Old 02-24-2010, 06:16   #1 (permalink)
Gulshan_80's Avatar
Member: 230164
Sonork: 100.1592997
Thanks Meter: 110
N95 8gb rm-320 unlock error....
HI ALL
N95 8GB UNLOCK ERROR
I CHANGE AROUND 3 CABLES
BUT SAME ERROR
HERE IS LOG....
Imei net: 3520610XXXXXXXX
Version: SIMLOCK SERVER
Provider: Vodafone, Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2341500000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=LOCKED (MCC+MNC): 23415F, DATA=23415F
BLOCK 2: 1=LOCKED (MCC+MNC): 23415F, DATA=23415F
Backup already exist.
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
Product: V 06wk41v46.1 13-11-07 RM-320 (c) Nokia
ApeCoreSw: 15.0.015
Boot error: 02 FF 72 00
UPP not responding !
- Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar.
- Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables.
- On rare occasions phone might be damaged or dead. So, if possible, try with another phone.
THANKS IN ADVANCE
Old 02-24-2010, 06:21   #2 (permalink)
sandeephanda78's Avatar
Member: 330468
Sonork: 100.1587596
Thanks Meter: 121
bro remove camera and try unlock again if still not get success then remove display also and repeat unlocking hope it help u
wbr
sandeep
Old 02-24-2010, 06:22   #3 (permalink)
kmaxmax's Avatar
Member: 553000
Thanks Meter: 2,302
check ur cable with another box like JAF nd MT.....then post ur result.....
Old 02-24-2010, 06:35   #4 (permalink)
Member: 184668
Thanks Meter: 34
yes remove camera if not sucsses also remove lcd its 100% tested by me many times
br
The Following User Says Thank You to sman234 For This Useful Post:
Old 02-24-2010, 06:39   #5 (permalink)
Member: 1224463
Sonork: Kafi_ctg
Thanks Meter: 26
yeah i got the problem while unlocking n95 8gb.. what the problem with this set..?
Nokia N95 8GB RM-320 Unlock Fail via NCK Calculation [ Solved ] aslam870 Cyclonebox 6 02-12-2010 16:00
n95-8GB RM-320 after unlock with Zulea 2.01 Contact Retailer, i have back ups... but! Boshko_Alfa Nokia Base Band 5 ( BB-5 ) 7 09-15-2009 08:40
n95 8gb rm-320 unlock free or? anam120 Nokia Base Band 5 ( BB-5 ) 5 07-07-2009 16:38
.:Nokia N95-8gb Rm-320 Unlock :. billal1050 JAF No Tp Unlocker by Cinek 6 02-20-2009 14:20
Page generated in 0.13663 seconds with 10 queries
