06-17-2010, 18:27 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Afghanistan 0093786144898 Age: 37
Member: 938983 Status: Offline Sonork: 100.1585802 Thanks Meter: 102 | 2610b Unlocked success but now not Signal this is the log Phone Type: RH-87 (Nokia 2610) SW Version: V 07.04a 26-08-08 RH-87 (c) Nokia. Imei plain: 01168400758765-0 Imei OTP: 01168400758765 Product Code: 0567579 Cellular System: GSM ASIC ID: 0x3168, type: 11 Ppm Id: MCR Language Pack: - not available. Imei net: 01168400758765 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
06-17-2010, 18:51 | #2 (permalink) |
No Life Poster Join Date: Sep 2009
Member: 1128573 Status: Offline Thanks Meter: 242 | br. when u unlock , phone ask for mcu file same ver. ? or not ask ? how much service provider have in your country ? if more then one, u check one by one sim . if all fail. go reflash phone with same ver. wirte pm. again unlock. then reset all. post the result . thanks mahir ashab |
06-17-2010, 18:56 | #3 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Dhaka mirpur-1 Age: 38
Member: 577653 Status: Offline Thanks Meter: 235 | Quote:
06-21-2010, 13:30 | #6 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | No no if it is not a hardware problem than it can be only solved through patch file not through pm.I have faced this problem in many dct4 mobiles and only solved through patch file in jaf(Some time hwk failed through patch files).I recomand you to unlock it again through patch file.Search for RH-87 v7.4a patch file.If u failed than tell me i will uplopad it for you. REgards Last edited by zishhaider; 06-21-2010 at 13:36. |
06-29-2010, 13:05 | #12 (permalink) |
No Life Poster Join Date: Oct 2009 Location: NIGERIA
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | similar problem,pls help after unlocking,no network,i tried flashing but it says MCU ID NOT SUPPORTED,and the worst is that the phone cannot even power on now,what should i do |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
