Member: 1872544
Sonork: 100.1668612 Thanks Meter: 193 | nokia 501 hang logo solution by mx key NOKIA 501
HANG ON LOGO DONE BY MXKEY
HERE IS FULL DETAIL WITH SHOT & FLASH FILE LINK Quote:
MXKEY [FT SCR2000 0], SN: C0874E1A
Using device: USB ROM
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.84
Module ver: 1.0.0.21762(03-12-2014), Library ver: 1.0.0.14473(03-12-2014)
Processing MCU file: AE35FA95_rm902_14.0.6.mcusw.fpsx
[XG223,XG223_V0 ALG] size: 33.60 MB
Supported Ids: 00000C2016100040
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 00000C2016100040498A28099A28A03866139B00 [XGOLD 223]
CMT PUBLIC ID: E1CA02CFDB011941498A28099A28A03866139B00
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 125FC72605B5C4E48A9E0225084D2579
CMT ROM ID: 535882252F54C676
Loading CMT secondary boot code
SecondaryBoot: XG223_v11_usb2nd.fg [XG223] version: 12.30.1 revision: 4.0 size: 0x59C0
Supported Ids: 00000C2016000040, 00000C2016100040
Secondary boot loaded.
Loading CMT update server data
Algorithm: XG223_v11_usbalg.fg [XG223_V0 ALG] version: 12.30.1 revision: 4.0 size: 0x32338
Update server code loaded.
Initializing Update Server ...
Configuring Algorithm clients...
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x1B8 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x1E8 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35789805528718_CE RT.rpl"
CMT PAPUBKEYS HASH: 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Erase size: 40 MB
CMT FLASH,NOR area [40000000-4003FFFF]
CMT FLASH,NOR area [47E00000-47E3FFFF]
CMT FLASH,NOR area [40060000-426FFFFF]
CMT FLASH,NOR area [47E40000-47F1FFFF]
Flash programming ...
CMT ISSW block sent
CMT MEMSET block sent
CMT PRIMAPP block sent
CMT LOADER block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 7E4AA995 [] sent
CMT UPDAPP block sent
CMT MCUSW block sent
Programming completed in 22.297 s
Processing PPM file: 49A9662F_rm902_14.0.2_059R3P2_i1_240_02_452065.rof s.fpsx
[XG223,XG223_V0 ALG] size: 9.37 MB
Erase size: 17 MB
CMT FLASH,NOR area [42700000-437FFFFF] erased in 0.031 s
CMT PPM block sent
Programming completed in 6.063 s
Processing CNT file: DF6D9FE1_rm902_14.0.2_059R3P2_i1_240_02_452065.ima ge.fpsx
[XG223,XG223_V0 ALG] size: 30.75 MB
Erase size: 70 MB
CMT FLASH,NOR area [43800000-47DFFFFF] erased in 0.016 s
Programming completed in 19.953 s
Total time for flashing process(boot+erase+write) was 49.469 s
Waiting for device boot up ...
Device connected: nmwcdc\Nokia USB Phonet (), PORT_ID: 357898055287185
Verifying communication to device OK.
Phone type: RM-902 (501)
SW version: V 14.0.6 10-07-14 RM-902 (c) Nokia
Imei plain: 35789805528718-5
Product code: 059T1N4
Battery voltage: 3710 mV, current: 123 mA
Language Pack:
- not available.
SLPA ver[5]: PA_SIMLOC30 (20 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: 01035602006006, ver:
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_RM-902_357898055287185_14_09_15_125636_SIM.RPL"
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 357898055287185
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
| BR MP HUSSAIN |
