Old 04-06-2011, 10:34   #1 (permalink)
Member: 149041
Sonork: 100.114578
Thanks Meter: 61
need help to use MX-Key on Win7 (ANSWERED)
any member use win7
i have problem cant load model
is it need change load address??
Old 04-06-2011, 10:54   #2 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
hi i am using win 7 32 bit and no problem .....
treat as you use on win xp no changes ....
for add model you need to select product path....
Old 04-06-2011, 10:58   #3 (permalink)
Member: 149041
Sonork: 100.114578
Thanks Meter: 61
sorry i forget to let know im using Win7 64bit
show this error
Nokia USB ROM virtual device started
Market items is empty, please select the correct products path !
BB5 USB DEAD PHONE flashing protocol ready.
Old 04-06-2011, 11:02   #4 (permalink)
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
ok but no problem in 64 bit allsoo ........
if you have problem then contact me via ym!
Old 04-06-2011, 11:07   #5 (permalink)
Member: 149041
Sonork: 100.114578
Thanks Meter: 61
MSN can o not??
i only have use MSN
Old 04-06-2011, 11:09   #6 (permalink)
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
sry i don't have msn i have yahoo or soonark onley
Old 04-06-2011, 11:13   #7 (permalink)
MOURAD™'s Avatar
Member: 468587
Sonork: 100.1612429
Thanks Meter: 681
message very clear, just select correct path and no more problem.
Old 04-06-2011, 11:16   #8 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
-yes, you need to change it manualy. set it from 'Config' menu, point it to your product folder directory.
Old 04-06-2011, 13:49   #9 (permalink)
Member: 149041
Sonork: 100.114578
Thanks Meter: 61
Originally Posted by gbluez View Post
hi,
i try d but it not work cant select
Old 04-06-2011, 14:00   #10 (permalink)
Yash_npj's Avatar
Member: 580145
Sonork: 100.1627342
Thanks Meter: 50
I have faced that also i and i just reinstall the software. please check
nothing can cure this problem. check it
WBR
yash_npj
Old 04-06-2011, 14:00   #11 (permalink)
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
bro select product path .. and install phone data package on the selected path ....
or make folder and gibe name
like example :- you want rm-237 model in list then make folder and rename it rm-237 ...
Old 04-06-2011, 17:25   #12 (permalink)
MOURAD™'s Avatar
Member: 468587
Sonork: 100.1612429
Thanks Meter: 681
Re-read again http://forum.gsmhosting.com/vbb/f550...3/#post7165089
1- start mobilex application.
2- Choose correct interface (ATF-UFS...).
3- Start Nokia service tool.
4- Select Config.
5- Select Directory and choose correct path.
Hope its clear Now....
Old 04-07-2011, 06:56   #13 (permalink)
Member: 149041
Sonork: 100.114578
Thanks Meter: 61
4- Select Config.
i have try d but same also nothing can select also
Old 04-07-2011, 07:30   #14 (permalink)
huyanten's Avatar
Member: 184637
Thanks Meter: 25
you can config to my pic
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.31985 seconds with 11 queries
