05-08-2011, 13:47 | #1 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 956453 Status: Offline Thanks Meter: 141 | UFS ERROR - Unexpected Exception: invalid Data Typ [100% SOLVED] Unexpected Exception: invalid Data Type For please repair this......... -uninstal -instal -empty file n remove driver.....regedit n device manager..... this problem not solved |
The Following 12 Users Say Thank You to toniyunk12 For This Useful Post: |
05-08-2011, 13:56 | #3 (permalink) |
No Life Poster Join Date: May 2010 Location: BaNgLaDeSh
Member: 1310148 Status: Offline Sonork: 100.1601928 Thanks Meter: 293 | I am also facing this problem just uninstall ufs suite & reinstall |
The Following 2 Users Say Thank You to Tarikul Islam For This Useful Post: |
05-08-2011, 13:59 | #4 (permalink) |
Member: 956453 Status: Offline Thanks Meter: 141 | ufs still work but any tab empty(hollow),but can clik/use...... open samsung or other fine but open dcxbb5 this problem show..... |
The Following 3 Users Say Thank You to toniyunk12 For This Useful Post: |
05-08-2011, 14:48 | #8 (permalink) | |
Member: 1310148 Status: Offline Sonork: 100.1601928 Thanks Meter: 293 | Quote:
No doubt this problem occur for mxkey update 2.1 If you Uninstall ufs setup & reinstall then ok. But when you again use mxkey then showing this problem again. Here i post from my experience. "Connect & Start menu invisible" | |
The Following User Says Thank You to Tarikul Islam For This Useful Post: |
05-08-2011, 14:52 | #9 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | YES THIS THIS IS THE PROBLEM DUE TO MX-KEY NEW SETUP FOR THE PAST 3-4 DAYS I ALSO FACE THIS PROBLEM JUST UNINSTALL UFS SUITE AND INSTALL IT AGAIN. PROBLEM WILL BE SOLVED TEMPERORILY BUT WHEN U AGAIN CONNECT MX-KEY WITH UFS IT WILL AGAIN GIVE ERROR WBR sahil2000ind |
The Following 6 Users Say Thank You to sahil2000ind For This Useful Post: |
05-08-2011, 16:54 | #10 (permalink) |
Member: 956453 Status: Offline Thanks Meter: 141 | but i'm confuse,i was uninstal,remove driver ufs(device manager),empty regedit ufs sarassoft,and instal again....and i'm not use mxkey....i'm open soon dctxbb5...still show error....and if open other ,like samsung ,sdbx..not show this error. please information and solution sir |
05-08-2011, 17:09 | #11 (permalink) | |
Banned Join Date: Sep 2009 Location: PM P L Z Age: 36
Member: 1116719 Status: Offline Thanks Meter: 542 | Quote:
give me id i see this error and fix br, ALi | |
The Following User Says Thank You to >>.123.<< For This Useful Post: |
05-08-2011, 17:19 | #14 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, yes this is driver crash, and nothing more. error already found on 1st day after 3.4 rev2.1 release since the coder and me are not using ufs suite anymore, so we didn't check it. (we just use the box, not the software) we are really sorry for this. will be solved on next release. BR ps. there is idiot who spreading this cheap gossip, please don't care about this stupid member. (see attachment) Last edited by gbluez; 05-08-2011 at 17:28. |
The Following 59 Users Say Thank You to gbluez For This Useful Post: |
05-24-2011, 03:58 | #15 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | We have located the cause of this problem. It's not about the drivers on installation. it's about registry that created by product folder setting on MXKEY. UFS doesn't accept our new method. So as a 'junior', we will revert to use old way on this. Your Quick Fix: run registry editor: HKLM > Software > Nokia Mobile Phones > Tss Shared > Common; - delete "REG_BIN" inside "InstPath" - edit "InstPath" permission on 'Users' : deny ALL. no need to un install or re install anything. BR Last edited by gbluez; 05-24-2011 at 04:05. |
The Following 23 Users Say Thank You to gbluez For This Useful Post: |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Cellular Data Suite Cables avaliable !!! | vingis | Main Sales Section | 0 | 11-02-1999 17:35 |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | nk.cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-14-1999 15:33 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
