03-29-2010, 19:12 | #1 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 326941 Status: Offline Thanks Meter: 16 | N95 8GB Simlock Phone Type: RM-320 (Nokia N95 8GB) SW Version: V 06wk41v64.1 26-09-08 RM-320 (c) Nokia Imei plain: 35698301558008-4 Product Code: 0557135 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! |
03-29-2010, 19:15 | #2 (permalink) |
No Life Poster Join Date: Nov 2005 Location: ABouSHaDy Age: 48
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | use search u can repair it with free alertdy posted here 1:Connect ur mobile and press scan botton. 2:Click on SERVICES. 3:Goto IMEI & SECURITY tab. 4:Click on SIMLOCK in left hand. 5:Put a tick mark in Make SIMLOCK RPL 6:and click Update SpLock or try exemple Info regarding superdongle + security test failed -------------------------------------------------------------------------------- Info regarding 1. SuperDongle Repair 2. Security Test Failed 1. SUPERDONGLE REPAIR SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed in this case a.press repair Super Dongle b.than SD Auth PM c.than good pm including fields pm1 and pm309 2. SuperDongle repair (case2) SIMLOCK passed! SUPERDONGLE_KEY passed! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed a.press repair Super Dongle b.than SD Auth PM c.than good pm including fields pm1 and pm309 3. Security test Failed SIMLOCK passed! SUPERDONGLE_KEY passed! SIMLOCK_TEST passed SECURITY_TEST failed in this case no need to full erase than flash just in few steps u can do this a. first of all Do SX4 than PM1 and PM309 if no success than b. replace CCC and HWC cert of RPL from same model and write it back to ur phone than repeat the SX4 + pm process hope this will help u to sort out such errors br ABOUSHADY |
The Following User Says Thank You to ABOUSHADY For This Useful Post: |
03-29-2010, 19:45 | #3 (permalink) |
Member: 326941 Status: Offline Thanks Meter: 16 | 1:Connect ur mobile and press scan botton. 2:Click on SERVICES. 3:Goto IMEI & SECURITY tab. 4:Click on SIMLOCK in left hand. 5:Put a tick mark in Make SIMLOCK RPL 6:and click Update SpLock didn't work, any other ideas |
need help master manole n95-8gb write screen restart | haslyn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 03-30-2010 10:56 |
n95 8gb simlock damaged | biri26 | Cyclonebox | 1 | 01-27-2010 12:06 |
simlock invalid after unlock n95 8gb | gsmteknikk | Universalbox | 2 | 03-14-2009 22:01 |
how can i open simlock n95 8gb | jimmyyew | Universalbox | 5 | 06-21-2008 00:54 |
