Old 06-14-2012, 00:02   #1 (permalink)
Member: 269126
Sonork: 100.1616382
Thanks Meter: 370
Arrow N96 dead after flash with 33.033
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C085458E
Using device: USB ROM and HTI, FW ver: 00.50, SN: 000001F0
Connection status: EHCI:HUB:HUB::USB 2.00 (High-speed)
Driver: nmwcdnsucx64, ver: 7.1.32.75
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
Processing MCU file: RM-247_30.101_prd.core.fpsx
[BB5,XSR 1.5,BB5,N8815 ALG STNFMS] size: 97.34 MB
Supported Ids: 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101031103, 400C192101031103, 4003192101021103, 400C192101021103, 4003192101051103, 400C192101051103
Supported Ids: 008815C1, 008815D0, 008815D1, 008815D2, 008815D3
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
APE SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x]
APE ASIC MODE ID: 00
APE PUBLIC ID: 9D072B12C0840C29EB79B50DF643323774B7F52A
APE ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35
APE ROM ID: 137A9A3B33259D2C
Loading secondary boot code
SecondaryBoot: STn8815_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x98C0
Supported Ids: 008815C1, 008815D0, 008815D1, 008815D3
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:APE
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:APE
Storage2: 0020 00B1 - 0000 0000 [ST 1Gb NAND,1 Gbits] type: FLASH,MuxOneNAND, asic:APE
Loading update server data
Algorithm: STn8815_STNFMS_alg.fg [N8815 ALG STNFMS] version: 11.14.0 revision: 2.0 size: 0x5C21D
Update server code loaded.
ALIVE message received!
Im trying to flash with usb giveing just above option and flashing didnt start wht i do
Old 06-14-2012, 04:53   #2 (permalink)
Member: 161280
Sonork: 100.1616990
Thanks Meter: 82
dir member use RJ 45 CABLE IF YOU DO NOT HAVE CABLE TRY TO MAKE IT YOUR SELF BY GOOGLE NOKIA N96 PINOUT
Old 06-14-2012, 12:22   #3 (permalink)
Member: 269126
Sonork: 100.1616382
Thanks Meter: 370
i hve flashed on fbus with mxbox and also try with usb?set only show white and switch off
Old 06-14-2012, 15:35   #4 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Hi,
Don't is MX BOX Problem this, but for N96 is OLD History, this fw that u want Flash have BUGs, have deaded more and more N96 when the Nokia get out this fw.
Try whith Original H3G 21.003 and u phone re-live after ceck if have any damaged area when repair and stop!!!
Can use also the fw 33.101, solve how other fw H3g, but NEVER USE THE FW 30.101, and if the phone is DEAD, use f/bus cable, no USB, how wont work w/o f/bus cables???, buy these if not have,
Allumts
Old 06-14-2012, 16:09   #5 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro. The only Solution for this Phone, Go to Service Tab>Quick Fix>Tick BB5 Rap3Nand Erase>Click Do Selected Job, now Check & post reply.
BR,
Zuber
Old 03-30-2013, 13:48   #6 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
BR,
Zuber
have same problem. when i want to quick fix, log give me this error message:
Not Supported, reason: this is not RAP3NAND phone !
how to solve? my nokia n96 doesnt power on.
br
Old 03-30-2013, 17:05   #7 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Post Buscheck Logs for assistance,
Follow Mxkey Rules: http://forum.gsmhosting.com/vbb/f550...ection-984366/
Cannot help without Logs.
BR,
ZUBER
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.25345 seconds with 10 queries
