Old 07-06-2010, 14:13   #1 (permalink)
decentevil's Avatar
Member: 691960
Sonork: 100.1592294
Thanks Meter: 145
n95 super sd auth prblem
m facing this prblem plz need urgent help ...............
ERROR reading PM, please make retry
i have tried too many time but n vain............
Old 07-06-2010, 14:22   #2 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
Wich metod u use in make pmm auth..............?
You try in tick load rfbb from server and press store rfbb to server then write
Old 07-06-2010, 15:54   #3 (permalink)
decentevil's Avatar
Member: 691960
Sonork: 100.1592294
Thanks Meter: 145
bro tried result (Access violation at address 03CCC41A. Read of address 00000000.)
Old 07-06-2010, 22:35   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
you need good cable , stable in LOCAL / TEST MODE
br,
Old 07-07-2010, 07:47   #5 (permalink)
decentevil's Avatar
Member: 691960
Sonork: 100.1592294
Thanks Meter: 145
br,
bro cable is 1000% ok i have 2 gpg cables and in ordinary and 1 is GTi ...........
more help needed............
Old 07-08-2010, 02:47   #6 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
Just for your info, GPG cables are not using good resistor inside to put your phone
in LOCAL /TEST MODE. They are using cheap Chinese not tested resistors and
for this reason they are not good cables.
It is tested by MXKEY TEAM. They are selling to you just nice pictures.
Use IPMART or GlobalStar (marked as ATxxx) cables and you will have good results.
BR,
Manole
The Following User Says Thank You to MANOLE For This Useful Post:
SUPER UNLOCKERS UP AGAIN with a temporary address dira33 GSM Mobile Links 0 12-28-2001 03:27
WEBSITE SUPER UNLOCKERS dira33 GSM Mobile Links 2 12-28-2001 01:17
5110 hardware prblem ( battery drain fast) Fai555 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 07-09-2001 03:06
Blue LEDs in your Display SUPER! GM Nokia Hardware & Hardware Repair 0 06-25-2000 12:47
Page generated in 0.16375 seconds with 9 queries
