Old 02-04-2010, 13:57   #1 (permalink)
powerplay83's Avatar
Member: 753732
Thanks Meter: 252
Cant Repair Security Test Failed on N96 and 5800
i have Nokia N96 and 5800, both phones had SL Data Corrupted.
i have repaired by mxkey. ButNow the phones have SECURITY_TEST failed!
here is info of N96:
Phone Type: RM-247 (Nokia N96-1)
SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia
Imei plain: 35932002237556-1
Product Code: 0573319
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 359320022375561
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
i want write PM + Sx4 but get this error:
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 85.105.105.64
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
how to solve this problem??
Old 02-07-2010, 00:05   #2 (permalink)
Member: 382590
Thanks Meter: 41
I have same problem with Nokia N96,
please we need a solution for this problem.
Thanks.
Old 02-07-2010, 02:59   #3 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
litle bit spend time with searching button u will get
[MXKEY - INFO] !!! NEW magic button inside mxkey !!!
and
Just in case if Recovery via Server doesn't work.......
and
Repair SUPERDONGLE
br,
The Following 2 Users Say Thank You to Andra For This Useful Post:
Old 02-07-2010, 08:26   #4 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
Originally Posted by MobileEx-Team View Post
you are graet for mx-key tream
BR.
Old 02-07-2010, 09:28   #5 (permalink)
a38
Member: 1027249
Thanks Meter: 24
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
No SX4 Card found.
Download this:http://www.4shared.com/file/21598259..._failed_V.html
includes N96 and 5800
and if after writing follows the failure
then download these modified PM
but remember before writing the PM must write the RPL before
http://www.4shared.com/file/21605830...-Clan_gsm.html
Old 02-07-2010, 09:30   #6 (permalink)
sp2_1987's Avatar
Member: 994932
Sonork: sp2_1987
Thanks Meter: 21
You need to super sd auth then write good pm
Old 02-07-2010, 10:45   #7 (permalink)
Member: 135631
Thanks Meter: 26
5800d-1 SECURITY_TEST failed!
I also have not received 2 phones 5800d-1 and n70. SECURITY_TEST failed! This solution is not suitable for them.
However, the 7210, 5220 was successful
Old 02-07-2010, 19:07   #8 (permalink)
Member: 33296
Thanks Meter: 20
i am too have 5800d-1b with
SIMLOCK_TEST passed
Restarting phone ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
my 8600 (luna) repair ok and work fine
Old 02-07-2010, 19:58   #9 (permalink)
Member: 33296
Thanks Meter: 20
When do "BB5 sertificate validation":
RAP PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61
Reading RAP NPC (0x190 bytes)
Original Product Code: 0577454
Reading RAP VARIANT (0x0 bytes)
Reading RAP CCC (0x160 bytes)
Product Code: 0583430
Product Code missmatch !
Reading RAP HWC (0xD4 bytes)
Product Code: 0577218
how to change product code?
Old 02-08-2010, 06:38   #10 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
after
[MXKEY - SERVER UPDATE] Solved "Bad phones ack on step1" for so called "SL3"
please give report
br,
Old 02-08-2010, 14:52   #11 (permalink)
Member: 259110
Thanks Meter: 11
Hello i need some help here! i follow all these post but i still have the same problem security test failed, i check BB5 Certificate Validation and i get this:
Reading RAP NPC (0x1B8 bytes)
Original Product Code: 0543713
VARIANT empty !
Product Code: 0543727
HWC seems to be valid
please help me
Old 02-08-2010, 15:16   #12 (permalink)
rickliew's Avatar
Member: 522783
Thanks Meter: 62
hi,u can try this...
http://forum.gsmhosting.com/vbb/showthread.php?t=920409
Old 02-08-2010, 15:46   #13 (permalink)
Member: 259110
Thanks Meter: 11
Originally Posted by rickliew View Post
already try that! and nothing!!! still the same problem!!!
Old 02-08-2010, 16:06   #14 (permalink)
daroas's Avatar
Member: 194078
Sonork: no have
Thanks Meter: 209
i have one E63 RM-450 with the same problem...please help us how to solve this problem?!
Old 02-09-2010, 04:54   #15 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
VARIANT empty !
please help me
how about do "Super SD Auth"
write PM except [308]
what problem do you have ?
where the log ?
br,
N96 screen flickers after repair security test failed., Some solutions to this proble Hacker84 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 03-19-2010 22:53
I can't repair Security Test Failed on N96 gsmlife MXKEY Nokia Flasher and Unlocker (by Alim Hape) 19 02-08-2010 06:44
Solution to repair Security Test Failed fretburner MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 02-07-2010 04:16
after sd repair SECURITY TEST failed mobitechnepal MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-04-2010 08:41
Post sucessfull SD Repair + Security Test Failed cel_phon MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-04-2010 06:51
Page generated in 0.34744 seconds with 10 queries
