05-22-2013, 13:19 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. How can we give Answer or solution without any Logs, So please follow Mxkey Section Rules: http://forum.gsmhosting.com/vbb/f550...ection-984366/ Post Buscheck & Selftest Logs, What condition of Phone before Flash ? If you have Flash Phone with correct or Match Firmware of Product, then do Quick Fix, Tick Rap3NAND Erase & click Do Selected Job will solve it. BR, ZUBER |
05-22-2013, 13:48 | #3 (permalink) |
No Life Poster Join Date: Jun 2008 Location: dunja
Member: 786607 Status: Offline Thanks Meter: 66 | MXKEY [FT SCR2000 0], SN: Using device: USB ROM Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsucx64, ver: 7.1.32.115 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 21A000065C8100527E2C902778CCF3B41D9FCD06 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B584 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. Reading CMT NPC (0xFF bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0xFF bytes). Reading CMT HWC (0xFF bytes). Reading CMT R&D (0xFF bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia N97 USB Phonet, PORT_ID: 20EEE66C Verifying communication to device OK. Phone type: RM-505 (Nokia N97) SW version: V ICPR72_09w44.18 28-05-10 RM-505 (c) Nokia ApeCoreSw: v 22.0.110 Imei plain: 35822603088587-4 Product code: 0586701 Battery voltage: 3450 mV, current: 351 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358226030885874 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
05-22-2013, 14:18 | #4 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Go to Service Tab > Tick BB5 Rap3NAND Erase & Click Do Selected Job, If not solve, then try read all my points on above Post & reply it with Selftest. BR, ZUBER |
