Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 03-10-2010, 17:54   #1 (permalink)
ramazoti10's Avatar
Member: 898887
Sonork: ramazoti
n95 rm320 help
Phone Type: RM-320
SW Version: V 06wk41v64.1 26-09-08 RM-320 (c) Nokia
Imei plain: 35195903302752-7
Product Code: 0558166
Language Pack:
- not available.
Imei net: 351959033027527
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Product: V 06wk41v64.1 26-09-08 RM-320 (c) Nokia
Using cached productData[1640000B067C0052F54CDDB0DF039D446A875BFA] ...
Calculating SUPERDONGLE using security server ...
Completed in 1.515 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-320_351959033027527_SIMSD.RPL"
Updating SUPERDONGLE_KEY ...OK
Updating SIMLOCK...OK
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized :)!
Writing PM from Node ...
Section: 1
Warning: failed to write 1 - 0 (114 bytes)
Warning: failed to write 1 - 1 (4 bytes)
Warning: failed to write 1 - 2 (98 bytes)
Warning: failed to write 1 - 4 (110 bytes)
Warning: failed to write 1 - 5 (4 bytes)
Warning: failed to write 1 - 6 (98 bytes)
Warning: failed to write 1 - 8 (110 bytes)
Warning: failed to write 1 - 13 (98 bytes)
Warning: failed to write 1 - 15 (4 bytes)
Warning: failed to write 1 - 16 (98 bytes)
Warning: failed to write 1 - 18 (98 bytes)
Warning: failed to write 1 - 20 (98 bytes)
Warning: failed to write 1 - 22 (16 bytes)
Warning: failed to write 1 - 23 (4 bytes)
Warning: failed to write 1 - 24 (84 bytes)
Warning: failed to write 1 - 25 (4 bytes)
Warning: failed to write 1 - 26 (110 bytes)
Warning: failed to write 1 - 27 (4 bytes)
Warning: failed to write 1 - 28 (98 bytes)
Warning: failed to write 1 - 29 (10 bytes)
Warning: failed to write 1 - 31 (98 bytes)
Warning: failed to write 1 - 33 (36 bytes)
Warning: failed to write 1 - 34 (80 bytes)
Warning: failed to write 1 - 44 (182 bytes)
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Warning: failed to write 309 - 22 (12 bytes)
Completed in 1.171 s
Old 03-10-2010, 17:55   #2 (permalink)
alasmmar's Avatar
Member: 231153
pls do it step by step
1_mxkey>serves>imei&securty>imei rebuild>repair sd
2_go to pm >click sd auth writ pm 1 and 309 and wait 2 mnt
3_full factory
Old 03-10-2010, 18:08   #3 (permalink)
Riz000's Avatar
Member: 777415
Sonork: 1589702
.::Solution for::. Security Test Fail .: HERE :.
SIMLOCK valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
how to solve this problem ?
1.
First of all u need good pm with SX4
( do SX4/super SX4 after that pm1 and pm309 )
2.
if not solved than
check CCC and HWC certificates
How to repair CCC and HWC certificates ?
backup RPL than open it in notepad
there u will see NPC data after that CCC data and HWC data
just replace CCC and HWC data with manole's uploaded clone RPL's ( of same model )
3.
if still not solved than
recover certificates ( go to service --> than imei & security --> than imei rebuild --> recover cert BUTTON )
4.
if still same than
Repair SL
REPAIR SD
SUPER SD AUTH
write PM1 and PM309
5.
if still same than
make RPL backup
full erase
than flash
than rpl
than Repair SL
than SD repair
than super AUTH
than PM
Old 03-10-2010, 18:17   #4 (permalink)
Y.P.Y's Avatar
Member: 1010502
Sonork: whats this?!
Backup only NPC Data
Reset NPC
Write PM Field309 & 1
Restore Only NPC Backup
The Following User Says Thank You to Y.P.Y For This Useful Post:
n95 rm320 help ramazoti10 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-10-2010 14:06
Please help for n95-rm320 no bleutooth houari Nokia Base Band 5 ( BB-5 ) 0 05-29-2009 19:04
please help with n95 rm320 flash farfour Chinese Miracle & PinFinder 18 05-12-2009 22:34
N95 RM320 Black from China restart problem F@RUK S Chinese Miracle & PinFinder 15 01-23-2009 15:23
N95 RM320 no power & no charge raptor3 Nokia Hardware & Hardware-Repair Area 2 07-30-2008 11:58
Page generated in 0.23347 seconds with 11 queries
