Old 12-05-2009, 14:03   #1 (permalink)
Member: 436987
Thanks Meter: 22
n96 failed to get key!
nokia phone write and closes immediately
press repair sl then gives this error
Imei net: 3593200223*****
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Backup already exist.
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11447, Date: 25-11-2009
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
Sending SecondaryBoot(0x3AC0 bytes) ...OK
Sending PreLoader(0x2E4 bytes) ...OK
Sending ROM(0x190C bytes) ...OK
Sending SecurityBlock(0x2000 bytes) ...OK
Sending SimlockBinary(0x190 bytes) ...OK
Sending Certificate(0x1A20 bytes) ...OK
Calculating NCK using security server ...
Connecting to server[main.mxkey.biz] ...OK, Login ...
failed to get key!
Reading Simlock info ...
Counter: 0/3, 0/10
Old 12-05-2009, 14:44   #2 (permalink)
enzawigroup's Avatar
Member: 141363
Sonork: 100.1594362
Thanks Meter: 148
try to unlock it withe the old verg
bug in the new verg
br
Old 12-05-2009, 14:52   #3 (permalink)
Member: 436987
Thanks Meter: 22
bug in the new verg
br
The Phone shwo me Nokia Logo and switch off.
What sould i do??
Old 12-05-2009, 15:06   #4 (permalink)
Member: 436987
Thanks Meter: 22
ub self test
MCU Nokia Version: 1.126, and up to date.
SMCU Nokia Version: 1.44, and up to date.
Initializing phone...
Output power at Line1 3,67V is in range of: 4,00V ±10,0%
Phone powered.
Reading Info...
Soft Version: V ICPR72_09w13.2 Date: 19-05-09 Type: RM-247 (N96-1) Pack: (c) Nokia
Product code:
Product code:
WLAN MAC: 0022FC90AB81
Radio: GSM850 / GSM900 / GSM1800 / GSM1900 / WCDMA I / WCDMA VIII
Original IMEI: 356406-02-********
Production serial: 0
HW Version:
DSP Version: MC_4032_ICPR72_09w13
LCD Version:
APE ADSP Version:
SIMLock service: SIMLOCK SERVER [01000B07091C]
Profile bits: 8000000000000000
Simlock config: 0010100000000000
Invalid codes entered: 0 / 0
Block: 1; Lock: 1; State: Open; Data: 00101F
All locks are open.
Executing self tests...
Passed [03] ST_UEM_CBUS_IF_TEST
Passed [0C] ST_EAR_DATA_LOOP_TEST
Passed [0D] ST_SIM_CLK_LOOP_TEST
Passed [21] ST_SIM_IO_CTRL_LOOP_TEST
Passed [5D] ST_SIM_LOCK_TEST
Passed [5A] ST_SECURITY_TEST
Passed [02] ST_PWR_KEY_TEST
Passed [14] ST_CURRENT_CONS_TEST
Passed [3A] ST_BACKUP_BATT_TEST
Passed [60] ST_CMT_APE_WAKEUP_TEST
Passed [65] ST_HOOKINT_TEST
Passed [08] ST_BTEMP_TEST
Passed [6C] ST_MBUS_RX_TX_LOOP_TEST
Passed [38] ST_EXT_DEVICE_TEST
Passed [80] ST_CDSP_SLEEPCLK_FREQ_TEST
Passed [56] ST_CDSP_SLEEPCLOCK_FREQ_TEST
Passed [53] ST_CDSP_RF_BB_IF_TEST
Passed [55] ST_CDSP_RF_SUPPLY_TEST
Passed [4A] ST_CDSP_TX_IQ_TEST
Passed [52] ST_CDSP_TXC_DATA_TEST
Passed [4F] ST_CDSP_PWR_DETECTOR_BIAS_TEST
Passed [50] ST_CDSP_RX_PLL_PHASE_LOCK_TEST
Not executed [4B] ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Passed [51] ST_CDSP_WCDMA_TX_POWER_TEST
Passed [4D] ST_CDSP_RX_IQ_LOOP_BACK_TEST
Not executed [00] ST_CDSP_GSM_TX_POWER_TE
Old 12-05-2009, 15:40   #5 (permalink)
Cheater -Don't Deal with him-
Member: 635691
Sonork: 100.1592330
Thanks Meter: 137
Originally Posted by k-emal View Post
ub self test
Phone powered.
Reading Info...
Product code:
Product code:
HW Version:
LCD Version:
APE ADSP Version:
All locks are open.
all is ok, reflash it
Old 12-05-2009, 19:02   #6 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
Counter: 0/3, 0/10
failed to get key!
Counter: 0/3, 0/10
Mobile is already unlocked
Alex
The Following 3 Users Say Thank You to moulnisky For This Useful Post:
Old 12-05-2009, 22:51   #7 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
Alex, Tnx for posting in our section, i see you are doing a great job over this forum, specially in cyclone section.
But i still not understand something ... cyclone can not do good job for DCT4 unlocking and ppl are waiting for an update, cyclone is just a perfect copy of UB just a little cheaper box, even if is bad hardware, what for are you keep doing your job for this box ?
BR,
Manole
The Following User Says Thank You to MANOLE For This Useful Post:
Old 12-06-2009, 15:29   #8 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
But What About This
http://forum.gsmhosting.com/vbb/showthread.php?t=854256
UMER
fail to get key problem for unlocking n79/ n96 ashvin MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 10-29-2011 10:53
N85 failed to get key! rvs MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 01-05-2010 18:20
nokia 5800-d can not unlock failed to get key! m_tahir1 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 12-22-2009 17:23
Failed to Get key a38 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 12-10-2009 06:50
N96 unlock: Failed to get Lock Key (6, 5) [SOLVED] CooLer55555 Cyclonebox 38 09-11-2009 09:35
Page generated in 0.22881 seconds with 10 queries
