Old 01-02-2010, 15:00   #1 (permalink)
Member: 554531
Thanks Meter: 85
need help for 5130c
hello all master plz help. i got nokia 5130c contact service.first i make bakupboth pm and rpl. then flash with 6.94 and all new verson also but not turn on. when i write backup its show error.
RPL: "C:\mobileEx\3.3\data\backup\RPL\BB5_35521*****_BA CK.rpl"
Imei: 35521203*******
Restoring RF/BB DATA from backup ...
Error unable to detect product !
Updating WARRANTY ...error 0x0
Updating PROD ...error 0x0
Updating BT ...error 0x0
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0E20021349E07C56E319113AFE41F734A858A539
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Certificate programmed successfully !
Phone not responding !
Old 01-02-2010, 15:06   #2 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
FLASH WITH THIS VERSION rm495_CareDP_17.0_07.91.exe
WBR
sahil2000ind
Old 01-02-2010, 15:22   #3 (permalink)
Member: 554531
Thanks Meter: 85
WBR
sahil2000ind
but same
Old 01-02-2010, 15:28   #4 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
u need same product code
Old 01-02-2010, 15:31   #5 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
but same
show full info of ur set
Old 01-02-2010, 15:43   #6 (permalink)
AOA
Registered User
Member: 1166923
Thanks Meter: 77
v3.2 revision 5.0, Public-Release
Added, SAFE Erase routine while using 'Custom Flash Erase' on the 'Advance Page'
~ SAFE Erase will Protect PM Data from erase specially when doing 'Erase WHOLE flash'.
~ Usefull for recovering a DEAD phone without loosing SIMLOCK DATA
Try 'save erase' then flash v7.91 mcu & ppm only.
with best regards
Old 01-03-2010, 13:12   #7 (permalink)
Member: 554531
Thanks Meter: 85
with best regards
sir i already have full backup both rpl and pm. but set is water damage show i think rpl may be courrpted. because pm area 120 not found in pm.and also not found simlock data in rpl.
need help for active desk v2.01 for nokia 7650 PoTpOt GSM Programming & Reverse Engineering 0 03-18-2004 16:59
Need Help for Seem elements for active all language and Motorola Logo .... Mike Ho Motorola Old Legacy (EMMI) 0 06-14-2003 13:11
!!! HELP !!! I need help for unlock 922--FT4,1M:1803 KisaKot Infineon C16X M51 & ARM7 M52 BASED 3 07-25-2002 03:27
Need help for newest version for nokia3310 morci Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-14-2002 15:37
Page generated in 0.21570 seconds with 9 queries
