Old 02-06-2010, 07:01   #1 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
Question Need solution for For MX USER
Need solution for For MX USER Mr.Manole
need to fix this problem as soon as possible Solution for: "SECURITY_TEST failed!" and "warning: SD authorized but verify failed!" every MX USER are facing this type of problem
its very difficult to use this type of method
Originally Posted by MANOLE View Post
If after repair SD and/or Simlock (Super Dongle RPL and Simlock RPL upload) you get "SECURITY_TEST failed!" and/or "warning: SD authorized but verify failed!".
This is comming usually because some PM fields and/or RPL sections are missing from your phone (e.g. DRM keys, CCC, ...).
Solution 1 (easy way, maybe not work all time, depends how phone was damaged):
- write full PM from SAME phone model (product number) WITHOUT fields 1, 308, 309 (and WITHOUT field 120 for SL20 based phones)
- unplug/replug phone from JAF/UFS box
- make Simlock RPL repair
- make SD RPL repair
- make SUPER SX4 Auth then write PM1 and PM309
if still have problems, use Solution 2:
- backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL
- backup RPL from another working phone (same model) with SAME product code
- edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL
- backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM
- full erase flash chip (use erase file regarding flash chip size)
- flash phone (CMT, APE, ...)
- upload CLONE RPL
- upload ORIGINAL RPL
- write full CLONE PM without fields 1,120,308,309
Manole
we hope u think abt this n we hope we get solution for this soon Mr.manole
take a look on this
http://forum.gsmhosting.com/vbb/showthread.php?t=918928
http://forum.gsmhosting.com/vbb/showthread.php?t=920105
http://forum.gsmhosting.com/vbb/showthread.php?t=919822
http://forum.gsmhosting.com/vbb/showthread.php?t=918773
http://forum.gsmhosting.com/vbb/showthread.php?t=919677
http://forum.gsmhosting.com/vbb/showthread.php?t=919400
http://forum.gsmhosting.com/vbb/showthread.php?t=920076
http://forum.gsmhosting.com/vbb/showthread.php?t=918550
The Following User Says Thank You to akashub For This Useful Post:
Old 02-06-2010, 08:17   #2 (permalink)
Member: 1086393
Thanks Meter: 771
Yes we all Know this type of pb exist in this ver. Coder is working on it.. Wait till Monday
Video MAnual for all MX user akashub MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 06-10-2010 09:24
need solution for this by MX KEY akashub MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-09-2010 12:18
I need solution unlock for ZTE A316 hthongvn Wanted Products 5 01-11-2010 15:02
need solution for unlock e606 USER CODE Dood Wanted Products 2 02-11-2005 19:25
Page generated in 0.16479 seconds with 10 queries
