Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2009
Member: 1051835 Status: Offline Sonork: 100.1594332 Thanks Meter: 514 | Nokia 110 (RM-827) Successfully Flashed Via USB With MXBOX MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C086CC02 Using device: USB ROM and HTI, FW ver: 00.50, SN: 010016AD Connection status: EHCI:HUB:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.49 EBL version: Quantum_Bootloader_10.49_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35325705000666 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35325705000666_ back.RPL" Processing file: rm827__03.04.mcusw Downloading item CODE:rm827__03.04.mcusw_ebl_psi.fls, num block: 4, size: 26 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.374 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.434 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.571 s Erasing area 0x40280000-0x41B3FFFE ...OK Programming completed in 35.332 s Checksum verified (0x74A0) Processing file: rm827__03.04.ppm_m4 Downloading item CUST ![]() Erasing area 0x41BC0000-0x41F40996 ...OK Programming completed in 5.141 s Checksum verified (0xA432) Processing file: rm827__03.04.image_m4_059N407 Downloading item CUST ![]() Erasing area 0x421C0000-0x43E1FFFE ...OK Programming completed in 19.868 s Checksum verified (0xED62) Total time for flashing process(boot+erase+write) was 7 min 12.327 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-00 USB Phonet, PORT_ID: 25263E7B Verifying communication to device OK. Phone type: RM-827 (Nokia 110) SW version: V 03.04 20-04-12 RM-827 (c) Nokia Imei plain: 35325705000666-6 Product code: 059N2R0 Battery voltage: 5054 mV, current: 177 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: M4 Language Pack: - not available. Camera config: NI00CS0000040C21AC67, ver: 004.032 Imei net: 35325705000666 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000004000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 0.117 s |
The Following User Says Thank You to ~The JoKeR~ For This Useful Post: |
![]() | #2 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2010 Location: Uganda
Member: 1340870 Status: Offline Sonork: 1611357 Thanks Meter: 99 | iwonder how you flashed it with usb Quote:
i wonder how you flashed this phone via usb when phone doesnt have usb port so can u pliz clarify on the way how you flashed this phone becoz it has no usb port. | |
The Following User Says Thank You to FREDDIE GTY For This Useful Post: |
![]() | #5 (permalink) | |||
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 45
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,262 | Quote:
FBus Cable with USB Socket instead of RJ45 already available in market, Have to Select Nokia USB ROM on Interface, So the Logs will be of USB Interface. BR, ZUBER | |||
![]() | #6 (permalink) | |
Keep it up, You can share this here too: http://forum.gsmhosting.com/vbb/f550...-mxkey-767051/ BR, ZUBER | |
![]() | #10 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 41
Member: 158032 Status: Offline Thanks Meter: 331 | Hi friends i need help my nokia 110 is not connected with mxbox i use nokia c2-00 USB phonet 1655D7F9 as interface but not success full the phone does not show any info always searching usb device i want to reset security code of it please help me how can i do it ??????????????? |
![]() | #11 (permalink) | |
But most of the Users facing problem with it, Better use FBus Cable available in Market. BR, ZUBER | |
![]() | #12 (permalink) |
Member: 158032 Status: Offline Thanks Meter: 331 | I try to search RJ45 cable in the market but it's not available in the whole market can u tell me that if we try to connect the wires with solder on pcb board then it can help us or not ?????? |
![]() | #13 (permalink) | |
Moderator ![]() Join Date: Dec 2010 Location: Malaysia
Member: 1464783 Status: Offline Thanks Meter: 1,054 | Quote:
you can buy from here Nokia 110 Flashing Cable - Nokia Fbus Cable - Cables BR Nizda Mobile | |
