Old 03-07-2010, 04:26   #1 (permalink)
Member: 368987
Thanks Meter: 26
[Need Help]6730c Restart...
I try USB flashing because i dont have Fbus cable....
It completes on flashing and the "Test Mode" showing on the phone but the phone did not fix... The phone always restart....
Old 03-07-2010, 05:10   #2 (permalink)
Member: 368987
Thanks Meter: 26
Here's the logs....
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
Processing file: rm566_023.010_prd.core.fpsx as MCU
[BB5,XSR 1.6] size: 88.26 MB
Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 27880DCA
RAP SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1]
RAP EM0 ID: 00000C34
RAP EM1 ID: 00000C30
RAP PUBLIC ID: 1F20010B4D340344B59C97A232BD8BEBBFEC7846
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
RAP ROM ID: 3E273BF637BE26FA
[ADL] Loading CMT secondary boot code
SecondaryBoot: rapuv11_2nd.fg [BB5] version: 9.38.1 revision: 2.1 size: 0x3A40
Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
[ADL] Secondary boot loaded.
FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP
FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP
FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: ONENAND,RAP
[ADL] Loading CMT Update Server Data
Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 9.38.1 revision: 2.1 size: 0x7EE22
[ADL] Update Server code loaded.
[ADL] Verifying communication to device OK.
RAP PAPUBKEYS HASH: 397DCE210733C335E84BAD369EC893FCA06D1BC3
Storing certificate OK.
Partitioning....
Partitioning complete
Total erase size: 64.00 KB
Flash programming ...
CMT PAPUBKEYS: 397DCE210733C335E84BAD369EC893FCA06D1BC3 (RAP Certificate 210 v1) written.
Programming completed in 1 min 40.063 s
Processing file: rm566_023.010_05.01_Russian_prd.rofs2.fpsx as PPM
[BB5,XSR 1.6] size: 39.97 MB
Total erase size: 51.00 MB
Programming completed in 45.484 s
Processing file: rm566_023.010_C01.01_BLACK_prd.rofs3.fpsx as CNT
[BB5,XSR 1.6] size: 8.20 MB
Total erase size: 25.00 MB
Programming completed in 9.328 s
[ADL] Device found: nmwcdc\Nokia USB Generic, ID: 2A558E8
Flashing completed in 3 min 16.578 s
Phone Type:
SW Version:
Imei plain: -
Language Pack:
- not available.
Total time to process is 3 min 59.125 s
USB Pooling failed, phone not found !
But the phone still restart... Any solution?
Old 03-07-2010, 05:47   #3 (permalink)
naveedbutt's Avatar
Member: 1015336
Sonork: 100.1608410
Thanks Meter: 813
Originally Posted by dodzkie View Post
here's the logs....
library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
processing file: Rm566_023.010_prd.core.fpsx as mcu
[bb5,xsr 1.6] size: 88.26 mb
supported rap ids: 4003192102001104, 400c192102001104, 6003192102001104, 600c192102001104, 6003192102011104, 600c192102011104, 6003192102021104, 600c192102021104
make sure usb cable, battery and charger are removed from device.
insert usb cable,battery back to device.
insert charger or press phone's power button
waiting for usb device ...
[adl] pooling for adl device
[adl] device found: Nmwcdnsuc\nokia usb flashing generic, id: 27880dca
rap system asic id: 000000030000022600010007600c192102011104 [rapu ver: 1.1]
rap em0 id: 00000c34
rap em1 id: 00000c30
rap public id: 1f20010b4d340344b59c97a232bd8bebbfec7846
rap asic mode id: 00
rap root key hash: 25b977a055be9b5dec0c38a2a279c695
rap rom id: 3e273bf637be26fa
[adl] loading cmt secondary boot code
secondaryboot: Rapuv11_2nd.fg [bb5] version: 9.38.1 revision: 2.1 size: 0x3a40
supported rap ids: 4003192102001104, 400c192102001104, 6003192102001104, 600c192102001104, 6003192102011104, 600c192102011104, 6003192102021104, 600c192102021104, 6003192102031104, 600c192102031104
[adl] secondary boot loaded.
flashid0: 0020 0040 - 0000 0031 [st nand kat00f00ra] type: Nor,rap
flashid1: 0000 0001 - 0000 0000 [unused/removed] type: Nor,rap
flashid2: 0020 0040 - 0000 0031 [st nand kat00f00ra] type: Onenand,rap
[adl] loading cmt update server data
algorithm: Rapuv11_xsr17_alg.fg [xsr 1.6] version: 9.38.1 revision: 2.1 size: 0x7ee22
[adl] update server code loaded.
[adl] verifying communication to device ok.
rap papubkeys hash: 397dce210733c335e84bad369ec893fca06d1bc3
storing certificate ok.
partitioning....
partitioning complete
total erase size: 64.00 kb
flash programming ...
cmt papubkeys: 397dce210733c335e84bad369ec893fca06d1bc3 (rap certificate 210 v1) written.
programming completed in 1 min 40.063 s
processing file: Rm566_023.010_05.01_russian_prd.rofs2.fpsx as ppm
[bb5,xsr 1.6] size: 39.97 mb
total erase size: 51.00 mb
programming completed in 45.484 s
processing file: Rm566_023.010_c01.01_black_prd.rofs3.fpsx as cnt
[bb5,xsr 1.6] size: 8.20 mb
total erase size: 25.00 mb
programming completed in 9.328 s
[adl] device found: Nmwcdc\nokia usb generic, id: 2a558e8
flashing completed in 3 min 16.578 s
phone type:
sw version:
imei plain: -
language pack:
- not available.
total time to process is 3 min 59.125 s
usb pooling failed, phone not found !
but the phone still restart... Any solution?
your fone want is soper donge
but 6730 not sported any tool yet
The Following 3 Users Say Thank You to naveedbutt For This Useful Post:
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP FuriouS TeaM FuriousGold 66 08-27-2010 13:20
need help master manole n95-8gb write screen restart haslyn MXKEY Nokia Flasher and Unlocker (by Alim Hape) 15 03-30-2010 10:56
2700 flashing need help ngaia MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-29-2010 11:48
nokia masters need help.............. ANILMPLY Nokia Hardware & Hardware Repair 0 03-29-2010 10:48
Need help N70 Restart raseelmsm Nokia Base Band 5 ( BB-5 ) 1 09-23-2008 04:50
Page generated in 0.16418 seconds with 9 queries
