Old 02-13-2010, 18:37   #1 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
New update and ufs bug fix
thanks for update and bug in ufis fix if any one face again bug then try with this tric uninstall ufs setup and restart pc again install ufs setup and update device ur problem will be solve
tested by me
Riz000
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post:
Old 02-13-2010, 18:45   #2 (permalink)
Registered User
Member: 751390
Thanks Meter: 18
i'll try bro
thnx for trik....
Old 02-13-2010, 19:44   #3 (permalink)
Member: 68085
Thanks Meter: 5
not work for me, still same
Old 02-13-2010, 21:12   #4 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
not fixed for me always bugs
Old 02-13-2010, 21:54   #5 (permalink)
Crazy Poster
Member: 705245
Thanks Meter: 7
not fixed for me
log 7610
sing device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
ASIC ID: 0x1081 [UPP_WD2 ver: 3.1]
SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8
Supported Ids: 1080, 1081
FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
FlashID1: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF
FlashID2: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA
Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50
Performing Flash Authentication ...OK
UEM ID: 00453445:2984DA7E
ASIC type: 5
UEM Imei: 35570000137998
Flash Imei: 35570000137998
RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35570000137998_BA CK.rpl"
Processing file: RH51_52_67_68PE605220.C1 as MCU
[WD2 BT2,WD2 ALGORITHM] size: 24.51 MB
Supported Ids: 0082, 1081
BootLoader not responding, mostly RAM problem !
flashing terminated !
Flashing terminated with error(s) in 1 min 21.203 s
RX Buffer: D372
Old 02-13-2010, 22:59   #6 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
not tested not fixed simply
Old 02-13-2010, 23:32   #7 (permalink)
Member: 95613
Thanks Meter: 17
tested not work for mi broblem in dct4
29/05/2009 New Microbox Update Amoi Skype Bug Fixed samigsm78 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 11 06-04-2009 06:36
29/05/2009 New Microbox Update Amoi Skype Bug Fixed samigsm78 Service Products News & Updates 0 05-29-2009 22:21
New UPdate Samsung E250 direct Unlock Added And C180 Bug Fixed samigsm78 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 5 06-20-2008 11:00
Simens clip update, M50/M50 bug fix Raskal Griffin 1 09-03-2003 12:46
Page generated in 0.15301 seconds with 9 queries
