Old 07-16-2012, 10:43   #1 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
Arrow nokia 101 flash terminated how to solve
ANY SOLUTION PLZ
Old 07-16-2012, 10:45   #2 (permalink)
Gsm.Universal's Avatar
Member: 1526738
Sonork: 100.1607644
Thanks Meter: 6,688
give me complete info
Old 07-16-2012, 10:46   #3 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
Phone type: RM-769
SW version: V 06.25 25-08-11 RM-769 (c) Nokia
Imei plain: 35975404279542-6
Product code: 059G7N6
Cellular system: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: IJ
Language Pack:
- not available.
Imei net: 35975404279542
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000040002
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 07-16-2012, 10:58   #4 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro. Don't use Flash File manually, Download complete Product Firmware with same code with FiRe Agent & Flash it, now post result.
BR,
Zuber
Old 07-16-2012, 11:23   #5 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
Zuber bro no have flash file with same code can u give me download target
Old 07-16-2012, 14:10   #6 (permalink)
solitaire09's Avatar
Member: 1687184
Sonork: 100.1621473
Thanks Meter: 24
use Navifirm
The Following User Says Thank You to solitaire09 For This Useful Post:
Old 07-16-2012, 15:25   #7 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Khalid Bro. @Solitaire09 has shown & i too checked your Product Firmware is present with latest Ver7.20 , so you can download & Flash with it will solve yours.
BR,
Zuber
Old 07-17-2012, 03:30   #8 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Phone type: RM-769
Ppm Id: IJ
Language Pack:
- not available.
Counter: 0/3, 0/10
So,
it's alive phone.
Press "Download" after phone scanned.
This will download the correct files for your attached phone.
AVOID load files manually.
The Following User Says Thank You to gbluez For This Useful Post:
Old 07-17-2012, 09:15   #9 (permalink)
Member: 1687184
Sonork: 100.1621473
Thanks Meter: 24
flash 101 according to product code
Backup already exists(C:\mobileEx\3.5\data\backup\XGOLD_RM-769_C4D45E837E895BC8_IMEI.back)
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C085****
Using device: HTI, FW ver: 00.50, SN: 0001****
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14203(16-07-2012)
Device synchronized.
CPU: XGOLD 110
 Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
 Boot mode: 0xCC
 EBL version major/minor: 10.24
 EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 00EC 2404 - 23280002 [Samsung K5N2833ATM,128 Mbits]
CFI information:
 Flash settings: 0/1, size: 0x01000000
 2 Block regions:
  255 x 0x00010000 = 0x00FF0000
  8 x 0x00002000 = 0x00010000
EBL ready !
Processing file: rm769_007.200
 Downloading item CODE:hw_f3_rm769_r07.200.fls, num block: 3, size: 5.58 MB
Erasing area 0x00000000-0x00005FFE ...OK
Programming completed in 0.609 s
Erasing area 0x00800000-0x00BEFFFE ...OK
Programming completed in 1 min 21.572 s
Erasing area 0x00C5D000-0x00DFB6FE ...OK
Programming completed in 32.963 s
Checksum verified (0x0C61)
Processing file: rm769_007.20me
 Downloading item CUST:hw_f3_rm769_007.20me.fls, num block: 1, size: 5.24 MB
Erasing area 0x00100000-0x0063D97E ...OK
Programming completed in 1 min 48.218 s
Checksum verified (0x73FF)
Processing file: rm7690_nai07.20me_nlt
 Downloading item CUST:hw_f3_rm7690_nai07.20me_nlt.fls, num block: 1, size: 670.95 KB
Erasing area 0x00E60000-0x00F06EBE ...OK
Programming completed in 13.354 s
Checksum verified (0x88B1)
Total time for flashing process(boot+erase+write) was 5 min 52.904 s
After Flash Processing ...
Reseting Factory Values OK.
Phone type: RM-769
SW version: V 07.20 30-03-12 RM-769 (c) Nokia
Imei plain: 35283805920332-0
Product code: 059H0D0
Ppm Id: ME
Language Pack:
- not available.
Imei net: 35283805920332
Counter: 0/3, 0/10
Restoring VCARD ...Error 0
OK.
Using GPG UFC PRO 2012 cable DCT-4F jig
Old 08-09-2012, 11:14   #10 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
today again customer come back with Nokia 101 same problem try with same product code but error flashing terminated any body face this type problem
Old 08-09-2012, 11:50   #11 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
Arrow
FLASH PROBLEM RESET PROBLEM
SHOW RESET SUCCESSFULLY BUT USER CODE UNKNOWN
Old 09-16-2012, 14:26   #12 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
give me any solution today i have one more this type
Old 09-16-2012, 20:12   #13 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Reset All & go to IMEI & Security > User Code > Click Read, Click Reset & insert 12345 Manually in Code Box, Click Write.
Move to Action Tab & again Click Reset All will work for you.
Something New for you.
BR,
ZUBER
Page generated in 0.26936 seconds with 10 queries
