Member: 665514
Sonork: 100.1618806 Thanks Meter: 325 | My Problem Solved My Problem Solved I Flashed C2-03 Quote:
MXKEY [FT SCR2000 0], SN: C0842478
Using device: USB ROM
Connection status: OHCI:HUB::USB 1.10 (Full-speed)
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3327FA29
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.46
EBL version: Quantum_Bootloader_10.46_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI: 35973604673946
IMEI_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35973604673946_ back.RPL"
Processing file: rm702__07.57.mcusw
Downloading item CODE:rm702__07.57.mcusw_ebl_psi.fls, num block: 4, size: 28 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.375 s
Erasing area 0x40040000-0x4005FFFE ...OK
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.703 s
Erasing area 0x40280000-0x41D3FFFE ...OK
Programming completed in 36.797 s
Checksum verified (0xCE42)
Processing file: rm702__07.57.ppm_mh1
Downloading item CUSTackage_mh1.ppm_ebl_psi.fls, num block: 1, size: 4.86 MB
Erasing area 0x41DC0000-0x4229B14A ...OK
Programming completed in 6.813 s
Checksum verified (0xDA8F)
Processing file: rm702__07.57.image_mh1_059P4Z9
Downloading item CUSTackage_mh1_059P4Z9.image.fls, num block: 1, size: 13.88 MB
Erasing area 0x424C0000-0x43E1FFFE ...OK
Programming completed in 19.125 s
Checksum verified (0xCAD3)
Total time for flashing process(boot+erase+write) was 7 min 41.125 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia C2-03 USB Phonet, PORT_ID: BA76FF6
Verifying communication to device OK.
Phone type: RM-702 (C2-03)
SW version: V 07.57 22-06-12 RM-702 (c) Nokia
Imei plain: 35973604673946-8
Product code: 059D463
Language Pack:
- not available.
Imei net: 35973604673946
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Thanks My Friend's |
