Old 03-03-2013, 16:27   #1 (permalink)
Crazy Poster
Member: 1605843
Thanks Meter: 7
Nokia 100 xgold flash without a LCD???
Is it possible to flash Nokia 100 ( xgold platform) without a LCD display ?
I have hard that Infineon Xgod patform base cpu s do not power on the phone when it detects there is no LCD connected or when there is broken LDC connected.
MX Box dose not detect the phone. LCD display is totally broken.
I want to know can I flash this kind of phones which has damaged LCD s????
Old 03-03-2013, 21:02   #2 (permalink)
Member: 1761678
Sonork: 100.1615439
Thanks Meter: 370
yes br its not matter display work or not
The Following User Says Thank You to tauheed9 For This Useful Post:
Old 03-04-2013, 06:32   #3 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,313
Yes bro, you can do this very easily.
Regards
amn32
The Following User Says Thank You to amn32 For This Useful Post:
Old 03-04-2013, 07:29   #4 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Even LCD broken or Remove from the working Phone,
Mxbox will detect it & will give full Info on Buscheck,
Only will show Unknown LCD on Selftest with all Logs OK,
So you can Flash it without problem.
Check LCD ways before fixing new LCD, if Flashing & Logs OK,
May be Print or Track of LCD on PCB is open while physical damage.
BR,
ZUBER
The Following 2 Users Say Thank You to .::ZUBER::. For This Useful Post:
Old 03-10-2013, 11:29   #5 (permalink)
Crazy Poster
Member: 1605843
Thanks Meter: 7
I could flashed it without a LCD
The problem was in the Fbus cable i thot that was a phone which dosent have a LCD.
Thanks all
This is a very grate forum.
I got so much knowledge from here. I m Very glad about every bod who involved to make this
Page generated in 0.13409 seconds with 8 queries
