - Key: 59, size 1 bytes written. - Key: 60, size 1 bytes written. - Key: 61, size 1 bytes written. - Key: 62, size 1 bytes written. - Key: 63, size 1 bytes written. - Key: 64, size 1 bytes written. - Key: 65, size 1 bytes written. - Key: 66, size 32 bytes written. - Key: 67, size 32 bytes written. - Key: 68, size 2 bytes written. - Key: 69, size 2 bytes written. - Key: 70, size 2 bytes written. - Key: 71, size 2 bytes written. - Key: 72, size 2 bytes written. - Key: 73, size 2 bytes written. - Key: 74, size 2 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 2 bytes written. - Key: 79, size 2 bytes written. - Key: 80, size 2 bytes written. - Key: 81, size 2 bytes written. - Key: 82, size 2 bytes written. - Key: 83, size 2 bytes written. - Key: 84, size 2 bytes written. - Key: 85, size 2 bytes written. - Key: 86, size 2 bytes written. - Key: 87, size 2 bytes written. - Key: 88, size 2 bytes written. - Key: 89, size 2 bytes written. - Key: 90, size 2 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 2 bytes written. - Key: 93, size 2 bytes written. - Key: 94, size 2 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 2 bytes written. - Key: 97, size 2 bytes written. - Key: 98, size 2 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 2 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 2 bytes written. - Key: 103, size 2 bytes written. - Key: 104, size 2 bytes written. - Key: 105, size 2 bytes written. - Key: 106, size 2 bytes written. - Key: 107, size 2 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 2 bytes written. - Key: 110, size 2 bytes written. - Key: 111, size 2 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 2 bytes written. - Key: 114, size 2 bytes written. - Key: 115, size 2 bytes written. - Key: 116, size 4 bytes written. - Key: 117, size 4 bytes written. - Key: 118, size 1 bytes written. - Key: 119, size 4 bytes written. - Key: 120, size 4 bytes written. - Key: 121, size 4 bytes written. - Key: 122, size 4 bytes written. - Key: 123, size 16 bytes written. - Key: 124, size 4 bytes written. - Key: 125, size 2 bytes written. - Key: 126, size 2 bytes written. - Key: 127, size 1438 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 31 - Key: 4, size 26 bytes written. Section: 44 - Key: 0, size 1 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 79 bytes written. - Key: 2, size 79 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. - Key: 26, size 16 bytes written. Section: 117 - Key: 0, size 4 bytes written. - Key: 1, size 3 bytes written. - Key: 2, size 6 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 9 bytes written. - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 13, size 3 bytes written. - Key: 14, size 3 bytes written. - Key: 19, size 40 bytes written. - 120 skipped Section: 122 Warning: failed to write 122 - 0 (2 bytes) Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 208 - Key: 1, size 4 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 239 - Key: 0, size 2 bytes written. Warning: failed to write 239 - 1 (2785 bytes) Section: 291 Warning: failed to write 291 - 0 (92 bytes) - 308 skipped Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Section: 313 Warning: failed to write 313 - 0 (615 bytes) Section: 322 Warning: failed to write 322 - 0 (1 bytes) Section: 329 Warning: failed to write 329 - 0 (8392 bytes) Section: 334 - Key: 0, size 1 bytes written. Section: 341 - Key: 0, size 1 bytes written. - Key: 3, size 4 bytes written. Warning: failed to write 341 - 4 (4406 bytes) Section: 354 Warning: failed to write 354 - 0 (3 bytes) Section: 356 - Key: 0, size 2 bytes written. - Key: 1, size 8 bytes written. Completed in 24.422 s |
08-01-2010, 04:50 | #5 (permalink) |
No Life Poster Join Date: Oct 2004 Location: AL-SATWA DUBAI U.A.E Age: 45
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | Problem is in UFS Interface and Poor F-Bus Cable , Locel or Test Mode can't b stable on the Phone. The batter way is use JAF or ATF Interface and a good Quality F-Bus Cable. Always chack Interface Usb Cable. For SX4, Unlock and SL Data Repair of N95, N95 8gb and N96 ATF and UB are batter then Mx-Key |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
