Old 02-05-2010, 16:59   #1 (permalink)
amit_deswal22's Avatar
Member: 778346
Thanks Meter: 33
n95 8gb sim lock repair failed
n95 rm-421 simlock data curpt
how to repair i tried but failed pls help
SIMLOCK_DATA corrupted!
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 06wk41v51.4 04-03-08 RM-421 (c) Nokia
ApeCoreSw: 11.2.011
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: A8C1D6713E691FF8
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SIMLOCK using security server ...
Connecting to server[main.mxkey.biz] ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
ERROR: something went wrong while receiving packet from server (c:1)!
Reading Simlock info ...
Old 02-05-2010, 17:42   #2 (permalink)
Member: 778346
Thanks Meter: 33
i try it unlocked by mx key
i try to unlock with mx key now sim lock ans sd data corrpt
pls help me how to solve it by mx key
i can it by ub but it needs 50 credit
Old 02-05-2010, 18:03   #3 (permalink)
Member: 778346
Thanks Meter: 33
i tried a lot
pls check where is problem
Completed in 9.078 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-421__SIM.RPL"
Updating SIMLOCK...OK
still SIMLOCK_DATA corrupted!
Old 02-05-2010, 18:09   #4 (permalink)
Member: 1170390
Thanks Meter: 2
use ub write pm then unlock
Old 02-05-2010, 18:16   #5 (permalink)
Member: 778346
Thanks Meter: 33
which pm
that is or another with pm auth or not pls help
Old 02-05-2010, 19:58   #6 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,774
can u post with details log info
seem like IMEI reset.
br,
Old 02-06-2010, 06:50   #7 (permalink)
Member: 778346
Thanks Meter: 33
br,
Phone Type: RM-421 (Nokia N95 8GB)
SW Version: V 06wk41v51.4 04-03-08 RM-421 (c) Nokia
Imei plain: 35294602234830-2
Product Code: 0564753
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
pls help how to repair simlock
Old 02-06-2010, 07:10   #8 (permalink)
Member: 778346
Thanks Meter: 33
br,
here is bus check log
APE Data :
SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2]
ASIC MODE ID: 00
PUBLIC ID: D92843798BB3A8F1C96B6C4A8E4FD714CA6FDE4C
ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1DD00010656B0052E4C20F016B5F38FFE0ADF4B1
ASIC MODE ID: 00
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4
SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00
Supported APE Ids: 24200703, 24200704, 24200705, 24200706
FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE
ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG
Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248
APE PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4
Original Imei: 35294602234830
Original Product code: 0564753
Bluetooth ID: 0022669F134E
WLAN ID: 002266AB484E
Language Pack:
- not available.
SIMLOCK invalid!
Old 02-07-2010, 10:01   #9 (permalink)
Member: 778346
Thanks Meter: 33
no reply
after long time
i use cylone to repair sim lock now set ok
Old 02-07-2010, 13:12   #10 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,774
u need 2 step repair
1.SIMLOCK ( with SIMLOCK RPL )
2.SUPERDONGLE repair
if not luck,try with erase metods before flashing
br,
Old 02-07-2010, 13:21   #11 (permalink)
mujahid_ali's Avatar
Member: 547967
Thanks Meter: 646
br,
Hello
before erasing get complete RPL backup so that can restore IMEI after flash
do as Mobilex-Team said that is a good solution.
Thanxs
Sim lock test fail, how repair ? ravi mobile MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 02-05-2010 11:43
N95-8GB Sim Lock data Repaired!!! Jr Telecom MT-BOX 11 08-03-2009 22:35
N95 8GB Sim Card Locked! DevilToster Nokia Base Band 5 ( BB-5 ) 1 06-17-2009 12:13
n95 8gb sim card registation failed after unlock okrongly BB5 Box by D.K. 10 03-05-2009 23:47
n95 8gb PHONE START-UP FAILED cejer Nokia Base Band 5 ( BB-5 ) 10 06-27-2008 14:23
Page generated in 0.39783 seconds with 8 queries
