07-06-2011, 08:39 | #1 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Nikia 3110c flashing problem.................(ANSWERED) Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Processing MCU file: rm237__07.30.mcusw [BB5,BB5 ALGORITHM] size: 14.49 MB Supported Ids: 0103192101001101, 010C192101001101 Storing certificate [NPC, VARIANT, R&D] ...OK Erase size: 16.37 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00020000-0007FFFF] CMT FLASH,NOR area [00080000-000DFFFF] CMT FLASH,NOR area [00100000-001FFFFF] CMT FLASH,NOR area [00200000-0031FFFF] CMT FLASH,NOR area [00320000-0105FFFF] CMT FLASH,NOR area [01060000-01067FFF] CMT FLASH,NOR area [01068000-0107FFFF] erased in 1 min 36.250 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: C0E691EA [RAP Certificate 66 v2] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT PMM_CONF block sent CMT SBIF_CONF block sent Programming completed in 1 min 17.344 s Processing PPM file: rm237__07.30.ppm_c [BB5,BB5 ALGORITHM] size: 3.75 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 4.62 MB CMT FLASH,NOR area [01080000-0151FFFF] erased in 21.562 s Flash programming ... Programming completed in 16.563 s Processing CNT file: rm237__07.30.image_c_tr_blue [BB5,BB5 ALGORITHM] page size: 64 K size: 3.69 MB Supported Ids: 0103192101001101, 010C192101001101 Converting UCP blocks to 128 K. Erase size: 10.75 MB CMT FLASH,NOR area [01520000-01FDFFFF] erased in 1 min 17.563 s Flash programming ... Programming completed in 16.188 s Total time for flashing process(boot+erase+write) was 5 min 21.375 s Phone not responding ! |
07-06-2011, 12:29 | #5 (permalink) |
Freak Poster Join Date: Feb 2011 Location: mumbai mira road Age: 51
Member: 1524461 Status: Offline Thanks Meter: 26 | some time it is hardware problem mostly flash ic problem. rehot flash ic. then flash in ufs if ui setting failed then format in ufs method. |
07-06-2011, 20:09 | #9 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Kathmandu,Nepal Age: 46
Member: 983663 Status: Offline Sonork: 100.1623270 Thanks Meter: 551 | give low heat to cpu and flash ic with very carefully,,,, then flash with hwk with this file > mcu 7.30 ,,, ppm 7.21 ,,,, cnt 7.21 select manually good luck |
07-07-2011, 21:31 | #10 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | - Quick Fix > BB5 downgrade fix. if still dead: - backup RAP, full erase, don't tick safe erase, reflash, if alive: restore imei, rebuild SL+SD, if still dead: check phone HW. BR |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
