10-15-2012, 04:10 | #1 (permalink) |
Insane Poster Join Date: Aug 2009
Member: 1103450 Status: Offline Thanks Meter: 5 | mx sim problem |
10-15-2012, 06:14 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | Each MX-SIM have own serial number. This can be read with our software. Read all serials, make a firmware update and post in in this thread your MX-SIM serials. This way I can check if your MX-SIM are update in server or not. BR, Manole |
The Following User Says Thank You to MANOLE For This Useful Post: |
10-15-2012, 06:54 | #3 (permalink) |
Member: 1103450 Status: Offline Thanks Meter: 5 | i tried to update it...but when i connect it the message always no card found i tried all of the the 4 remaining mx sim same message i get...when i plug it in on iphone 4s even the accept and cancel message doesnt show up.......i was just able to use one piece of the mx sim on the set of 5...all the others doesnt work anymore....all of this doesnt work anymore a day after i open and use just one....need a solution on this please help..i'm afraid to open another set because it might happen again...i think the manufacturer should put one mx sim each plastic not 5 [IMG] Uploaded with ImageShack.us[/IMG] |
10-15-2012, 12:38 | #4 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | You uploaded a picture, I can not see this from China internet and I do not have my VPN on this new PC. And you do not write here anything about what reader you use and if this reader is installed correctly the drivers. Sorry, but I can not teach you how to install correctly this drivers, I can only tell you how to check. The most easy way to check if your reader have installed correctly is to take one operator SIM CARD and read with MX-SIM software. If this operation can not work, you can not read settings, then is mean you got a problem on your dongle drivers or your dongle malfunction. BR, Manole |
10-15-2012, 16:45 | #5 (permalink) |
Member: 1103450 Status: Offline Thanks Meter: 5 | i use the reader that i used when i use the only mx sim that work it only means that there is no problem with the computer or reader i guess the problem is with the mx sim because i where able to use it once ....now i open another set....like the 4 that doesnt work....another 5pcs doesnt work again........i need to return this....i think this are diffective mx sim.........only 1 work for the first 2 set that i bought the other 9 pcs doesnt work... |
10-15-2012, 19:08 | #6 (permalink) |
Member: 1103450 Status: Offline Thanks Meter: 5 | > Instance created. ======================= 11-10-2012:23:07:05 > Instance created. ======================= 11-10-2012:23:12:02 Using connection: COM6 Found: MX-SIM Serial: A0000640 FW version: 1.05 Settings: IMSI: 0100000 STK Menu: None [TASK]: Updating firmware [TASK]: Done. [TASK]: Update SIM settings [TASK]: Done. ============================================ Using connection: COM6 Found: MX-SIM Serial: A0000640 FW version: 1.05 Settings: IMSI: 0100000 STK Menu: None [TASK]: Update SIM settings [TASK]: Done. ============================================ > Instance destroyed. > Instance destroyed. > Instance created. ======================= 15-10-2012:10:59:13 > Instance destroyed. > Instance created. ======================= 15-10-2012:11:00:07 > Instance destroyed. > Instance created. ======================= 15-10-2012:11:01:08 > Instance destroyed. > Instance created. ======================= 15-10-2012:11:02:33 > Instance destroyed. > Instance created. ======================= 15-10-2012:13:45:00 > Instance destroyed. > Instance created. ======================= 15-10-2012:13:45:34 > Instance destroyed. > Instance created. ======================= 15-10-2012:13:46:43 > Instance destroyed. > Instance created. ======================= 16-10-2012:01:58:43 > Instance destroyed. > Instance created. ======================= 16-10-2012:02:00:27 > Instance destroyed. > Instance created. ======================= 16-10-2012:02:02:53 > Instance destroyed. > Instance created. ======================= 16-10-2012:02:03:33 > Instance destroyed. > Instance created. ======================= 16-10-2012:02:04:10 > Instance destroyed. this is the log txt that i got from the mx sim manager |
10-15-2012, 20:30 | #7 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | What software version you are using for make this ? Hope you use latest one 1.2 Because I can not see any update you did for this serial A0000640 in our servers, that is a problem from your side, MX-SIM are tested before sent out. So, me and you need to find the real problem, what is not MX-SIM hardware malfunction, what you think it is. BR, Manole |
