Old 10-07-2012, 14:54   #1 (permalink)
yusniel's Avatar
Member: 1537172
Thanks Meter: 65
Can I flash Nokia 6265 CDMA with HTI NokiaTool?
Hi, have one handset 6265 CDMA rm-66 and i want to flash, please tell me if i can use my hti to do this..... thanks in advance
Old 10-07-2012, 15:44   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Yes,
You can Flash it with Mxkey HTI Box.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 10-07-2012, 15:54   #3 (permalink)
yusniel's Avatar
Member: 1537172
Thanks Meter: 65
Could you tell me how to do this??
Old 10-07-2012, 16:29   #4 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
Search sticky thread.
BR.
Arsalan gsm2000.
Old 10-08-2012, 13:32   #5 (permalink)
yusniel's Avatar
Member: 1537172
Thanks Meter: 65
Yes i know, but always give me this error: here is the log:
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C081xxxx
Using device: HTI, FW ver: 00.50, SN: 0000xxxx
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14102(15-06-2012)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\02613718452_BACK.rpl) .
Processing MCU file: HL100V1100.nep
[TIKU BT2,TIKU ALGORITHM] size: 12.82 MB
Supported Ids: 1051, 1052, 2051
ASIC ID: 0x2051 [TikuEdge ver: 2.0]
SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398
FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M)
FlashID2: 0000 0001 [unused/removed]
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5
Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8
Performing Flash Authentication ...OK
UEM ID: 0002623D:3B8ADA60
Area [00000000-0001FFFF] erased in 0.771 s
Area [00020000-00DFFFFF] erased in 1 min 26.010 s
Flash programming ...
Programming completed in 1 min 41.271 s
File processed in 3 min 18.141 s
Processing CNT file: HL100_05w21_34_16_ANG01.image_ba
[TIKU BT2,TIKU MON CSM] size: 4.30 MB
Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660
Mass Memory Storage Device detected.
Configuring MM bus ...
Formating partition ...OK
Opening MM device ...
Erasing disks ...OK
Se agotó el tiempo de espera del semáforo
Error while programming [2E] at 0x00000020, Result: 0000
flashing terminated !
Old 10-09-2012, 18:46   #6 (permalink)
yusniel's Avatar
Member: 1537172
Thanks Meter: 65
Anybody knows solution
Old 10-09-2012, 19:21   #7 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
It's Hardware,
May be Physical Damaged PCB,
Try Reflow TIKU & surround must solve it.
BR,
ZUBER
Page generated in 0.17474 seconds with 9 queries
