02-15-2010, 06:04 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: mobile solution
Member: 638416 Status: Offline Sonork: 100.1591787 Thanks Meter: 1,113 | n96 SECURITY_TEST failed! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! |
The Following User Says Thank You to .::kabir::. For This Useful Post: |
02-15-2010, 06:14 | #5 (permalink) |
Member: 638416 Status: Offline Sonork: 100.1591787 Thanks Meter: 1,113 | pm auth Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 119.30.36.56 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request pm not write Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 4.485 s |
02-15-2010, 06:17 | #6 (permalink) |
Member: 638416 Status: Offline Sonork: 100.1591787 Thanks Meter: 1,113 | ccc+hwc write APE PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE NPC verified Ok. Updating CMT CCC ...OK Updating CMT HWC ...OK Certificate programmed successfully ! |
02-15-2010, 06:37 | #9 (permalink) |
Member: 638416 Status: Offline Sonork: 100.1591787 Thanks Meter: 1,113 | log Phone Type: RM-247 (Nokia N96-1) SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia Imei plain: 35932002295875-4 Product Code: 0543722 ApeCoreSw: 30.033 ApeVariant: 30.033, ApeTest: ENOSW_4032_PR11.0835_003 ApeProd: V 40.2009.25.xx PRD ContentPack: V 40.2009.25.xx PRD Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359320022958754 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-15-2010, 08:12 | #11 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
contact me on msn http://forum.gsmhosting.com/vbb/showthread.php?t=926798 | |
The Following User Says Thank You to hasnain For This Useful Post: |
02-19-2010, 04:48 | #12 (permalink) |
Member: 638416 Status: Offline Sonork: 100.1591787 Thanks Meter: 1,113 | repaier 100% thanks mx-key Phone Type: RM-247 (Nokia N96-1) SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia Imei plain: 35932002295875-4 Product Code: 0543727 ApeCoreSw: 30.033 ApeVariant: 30.033, 30.033.005.1, 30.033.098.1 ApeTest: ENOSW_4032_PR11.0835_003 ContentPack: V 40.2009.25.xx PRD Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359320022958754 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF JAF FLASHER INTERFACE disconnected. No interface connected please select interface and connect first ! |
04-17-2010, 11:38 | #15 (permalink) |
Banned Join Date: Feb 2010 Location: ..::: Inside ur Brain :::.. Age: 34
Member: 1237415 Status: Offline Thanks Meter: 26 | N96 security test failed.. Bro Jst Repair Superdongle key After Repair Superdongle do pm auth And Write Good PM Ur Phone Will Be Done... |
The Following User Says Thank You to shaikh_shoeb For This Useful Post: |
N96 rm-247 SECURITY_TEST failed! | GsmChina | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-08-2010 06:27 |
to manole n96 SECURITY_TEST failed!" no any Solution | zakryia | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-06-2010 12:17 |
Any Buddy repair SIMLOCK invalid!, SIMLOCK_TEST failed! or SECURITY_TEST failed! | mohit_kripalu01 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-06-2010 11:36 |
SECURITY_TEST failed!" and "warning: SD authorized but verify failed solution | ..::Rizwan::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-03-2010 15:58 |
SIMLOCK invalid!, SIMLOCK_TEST failed!, SECURITY_TEST failed! | Raven21 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 01-27-2010 08:15 |
