10-01-2012, 15:57 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Karachi pakistan
Member: 1449003 Status: Offline Sonork: tariq (100.1603714) Thanks Meter: 38 | Nokia 110 not security code unlock.manole i always try with cyclone to remove security code but not remove with cyclone please help and Quick update we want please.manole |
10-01-2012, 20:51 | #2 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Asking for Security Code to @Manole, then Karwos, Who is Karwos here? I don't know anybody with this name here. Then asking with other Tool, So if want assistance, then post full Buscheck Logs of Mxkey with details of Problem. BR, ZUBER | |
10-01-2012, 22:04 | #3 (permalink) |
Member: 1449003 Status: Offline Sonork: tariq (100.1603714) Thanks Meter: 38 | Sorry by mistake i post.........but section is correct.....i have.........mx box and others... now i tell you my problem dear.....i have 110 nokia i want to remove security code.... how i can......simple reply.......me |
10-01-2012, 22:34 | #4 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. If using FBus can be done easily by Clicking Buscheck, Phone appears in Test Mode, Click Reset All & job done. If using USB then have to Flash, if Phone not appears in Test Mode after Buscheck to Reset All. Have to arrange Flash Files of it from External Links, Product not available in Care Suit, But with Caution. BR, ZUBER |
10-03-2012, 17:11 | #5 (permalink) |
Member: 1449003 Status: Offline Sonork: tariq (100.1603714) Thanks Meter: 38 | dear i have this cable auto test mode but cant.....remove and flash it....dear...with procedure... see this image test mode... |
10-03-2012, 21:52 | #7 (permalink) |
Member: 1449003 Status: Offline Sonork: tariq (100.1603714) Thanks Meter: 38 | my freind i told you i know its usb cable but not works....i already try to flash xgold series simply but its not xgold its infinion chip inside... |
11-16-2012, 07:46 | #9 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | Hi sir i am new user of mxbox kindly explain i also have this set for security code and a four pin usb cable i also face this problem the set is in already in test mode but and i select bb5 in tab but it could not read any info or always searching in usb mode what can i do please help ............. |
11-16-2012, 08:19 | #10 (permalink) |
Member: 158032 Status: Offline Thanks Meter: 331 | Here the the whole steps i done first connect mxbox then connect the phone with usb cable when set on test mode and detected nokia c2-00 usb phonet port press connect Using device: Nokia C2-00 USB Phonet Connection status: UHCI:HUB:USB 2.00 Full-speed Nokia C2-00 USB Phonet ready. Then select nokia service tool Generation BB5 Select model RM-827 Then press Scan button the set is already on test mode nothing happened then i press bus check MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087C522 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0100AE6C Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Aborting operation ... Waiting for USB ROM device ... Then always this box appear nokia usb Flashing the always done the three steps but noting please help what can i do i am waiting for your reply with thanks,,,, |
11-16-2012, 12:33 | #11 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: Bangladesh
Member: 1076772 Status: Offline Sonork: 100.1601881 Thanks Meter: 2,847 | Quote:
[IMG]http://3.bp.********.com/-29kblOBIG0o/UHZdbCnVACI/AAAAAAAACuI/cbleNrXE84g/s640/110flashed.jpg[/IMG] [IMG]http://2.bp.********.com/-BdeZ1puQc3k/UHZdsaJv-kI/AAAAAAAACuQ/pS2fnCRxXDc/s640/nokia+110+usb+pinout.jpg[/IMG] | |
The Following User Says Thank You to JONONItelecom™ For This Useful Post: |
11-16-2012, 18:49 | #12 (permalink) |
Member: 1449003 Status: Offline Sonork: tariq (100.1603714) Thanks Meter: 38 | help please how i make this cable.......and reply i have lots of mobiles who want remove code and error in software.... |
The Following User Says Thank You to power_zone For This Useful Post: |
11-22-2012, 14:19 | #14 (permalink) | |
Member: 158032 Status: Offline Thanks Meter: 331 | Thanks Quote:
Version Info: MCU SW version: V 03.04 20-04-12 RM-827 (c) Nokia HW version: 1100 RFIC version: 68 LCD version: TPO PPM version: V 03.04 20-04-12 RM-827 (c) Nokia M2 BT MCM version: 19b5-22012 Content Pack version: Content: m2_059N2R0 V 03.04 20-04-12 RM-827 (c) Nokia Bluetooth ID: E8 CB A1 70 CB 5C Product Info: Production serial number: B56D532AH Product code: 059N403 Module code: 0205081 Basic production code: 059K3X3 Product specific data: 000000000000000000000000000000000000 Long production SN: 0 Serial Numbers: IMEI plain: 353656053005601 IMEI spare to net: 3A 35 56 06 35 00 65 IMEI SV to net: 33 35 56 06 35 00 65 00 F2 Master code: 6277652557 Other Info: Model: Nokia 110 (Entry Phone) CS type: GSM900/GSM1800 Battery voltage: 5053 mV Battery current: 176 mA BSI: 7.2 KOhm Imei net: 35365605300560 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000004000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Nokia USB ROM disconnected. I am so happy because i am new user of this box so i don't know much about this product but it's the best I'm very thank full to u take care... | |
