Old 04-21-2010, 07:27   #1 (permalink)
Member: 578236
Thanks Meter: 31
5130xm Phone restart after flashing(Simlock Data corrupted)
First check like this
1ST BOOT : C0,07 [] [2.0.9.0]
RAPx ID : 000000010000022600010006030C192101033000
EM 1 ID : 00000296
EM 2 ID : 00000B22
RAPx PBID : 1F00011483135950FCD02A9FFB7ADD7E9AA84FFC
RAPx MODE : 00
RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
RAPx ROID : 273F6D55DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00898982-00008A31, Int NU48F512
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
CMT KSIG0 : 0C917F11196FDB7378C18EF7260698CA4489DCA0
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
INFO_2ND : APE Chip Absent
INFO_ALG : APE Chip Absent
Rebooting Mobile
phone can not be info(can be show only first line)
After flashing became this
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1F00011483135950FCD02A9FFB7ADD7E9AA84FFC
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Original Imei: 35932902202547
Original Product code: 0580023
Bluetooth ID: 00247D25BA4B
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 06.65 01-04-09 RM-495 (c) Nokia
Imei plain: 35932902202547-2
Product Code: 0580023
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Just back up only RPL (PM can not be read)
No any erase
How to solve this problem(Or just wait for Mxkey Last Update)
thanks in advance
Old 04-21-2010, 07:36   #2 (permalink)
swatdan's Avatar
Member: 514081
Thanks Meter: 82
Bead news ....
nokia 5130 is SL3 !!! NO simlock repair or unlock !!!
If you don`t have backup RPL with mx-key , only RPL by nokia work .
Search for RPL in you pc and write again in phone....
Never , i say NEVER ERASE the phone !
Have a nice day !!!
The Following User Says Thank You to swatdan For This Useful Post:
Old 04-21-2010, 07:38   #3 (permalink)
Member: 578236
Thanks Meter: 31
Originally Posted by jaleelkuttikkar View Post
wich file using to you flashing?
somthing file is wrrong
I flash with v6.65
thanks
Old 04-21-2010, 07:39   #4 (permalink)
Member: 578236
Thanks Meter: 31
Have a nice day !!!
I have back up it
I will try first(I don't know it can be write back during Simlock data corrupted)
thanks
Old 04-21-2010, 07:40   #5 (permalink)
swatdan's Avatar
Member: 514081
Thanks Meter: 82
Originally Posted by Liheng View Post
I flash with v6.65
thanks
And now work the phone.... post log pls !!!
Old 04-21-2010, 07:42   #6 (permalink)
swatdan's Avatar
Member: 514081
Thanks Meter: 82
RPL by mx-key
I have back up it
thanks
If you have backup RPL with MX-key , don`t matter if the phone is SL3 or another SL ....
Write RPL and everything will be ok !!!
POst log !!!
Old 04-21-2010, 07:52   #7 (permalink)
Member: 578236
Thanks Meter: 31
POst log !!!
Thanks you to All Friends
Now OK but phone stile Hane
I just reflash with V 7.90
Flash 7.90
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Storing certificate ...OK
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF]
CMT NOR area [000006C0-0001FFFF]
CMT NOR area [00040000-000BFFFF]
CMT NOR area [000C0000-0013FFFF]
CMT NOR area [00140000-0137FFFF]
CMT NOR area [01380000-0151FFFF]
erased in 1 min 28.031 s
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF]
erased in 36.453 s
Erase size: 34.00 MB
CMT NOR area [01DC0000-0215FFFF]
CMT NOR area [02160000-03FBFFFF]
erased in 1 min 21.359 s
Erase completed in 3 min 26.828 s
Flash programming ...
CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written.
Programming completed in 3 min 54.579 s
Flashing completed in 7 min 29.984 s
info
Version Info:
RFIC version: 06540601
DSP version: ICPR72_09w33
LCD version: SEIKO
PPM version: V 07.90 23-09-09 RM-495 (c) Nokia U
BT MCM version: 2222-302
Retu version: 16
Tahvo version: 22
Content Pack version: Content: u_blu V 07.90 23-09-09 RM-495 (c) Nokia
Product Info:
Production serial number: HEC215186
Module code: 0204024
Basic production code: 0567773
Long production SN: 0
Serial Numbers:
IMEI plain: 359329022025472
IMEI spare to net: 3A 95 23 09 22 20 45 07
IMEI SV to net: 33 95 23 09 22 20 45 47 F4
Other Info:
Model : Nokia 5130c-2 (Classic Phone)
CS type : GSM850/GSM900/GSM1800/GSM1900
BSI: 6.9 KOhm
Imei net: 359329022025472
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
check
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
SW Version: V 07.90 23-09-09 RM-495 (c) Nokia
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Counter: 0/3, 0/10
It is ok but the phone can be open just only nokia then white screen and off
Re Power on again (it is the same)
what problem with this phone (Hardware of Software?)
thanks in advance
Old 04-21-2010, 07:56   #8 (permalink)
Member: 578236
Thanks Meter: 31
I have change battery
remove MMC
Change LCD
Old 04-21-2010, 08:02   #9 (permalink)
Rhyan777's Avatar
Member: 893209
Thanks Meter: 274
Try FLASH AGAIN Bro..
Maybe you FLASH the UNIT w/MMC INSERTED..
Br,.
Rhyan777
The Following User Says Thank You to Rhyan777 For This Useful Post:
Old 04-21-2010, 08:32   #10 (permalink)
Member: 578236
Thanks Meter: 31
Every thing OK
Thanks you to all and Mxkey team specialy MANOLE
If no Mxkey , this phone will be dead
I try to remove every thing like MMC, change batter, remove Zink....
and the last Camera problem
Jus remove camera, it is OK
thanks to all again
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Page generated in 0.26554 seconds with 10 queries
