12-03-2010, 02:49 | #1 (permalink) | ||
Freak Poster Join Date: Feb 2008 Location: Cavite,Philippines
Member: 710668 Status: Offline Thanks Meter: 119 | n95 8gb "PHONE START-UP FAILED CONTACT RETAILER".. (ANSWERED) is there anyway to fix n95 contact retailer... after RPL DATA back it show's: [QUOTE]Flash Imei: 35954201394948 NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK SUPERDONGLE_KEY_DATA saved OK WMDRM_PD_DATA saved OK NPC_DATA saved OK VARIANT_DATA is empty. CCC_DATA saved OK HWC_DATA saved OK RF_DATA saved OK PROD_DATA is empty. BT_DATA saved OK LOCK_DATA is empty. BB_DATA is empty. BUS check: Quote:
SELF TEST: Quote:
-rebuild imei -pmm auth ***but sofware say's access violation*** -sd repair -super sd auth(autorized) -write pm error again | ||
The Following User Says Thank You to nhoy'sbarage For This Useful Post: |
12-03-2010, 05:51 | #4 (permalink) |
No Life Poster Join Date: Nov 2007 Location: mobile solution
Member: 638416 Status: Offline Sonork: 100.1591787 Thanks Meter: 1,113 | 93 SECURITY N !failed ! pm auth then writ pm 1 109 solve your problem |
The Following User Says Thank You to .::kabir::. For This Useful Post: |
12-04-2010, 20:10 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | it's ok with all the green marked above. all you need is to calibrate it's eeprom. BB5 > Service > PM - do not load any pm. - tick 'Load RFBB from server' - do any auth, click 'Write' when authorization successfull. BR |
The Following 4 Users Say Thank You to gbluez For This Useful Post: |
