03-08-2010, 14:39 | #1 (permalink) |
Banned Join Date: Jul 2009
Member: 1073809 Status: Offline Thanks Meter: 78 | n96 security test failed SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356406020585476 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
03-08-2010, 14:43 | #2 (permalink) |
Member: 1073809 Status: Offline Thanks Meter: 78 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Product: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia ApeCoreSw: 30.033 SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 91.98.8.80 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
03-08-2010, 14:44 | #3 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Sharjah Age: 42
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | Quote:
if failed repair sd first and then repeat the above process | |
03-08-2010, 14:46 | #5 (permalink) |
Member: 1073809 Status: Offline Thanks Meter: 78 | - Key: 25, size 132 bytes written. - Key: 26, size 12 bytes written. Section: 117 - Key: 0, size 4 bytes written. - Key: 1, size 3 bytes written. - Key: 2, size 6 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 9 bytes written. - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 8, size 42 bytes written. - Key: 13, size 3 bytes written. - Key: 14, size 3 bytes written. - Key: 16, size 40 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 208 - Key: 1, size 4 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 239 - Key: 0, size 2 bytes written. - Key: 1, size 3425 bytes written. - Key: 2, size 3425 bytes written. - Key: 3, size 3425 bytes written. - Key: 4, size 3425 bytes written. - Key: 6, size 222 bytes written. Section: 291 - Key: 0, size 92 bytes written. Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Section: 313 - Key: 0, size 615 bytes written. Section: 322 - Key: 0, size 1 bytes written. Section: 329 - Key: 0, size 8392 bytes written. Section: 334 - Key: 0, size 1 bytes written. Section: 341 - Key: 0, size 1 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 4514 bytes written. Section: 354 - Key: 0, size 33 bytes written. Completed in 15.016 s |
03-08-2010, 17:57 | #6 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: QQ:2557307931
Member: 1010502 Status: Offline Sonork: whats this?! Thanks Meter: 316 | Quote:
Use 3rd method: http://forum.gsmhosting.com/vbb/f550...lution-945309/ | |
The Following User Says Thank You to Y.P.Y For This Useful Post: |
03-08-2010, 18:02 | #7 (permalink) | ||
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
.::Solution for::. Security Test Fail .: HERE :. - GSM-Forum Quote:
03-08-2010, 22:28 | #9 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: (¯`». Catch Me If U Can .«´¯) Age: 35
Member: 553445 Status: Offline Sonork: 100.1585581 Thanks Meter: 8,184 | Quote:
Try This Method I Repair Many Phone 1: SX4 Auth 2: Write Full PM 3: Check ( Make SIMLOCK RPL ) & ( Repair SIMLOCK ) And Press Repair SPLOCK Button 4: Repair SD 5: SUPER SD Auth 6: Write Full PM It Is 100% Working Solution Waiting For Result | |
The Following 2 Users Say Thank You to nasirkhan007 For This Useful Post: |
05-11-2010, 09:17 | #11 (permalink) |
Junior Member Join Date: Apr 2010 Location: Pakistan
Member: 1278886 Status: Offline Thanks Meter: 19 | n96 phone start up failed plz tell me how can i solve this problem log is hear SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! |
05-11-2010, 09:33 | #12 (permalink) |
Member: 1278886 Status: Offline Thanks Meter: 19 | i solve the SIMLOCK_TEST failed! but SECURITY_TEST failed! not solve help me Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) APE Data : SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x] ASIC MODE ID: 00 PUBLIC ID: 756D94BC6C1D250F7A3E6E56D3C919057A9F79AF ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35 ROM ID: 137A9A3B33259D2C RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1DC0001017AE015895E4D253C3CCB873C1719AB7 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00 Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 FlashID0: 0020 00B1 - 0000 0000 [ST 1Gb NAND,1 Gbits] type: NAND,APE ALG [35]: N8815 ALG STNFMS Algorithm: nomadik8815_alg.fg [N8815 ALG STNFMS] version: 1.59.0 revision: 0.0 size: 0x37E78 Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 APE PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE Original Imei: 35640602183402 Original Product code: 0573063 Bluetooth ID: 0022FC82AA8A WLAN ID: 0022FC90662A Phone Type: RM-247 (Nokia N96) SW Version: V ICPR72_08w50.4 05-06-09 RM-247 (c) Nokia Imei plain: 35640602183402-2 Product Code: 0543727 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356406021834022 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following User Says Thank You to -=asad khan=- For This Useful Post: |
N96 Security Test Failed | adnann5 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 03-09-2010 14:36 |
Nokia N96 Rm247 still security test failed after sd repair --Last Update -- | ABGSM | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-11-2010 11:01 |
Cant Repair Security Test Failed on N96 and 5800 | powerplay83 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 23 | 02-09-2010 17:51 |
I can't repair Security Test Failed on N96 | gsmlife | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 19 | 02-08-2010 06:44 |
