03-18-2010, 10:11 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: pakistan Age: 34
Member: 294245 Status: Offline Sonork: 100.1602405 Thanks Meter: 115 | N97 security test failed[SOLVED] SW Version: V ICPR72_09w28.9 29-10-09 RM-505 (c) Nokia Imei plain: 35xxxxxxx5385-2 Product Code: 0576128 ApeCoreSw: v 20.0.027 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356064039953852 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF after write pm same |
The Following User Says Thank You to ayaz ali For This Useful Post: |
03-18-2010, 10:51 | #3 (permalink) |
Member: 294245 Status: Offline Sonork: 100.1602405 Thanks Meter: 115 | Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 116.71.173.5 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request and after this repair sd Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Product: V ICPR72_09w28.9 29-10-09 RM-505 (c) Nokia ApeCoreSw: v 20.0.027 SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 58.469 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-505_35xxxxxxx953852_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...error 0x1 |
04-08-2010, 16:41 | #8 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | log is same , when get this Quote:
http://forum.gsmhosting.com/vbb/5589275-post4.html br, | |
The Following User Says Thank You to Andra For This Useful Post: |
04-09-2010, 21:05 | #9 (permalink) | |
Freak Poster Join Date: Oct 2009
Member: 1138285 Status: Offline Thanks Meter: 14 | Quote:
B.R godhelpjun. | |
3120c rm-346 "CS" security test failed [solved (server update)] | i-Fixed | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 03-11-2011 15:02 |
nokia n76 sucussfully phonestartup failure solved .security test fail solved | manish_jain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 02-14-2011 06:55 |
Help with Nokia 3500 with security test failed? [ Solved ] | geovanny78 | Cyclonebox | 2 | 02-18-2010 00:27 |
7210c CONTACT SAERVICE security test failed [ Solved ] | jermaineyork | Cyclonebox | 4 | 02-04-2010 06:35 |
security test Fail nokia 5800 [SOLVED] | langin | Cyclonebox | 10 | 01-10-2010 22:34 |
