Old 02-15-2014, 16:13   #1 (permalink)
Registered User
Member: 1179630
Sonork: 100.1644820
Thanks Meter: 80
Exclamation Nokia 110 SIMLOCK DATA CORRUPTED After Flash. Please Help.
Today I flashed Nokia 110 with mxkey. Before phone cant browse internet ( browser not open) after flash phone in "contact service"
Phone imei is ok. but "simlock data corrupted".
I try write RPL & PM (Mxkey auto backuped ) But no luck. how to fix this.
last week i flash nokia 110 with same firmware it worked fine.
Old 02-15-2014, 17:03   #2 (permalink)
Member: 1974720
Sonork: None
Thanks Meter: 2
you can try to unlock or flash higher version...............
The Following User Says Thank You to jhames88 For This Useful Post:
Old 02-15-2014, 17:37   #3 (permalink)
israrbjr's Avatar
Member: 748544
Sonork: 100.1601881
Thanks Meter: 173
Flash again with same product code
The Following User Says Thank You to israrbjr For This Useful Post:
Old 02-16-2014, 05:00   #4 (permalink)
Member: 2112499
Sonork: 100.1625182
Thanks Meter: 5
The Following User Says Thank You to kudalamahesh For This Useful Post:
Old 02-16-2014, 17:31   #5 (permalink)
Registered User
Member: 1179630
Sonork: 100.1644820
Thanks Meter: 80
I try all but no luck. flash meny times Product code is 059P7V8 no luck.
but not write PM file. Still i cant find 110 pm file.
Old 02-17-2014, 05:00   #6 (permalink)
Registered User
Member: 1179630
Sonork: 100.1644820
Thanks Meter: 80
MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: C0xxx
Using device: USB Phonet  and HTI, FW ver: 00.50, SN: 010xxxF0
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: nmwcdc, ver: 7.1.32.84
Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device synchronized.
CPU: XGOLD 213
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
 Boot mode: 0xCC
 EBL version major/minor: 10.37
 EBL version: Quantum_Bootloader_10.37_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 00EC 3012 - 23280002 [Samsung ]
CFI information:
 Flash settings: 0/1024, size: 0x04000000
 1 Block regions:
  512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI: 35413xxxxx20580
Updating IMEI ... OK
Updating HWC (059P7V8)... OK
Updating CCC (059P7V8)... OK
Waiting for device boot up ...
Device connected: nmwcdc\Nokia C2-00 USB Phonet, PORT_ID: 11F6C1DA
Verifying communication to device OK.
Phone type: RM-827 (Nokia 110)
SW version: V 03.33 28-09-12 RM-827 (c) Nokia
Imei plain: 3541320xxx058-4
Product code: 059P7V8
Battery voltage: 3801 mV, current: 130 mA
Cellular system: GSM
ASIC ID: 0x0000, type: 11
Ppm Id: S2
Language Pack:
- not available.
Master code: 7403724316
Camera config: NI00CS00000401022F03, ver: 010.009
SIMLOCK_DATA corrupted!
Writing PM from Node ...
Section: 4
 - Key: 1, size 800 bytes written.
 - Key: 3, size 10 bytes written.
 - Key: 4, size 8 bytes written.
 - Key: 5, size 8 bytes written.
 - Key: 6, size 8 bytes written.
 - Key: 9, size 5 bytes written.
 - Key: 18, size 80 bytes written.
 - Key: 19, size 4 bytes written.
 - Key: 26, size 132 bytes written.
 - Key: 28, size 2 bytes written.
Section: 8
 - Key: 0, size 2 bytes written.
 - Key: 1, size 16 bytes written.
 - Key: 2, size 16 bytes written.
 - Key: 3, size 128 bytes written.
 - Key: 4, size 128 bytes written.
 - Key: 8, size 8 bytes written.
 - Key: 9, size 8 bytes written.
 - Key: 10, size 32 bytes written.
 - Key: 11, size 4 bytes written.
 - Key: 12, size 4 bytes written.
Section: 11
 - Key: 0, size 4 bytes written.
 - Key: 1, size 4 bytes written.
 - Key: 2, size 4 bytes written.
 - Key: 3, size 4 bytes written.
 - Key: 4, size 241 bytes written.
Section: 13
 - Key: 0, size 1 byte written.
 - Key: 1, size 2 bytes written.
 - Key: 2, size 1 byte written.
 - Key: 3, size 2 bytes written.
 - Key: 4, size 1 byte written.
 - Key: 5, size 1 byte written.
 - Key: 6, size 1 byte written.
 - Key: 7, size 1 byte written.
 - Key: 8, size 2 bytes written.
 - Key: 9, size 1 byte written.
 - Key: 10, size 1 byte written.
 - Key: 11, size 48 bytes written.
 - Key: 13, size 1 byte written.
 - Key: 14, size 1 byte written.
 - Key: 15, size 886 bytes written.
 - Key: 16, size 2 bytes written.
 - Key: 17, size 1 byte written.
 - Key: 18, size 1 byte written.
 - Key: 19, size 8 bytes written.
 - Key: 20, size 1 byte written.
 - Key: 21, size 1 byte written.
 - Key: 22, size 1 byte written.
 - Key: 23, size 1 byte written.
 - Key: 24, size 1 byte written.
 - Key: 25, size 2 bytes written.
 - Key: 26, size 1 byte written.
 - Key: 27, size 1 byte written.
 - Key: 28, size 1 byte written.
 - Key: 29, size 1 byte written.
 - Key: 30, size 1 byte written.
 - Key: 31, size 1 byte written.
 - Key: 32, size 1 byte written.
 - Key: 33, size 1 byte written.
 - Key: 34, size 1 byte written.
 - Key: 35, size 1 byte written.
 - Key: 36, size 1 byte written.
 - Key: 37, size 4 bytes written.
 - Key: 38, size 1 byte written.
 - Key: 39, size 1 byte written.
 - Key: 40, size 1 byte written.
 - Key: 41, size 1 byte written.
 - Key: 42, size 4 bytes written.
 - Key: 43, size 4 bytes written.
 - Key: 44, size 1 byte written.
 - Key: 45, size 4 bytes written.
 - Key: 46, size 4 bytes written.
 - Key: 47, size 1 byte written.
 - Key: 48, size 4 bytes written.
 - Key: 49, size 1 byte written.
 - Key: 50, size 1 byte written.
 - Key: 51, size 1 byte written.
 - Key: 52, size 2 bytes written.
 - Key: 53, size 4 bytes written.
 - Key: 54, size 4 bytes written.
 - Key: 55, size 1 byte written.
 - Key: 56, size 1 byte written.
 - Key: 57, size 1 byte written.
 - Key: 58, size 2 bytes written.
 - Key: 59, size 1 byte written.
 - Key: 60, size 4 bytes written.
 - Key: 61, size 4 bytes written.
 - Key: 62, size 1 byte written.
 - Key: 63, size 4 bytes written.
 - Key: 64, size 4 bytes written.
 - Key: 65, size 1 byte written.
 - Key: 66, size 4 bytes written.
 - Key: 67, size 4 bytes written.
 - Key: 68, size 1 byte written.
 - Key: 69, size 1 byte written.
 - Key: 70, size 1 byte written.
 - Key: 71, size 4 bytes written.
 - Key: 72, size 4 bytes written.
 - Key: 73, size 1 byte written.
 - Key: 74, size 4 bytes written.
 - Key: 75, size 2 bytes written.
 - Key: 76, size 2 bytes written.
 - Key: 77, size 2 bytes written.
 - Key: 78, size 1 byte written.
 - Key: 79, size 1 byte written.
 - Key: 80, size 1 byte written.
 - Key: 81, size 1 byte written.
 - Key: 82, size 1 byte written.
 - Key: 83, size 2 bytes written.
 - Key: 84, size 1 byte written.
 - Key: 85, size 4 bytes written.
 - Key: 86, size 4 bytes written.
 - Key: 87, size 2 bytes written.
 - Key: 88, size 1 byte written.
 - Key: 89, size 4 bytes written.
 - Key: 90, size 4 bytes written.
 - Key: 91, size 2 bytes written.
 - Key: 92, size 1 byte written.
 - Key: 93, size 4 bytes written.
 - Key: 94, size 4 bytes written.
 - Key: 95, size 2 bytes written.
 - Key: 96, size 1 byte written.
 - Key: 97, size 4 bytes written.
 - Key: 98, size 4 bytes written.
 - Key: 99, size 2 bytes written.
 - Key: 100, size 4 bytes written.
 - Key: 101, size 2 bytes written.
 - Key: 102, size 1 byte written.
 - Key: 103, size 4 bytes written.
 - Key: 104, size 4 bytes written.
 - Key: 105, size 4 bytes written.
 - Key: 106, size 4 bytes written.
 - Key: 107, size 4 bytes written.
 - Key: 108, size 2 bytes written.
 - Key: 109, size 4 bytes written.
 - Key: 110, size 4 bytes written.
 - Key: 111, size 4 bytes written.
 - Key: 112, size 2 bytes written.
 - Key: 113, size 4 bytes written.
 - Key: 114, size 4 bytes written.
 - Key: 115, size 1 byte written.
 - Key: 116, size 1 byte written.
 - Key: 117, size 1 byte written.
 - Key: 118, size 4 bytes written.
 - Key: 119, size 4 bytes written.
 - Key: 120, size 1 byte written.
 - Key: 121, size 1 byte written.
 - Key: 122, size 1 byte written.
 - Key: 123, size 8 bytes written.
 - Key: 124, size 1 byte written.
 - Key: 125, size 1 byte written.
 - Key: 126, size 1 byte written.
 - Key: 127, size 1 byte written.
 - Key: 128, size 1 byte written.
 - Key: 129, size 4 bytes written.
 - Key: 130, size 4 bytes written.
 - Key: 131, size 1 byte written.
 - Key: 132, size 1 byte written.
 - Key: 133, size 2 bytes written.
 - Key: 134, size 1 byte written.
 - Key: 135, size 2 bytes written.
 - Key: 136, size 1 byte written.
 - Key: 137, size 1 byte written.
 - Key: 138, size 4 bytes written.
 - Key: 139, size 4 bytes written.
 - Key: 140, size 1 byte written.
 - Key: 141, size 1 byte written.
 - Key: 142, size 1 byte written.
 - Key: 143, size 1 byte written.
 - Key: 144, size 4 bytes written.
 - Key: 145, size 8 bytes written.
 - Key: 146, size 4 bytes written.
 - Key: 147, size 4 bytes written.
 - Key: 148, size 1 byte written.
 - Key: 149, size 1 byte written.
 - Key: 150, size 1 byte written.
 - Key: 151, size 1 byte written.
 - Key: 152, size 1 byte written.
 - Key: 153, size 1 byte written.
 - Key: 154, size 1 byte written.
 - Key: 155, size 1 byte written.
 - Key: 156, size 1 byte written.
 - Key: 157, size 1 byte written.
 - Key: 158, size 1 byte written.
 - Key: 159, size 2 bytes written.
 - Key: 160, size 2 bytes written.
 - Key: 161, size 1 byte written.
 - Key: 162, size 1 byte written.
 - Key: 163, size 1 byte written.
 - Key: 164, size 1 byte written.
 - Key: 165, size 1 byte written.
 - Key: 166, size 1 byte written.
Section: 24
Section: 42
 - Key: 1, size 12 bytes written.
 - Key: 2, size 36 bytes written.
 - Key: 3, size 36 bytes written.
 - Key: 4, size 36 bytes written.
 - Key: 5, size 36 bytes written.
 - Key: 6, size 36 bytes written.
 - Key: 7, size 40 bytes written.
 - Key: 8, size 40 bytes written.
 - Key: 9, size 40 bytes written.
 - Key: 10, size 40 bytes written.
 - Key: 11, size 40 bytes written.
 - Key: 12, size 40 bytes written.
 - Key: 13, size 40 bytes written.
 - Key: 14, size 40 bytes written.
 - Key: 15, size 40 bytes written.
 - Key: 16, size 40 bytes written.
 - Key: 17, size 40 bytes written.
 - Key: 18, size 40 bytes written.
 - Key: 19, size 40 bytes written.
 - Key: 20, size 40 bytes written.
 - Key: 21, size 40 bytes written.
 - Key: 22, size 40 bytes written.
 - Key: 23, size 40 bytes written.
 - Key: 24, size 40 bytes written.
 - Key: 25, size 40 bytes written.
 - Key: 26, size 40 bytes written.
Section: 54
 - Key: 2, size 24 bytes written.
Section: 96
 - Key: 1, size 20 bytes written.
Section: 107
 - Key: 0, size 21 bytes written.
 - Key: 1, size 89 bytes written.
 - Key: 2, size 69 bytes written.
 - Key: 3, size 70 bytes written.
 - Key: 25, size 136 bytes written.
 - Key: 26, size 12 bytes written.
Section: 116
Section: 117
 - Key: 5, size 10 bytes written.
 - Key: 16, size 62 bytes written.
 - Key: 22, size 10 bytes written.
 - Key: 23, size 8 bytes written.
- 120 skipped
Section: 163
 - Key: 0, size 8 bytes written.
Section: 193
 - Key: 2, size 8 bytes written.
 - Key: 3, size 32 bytes written.
 - Key: 4, size 32 bytes written.
 - Key: 9, size 64 bytes written.
Section: 217
 - Key: 0, size 32 bytes written.
Section: 218
Section: 238
 - Key: 1, size 1 byte written.
Section: 239
Warning: failed to write 239 - 1 (6917 bytes)
Warning: failed to write 239 - 2 (6917 bytes)
Warning: failed to write 239 - 3 (6911 bytes)
Warning: failed to write 239 - 4 (6917 bytes)
Section: 301
Section: 308
 - Key: 3, size 1 byte written.
 - Key: 8, size 1 byte written.
Section: 322
Section: 341
 - Key: 5, size 4 bytes written.
 - Key: 6, size 2380 bytes written.
Section: 354
 - Key: 0, size 3 bytes written.
Section: 355
Warning: failed to write 355 - 0 (22891 bytes)
Section: 362
 - Key: 1, size 120 bytes written.
Section: 364
Section: 365
Section: 373
 - Key: 0, size 44 bytes written.
Section: 374
Section: 383
 - Key: 1, size 256 bytes written.
 - Key: 3, size 256 bytes written.
 - Key: 4, size 256 bytes written.
 - Key: 5, size 256 bytes written.
 - Key: 6, size 256 bytes written.
 - Key: 7, size 256 bytes written.
 - Key: 8, size 256 bytes written.
 - Key: 9, size 256 bytes written.
 - Key: 10, size 256 bytes written.
 - Key: 11, size 256 bytes written.
 - Key: 12, size 256 bytes written.
 - Key: 13, size 256 bytes written.
 - Key: 14, size 256 bytes written.
 - Key: 15, size 256 bytes written.
 - Key: 16, size 256 bytes written.
 - Key: 17, size 256 bytes written.
 - Key: 18, size 256 bytes written.
 - Key: 19, size 256 bytes written.
 - Key: 20, size 256 bytes written.
 - Key: 21, size 256 bytes written.
 - Key: 22, size 256 bytes written.
 - Key: 23, size 256 bytes written.
 - Key: 24, size 256 bytes written.
 - Key: 25, size 256 bytes written.
 - Key: 26, size 256 bytes written.
 - Key: 27, size 256 bytes written.
 - Key: 28, size 256 bytes written.
 - Key: 29, size 256 bytes written.
 - Key: 30, size 256 bytes written.
 - Key: 31, size 256 bytes written.
 - Key: 32, size 256 bytes written.
 - Key: 33, size 256 bytes written.
 - Key: 34, size 256 bytes written.
 - Key: 35, size 256 bytes written.
 - Key: 36, size 256 bytes written.
 - Key: 37, size 256 bytes written.
 - Key: 38, size 256 bytes written.
 - Key: 39, size 256 bytes written.
 - Key: 40, size 256 bytes written.
 - Key: 41, size 256 bytes written.
 - Key: 42, size 256 bytes written.
 - Key: 43, size 256 bytes written.
 - Key: 44, size 256 bytes written.
 - Key: 45, size 256 bytes written.
 - Key: 46, size 256 bytes written.
 - Key: 47, size 256 bytes written.
 - Key: 48, size 256 bytes written.
 - Key: 49, size 256 bytes written.
 - Key: 50, size 256 bytes written.
 - Key: 51, size 256 bytes written.
 - Key: 52, size 256 bytes written.
 - Key: 53, size 256 bytes written.
 - Key: 54, size 256 bytes written.
 - Key: 55, size 256 bytes written.
 - Key: 56, size 256 bytes written.
 - Key: 57, size 256 bytes written.
 - Key: 58, size 256 bytes written.
 - Key: 59, size 256 bytes written.
 - Key: 60, size 256 bytes written.
 - Key: 61, size 256 bytes written.
 - Key: 62, size 256 bytes written.
 - Key: 63, size 256 bytes written.
 - Key: 64, size 256 bytes written.
 - Key: 65, size 256 bytes written.
 - Key: 66, size 256 bytes written.
 - Key: 67, size 256 bytes written.
 - Key: 68, size 256 bytes written.
 - Key: 69, size 256 bytes written.
 - Key: 70, size 256 bytes written.
 - Key: 71, size 256 bytes written.
 - Key: 72, size 256 bytes written.
 - Key: 73, size 256 bytes written.
 - Key: 74, size 256 bytes written.
 - Key: 75, size 256 bytes written.
 - Key: 76, size 256 bytes written.
 - Key: 77, size 256 bytes written.
 - Key: 78, size 256 bytes written.
 - Key: 79, size 256 bytes written.
 - Key: 80, size 256 bytes written.
 - Key: 81, size 256 bytes written.
 - Key: 82, size 256 bytes written.
 - Key: 83, size 256 bytes written.
 - Key: 84, size 256 bytes written.
 - Key: 85, size 256 bytes written.
 - Key: 86, size 256 bytes written.
 - Key: 87, size 256 bytes written.
 - Key: 88, size 256 bytes written.
 - Key: 89, size 256 bytes written.
 - Key: 90, size 256 bytes written.
 - Key: 91, size 256 bytes written.
 - Key: 92, size 256 bytes written.
 - Key: 93, size 256 bytes written.
 - Key: 94, size 256 bytes written.
 - Key: 95, size 256 bytes written.
 - Key: 96, size 256 bytes written.
 - Key: 97, size 256 bytes written.
 - Key: 98, size 256 bytes written.
 - Key: 99, size 256 bytes written.
 - Key: 100, size 256 bytes written.
 - Key: 101, size 256 bytes written.
 - Key: 102, size 256 bytes written.
 - Key: 103, size 256 bytes written.
 - Key: 104, size 256 bytes written.
 - Key: 105, size 256 bytes written.
 - Key: 106, size 256 bytes written.
 - Key: 107, size 256 bytes written.
 - Key: 108, size 256 bytes written.
 - Key: 109, size 256 bytes written.
 - Key: 110, size 256 bytes written.
 - Key: 111, size 256 bytes written.
 - Key: 112, size 256 bytes written.
 - Key: 113, size 256 bytes written.
 - Key: 114, size 256 bytes written.
 - Key: 115, size 256 bytes written.
 - Key: 116, size 256 bytes written.
 - Key: 117, size 256 bytes written.
 - Key: 118, size 256 bytes written.
 - Key: 119, size 256 bytes written.
 - Key: 120, size 256 bytes written.
 - Key: 121, size 256 bytes written.
 - Key: 122, size 256 bytes written.
 - Key: 123, size 256 bytes written.
 - Key: 124, size 256 bytes written.
 - Key: 125, size 256 bytes written.
 - Key: 126, size 256 bytes written.
 - Key: 127, size 256 bytes written.
 - Key: 128, size 256 bytes written.
 - Key: 129, size 256 bytes written.
 - Key: 130, size 256 bytes written.
 - Key: 131, size 256 bytes written.
 - Key: 132, size 256 bytes written.
 - Key: 133, size 256 bytes written.
 - Key: 134, size 256 bytes written.
 - Key: 135, size 256 bytes written.
 - Key: 136, size 256 bytes written.
 - Key: 137, size 256 bytes written.
 - Key: 138, size 256 bytes written.
 - Key: 139, size 256 bytes written.
 - Key: 140, size 256 bytes written.
 - Key: 141, size 256 bytes written.
 - Key: 142, size 256 bytes written.
 - Key: 143, size 256 bytes written.
 - Key: 144, size 256 bytes written.
 - Key: 145, size 256 bytes written.
 - Key: 146, size 256 bytes written.
 - Key: 147, size 256 bytes written.
 - Key: 148, size 256 bytes written.
 - Key: 149, size 256 bytes written.
 - Key: 150, size 256 bytes written.
 - Key: 151, size 256 bytes written.
 - Key: 152, size 256 bytes written.
 - Key: 153, size 256 bytes written.
 - Key: 154, size 256 bytes written.
 - Key: 155, size 256 bytes written.
 - Key: 156, size 256 bytes written.
 - Key: 157, size 256 bytes written.
 - Key: 158, size 256 bytes written.
 - Key: 159, size 256 bytes written.
 - Key: 160, size 256 bytes written.
 - Key: 161, size 256 bytes written.
 - Key: 162, size 256 bytes written.
 - Key: 163, size 256 bytes written.
 - Key: 164, size 256 bytes written.
 - Key: 165, size 256 bytes written.
 - Key: 166, size 256 bytes written.
 - Key: 167, size 256 bytes written.
 - Key: 168, size 256 bytes written.
 - Key: 169, size 256 bytes written.
 - Key: 170, size 256 bytes written.
 - Key: 171, size 256 bytes written.
 - Key: 172, size 256 bytes written.
 - Key: 173, size 256 bytes written.
 - Key: 174, size 256 bytes written.
 - Key: 175, size 256 bytes written.
 - Key: 176, size 256 bytes written.
 - Key: 177, size 256 bytes written.
 - Key: 178, size 256 bytes written.
 - Key: 179, size 256 bytes written.
 - Key: 180, size 256 bytes written.
 - Key: 181, size 256 bytes written.
 - Key: 182, size 256 bytes written.
 - Key: 183, size 256 bytes written.
 - Key: 184, size 256 bytes written.
 - Key: 185, size 256 bytes written.
 - Key: 186, size 256 bytes written.
 - Key: 187, size 256 bytes written.
 - Key: 188, size 256 bytes written.
 - Key: 189, size 256 bytes written.
 - Key: 190, size 256 bytes written.
 - Key: 191, size 256 bytes written.
 - Key: 192, size 256 bytes written.
 - Key: 193, size 256 bytes written.
 - Key: 194, size 256 bytes written.
 - Key: 195, size 256 bytes written.
 - Key: 196, size 256 bytes written.
 - Key: 197, size 256 bytes written.
 - Key: 198, size 256 bytes written.
 - Key: 199, size 256 bytes written.
 - Key: 200, size 256 bytes written.
 - Key: 201, size 256 bytes written.
 - Key: 202, size 256 bytes written.
 - Key: 203, size 256 bytes written.
 - Key: 204, size 256 bytes written.
 - Key: 205, size 256 bytes written.
 - Key: 206, size 256 bytes written.
 - Key: 207, size 256 bytes written.
 - Key: 208, size 256 bytes written.
 - Key: 209, size 256 bytes written.
 - Key: 210, size 256 bytes written.
 - Key: 211, size 256 bytes written.
 - Key: 212, size 256 bytes written.
 - Key: 213, size 256 bytes written.
 - Key: 214, size 256 bytes written.
 - Key: 215, size 256 bytes written.
 - Key: 216, size 256 bytes written.
 - Key: 217, size 256 bytes written.
 - Key: 218, size 256 bytes written.
 - Key: 219, size 256 bytes written.
 - Key: 220, size 256 bytes written.
 - Key: 221, size 256 bytes written.
 - Key: 222, size 256 bytes written.
 - Key: 223, size 256 bytes written.
 - Key: 224, size 256 bytes written.
 - Key: 225, size 256 bytes written.
 - Key: 226, size 256 bytes written.
 - Key: 227, size 256 bytes written.
 - Key: 228, size 256 bytes written.
 - Key: 229, size 256 bytes written.
 - Key: 230, size 256 bytes written.
 - Key: 231, size 256 bytes written.
 - Key: 232, size 256 bytes written.
 - Key: 233, size 256 bytes written.
 - Key: 234, size 256 bytes written.
 - Key: 235, size 256 bytes written.
 - Key: 236, size 256 bytes written.
 - Key: 237, size 256 bytes written.
 - Key: 238, size 256 bytes written.
 - Key: 239, size 256 bytes written.
 - Key: 240, size 256 bytes written.
 - Key: 241, size 256 bytes written.
 - Key: 242, size 256 bytes written.
 - Key: 243, size 256 bytes written.
 - Key: 244, size 256 bytes written.
 - Key: 245, size 256 bytes written.
 - Key: 246, size 256 bytes written.
 - Key: 247, size 256 bytes written.
Section: 390
 - Key: 0, size 256 bytes written.
 - Key: 2, size 256 bytes written.
 - Key: 248, size 256 bytes written.
 - Key: 249, size 256 bytes written.
 - Key: 250, size 256 bytes written.
 - Key: 251, size 256 bytes written.
 - Key: 252, size 256 bytes written.
 - Key: 253, size 256 bytes written.
 - Key: 254, size 256 bytes written.
 - Key: 255, size 256 bytes written.
 - Key: 256, size 256 bytes written.
 - Key: 257, size 256 bytes written.
 - Key: 258, size 256 bytes written.
 - Key: 259, size 256 bytes written.
 - Key: 260, size 256 bytes written.
 - Key: 261, size 256 bytes written.
 - Key: 262, size 256 bytes written.
 - Key: 263, size 256 bytes written.
 - Key: 264, size 256 bytes written.
 - Key: 265, size 256 bytes written.
 - Key: 266, size 256 bytes written.
 - Key: 267, size 256 bytes written.
 - Key: 268, size 256 bytes written.
 - Key: 269, size 256 bytes written.
 - Key: 270, size 256 bytes written.
 - Key: 271, size 256 bytes written.
 - Key: 272, size 256 bytes written.
 - Key: 273, size 256 bytes written.
 - Key: 274, size 256 bytes written.
 - Key: 275, size 256 bytes written.
 - Key: 276, size 256 bytes written.
 - Key: 277, size 256 bytes written.
 - Key: 278, size 256 bytes written.
 - Key: 279, size 256 bytes written.
 - Key: 280, size 256 bytes written.
 - Key: 281, size 256 bytes written.
 - Key: 282, size 256 bytes written.
 - Key: 283, size 256 bytes written.
 - Key: 284, size 256 bytes written.
 - Key: 285, size 256 bytes written.
 - Key: 286, size 256 bytes written.
 - Key: 287, size 256 bytes written.
 - Key: 288, size 256 bytes written.
 - Key: 289, size 256 bytes written.
 - Key: 290, size 256 bytes written.
 - Key: 291, size 256 bytes written.
 - Key: 292, size 256 bytes written.
 - Key: 293, size 256 bytes written.
 - Key: 294, size 256 bytes written.
 - Key: 295, size 256 bytes written.
 - Key: 296, size 256 bytes written.
 - Key: 297, size 256 bytes written.
 - Key: 298, size 256 bytes written.
 - Key: 299, size 256 bytes written.
 - Key: 300, size 256 bytes written.
 - Key: 301, size 256 bytes written.
 - Key: 302, size 256 bytes written.
 - Key: 303, size 256 bytes written.
 - Key: 304, size 256 bytes written.
 - Key: 305, size 256 bytes written.
 - Key: 306, size 256 bytes written.
 - Key: 307, size 256 bytes written.
 - Key: 308, size 256 bytes written.
 - Key: 309, size 256 bytes written.
 - Key: 310, size 256 bytes written.
 - Key: 311, size 256 bytes written.
 - Key: 312, size 256 bytes written.
 - Key: 313, size 256 bytes written.
 - Key: 314, size 256 bytes written.
 - Key: 315, size 256 bytes written.
 - Key: 316, size 256 bytes written.
 - Key: 317, size 256 bytes written.
 - Key: 318, size 256 bytes written.
 - Key: 319, size 256 bytes written.
 - Key: 320, size 256 bytes written.
 - Key: 321, size 256 bytes written.
 - Key: 322, size 256 bytes written.
 - Key: 323, size 256 bytes written.
 - Key: 324, size 256 bytes written.
 - Key: 325, size 256 bytes written.
 - Key: 326, size 256 bytes written.
 - Key: 327, size 256 bytes written.
 - Key: 328, size 256 bytes written.
 - Key: 329, size 256 bytes written.
 - Key: 330, size 256 bytes written.
 - Key: 331, size 256 bytes written.
 - Key: 332, size 256 bytes written.
 - Key: 333, size 256 bytes written.
 - Key: 334, size 256 bytes written.
 - Key: 335, size 256 bytes written.
 - Key: 336, size 256 bytes written.
 - Key: 337, size 256 bytes written.
 - Key: 338, size 256 bytes written.
 - Key: 339, size 256 bytes written.
 - Key: 340, size 256 bytes written.
 - Key: 341, size 256 bytes written.
 - Key: 342, size 256 bytes written.
 - Key: 343, size 256 bytes written.
 - Key: 344, size 256 bytes written.
 - Key: 345, size 256 bytes written.
 - Key: 346, size 256 bytes written.
 - Key: 347, size 256 bytes written.
 - Key: 348, size 256 bytes written.
 - Key: 349, size 256 bytes written.
 - Key: 350, size 256 bytes written.
 - Key: 351, size 256 bytes written.
 - Key: 352, size 256 bytes written.
 - Key: 353, size 256 bytes written.
 - Key: 354, size 256 bytes written.
 - Key: 355, size 256 bytes written.
 - Key: 356, size 256 bytes written.
 - Key: 357, size 256 bytes written.
 - Key: 358, size 256 bytes written.
 - Key: 359, size 256 bytes written.
 - Key: 360, size 256 bytes written.
 - Key: 361, size 256 bytes written.
 - Key: 362, size 256 bytes written.
 - Key: 363, size 256 bytes written.
 - Key: 364, size 256 bytes written.
 - Key: 365, size 256 bytes written.
 - Key: 366, size 256 bytes written.
 - Key: 367, size 256 bytes written.
 - Key: 368, size 256 bytes written.
 - Key: 369, size 256 bytes written.
 - Key: 370, size 256 bytes written.
 - Key: 371, size 256 bytes written.
 - Key: 372, size 256 bytes written.
 - Key: 373, size 256 bytes written.
 - Key: 374, size 256 bytes written.
 - Key: 375, size 256 bytes written.
 - Key: 376, size 256 bytes written.
 - Key: 377, size 256 bytes written.
 - Key: 378, size 256 bytes written.
 - Key: 379, size 256 bytes written.
 - Key: 380, size 256 bytes written.
 - Key: 381, size 256 bytes written.
 - Key: 382, size 256 bytes written.
 - Key: 383, size 256 bytes written.
 - Key: 384, size 256 bytes written.
 - Key: 385, size 256 bytes written.
 - Key: 386, size 256 bytes written.
 - Key: 387, size 256 bytes written.
 - Key: 388, size 256 bytes written.
 - Key: 389, size 256 bytes written.
 - Key: 390, size 256 bytes written.
 - Key: 391, size 256 bytes written.
 - Key: 392, size 256 bytes written.
 - Key: 393, size 256 bytes written.
 - Key: 394, size 256 bytes written.
 - Key: 395, size 256 bytes written.
 - Key: 396, size 256 bytes written.
 - Key: 397, size 256 bytes written.
 - Key: 398, size 256 bytes written.
 - Key: 399, size 256 bytes written.
 - Key: 400, size 256 bytes written.
 - Key: 401, size 256 bytes written.
 - Key: 402, size 256 bytes written.
 - Key: 403, size 256 bytes written.
 - Key: 404, size 256 bytes written.
 - Key: 405, size 256 bytes written.
 - Key: 406, size 256 bytes written.
 - Key: 407, size 256 bytes written.
 - Key: 408, size 256 bytes written.
 - Key: 409, size 256 bytes written.
 - Key: 410, size 256 bytes written.
 - Key: 411, size 256 bytes written.
 - Key: 412, size 256 bytes written.
 - Key: 413, size 256 bytes written.
 - Key: 414, size 256 bytes written.
 - Key: 415, size 256 bytes written.
 - Key: 416, size 256 bytes written.
 - Key: 417, size 256 bytes written.
 - Key: 418, size 256 bytes written.
 - Key: 419, size 256 bytes written.
 - Key: 420, size 256 bytes written.
 - Key: 421, size 256 bytes written.
 - Key: 422, size 256 bytes written.
 - Key: 423, size 256 bytes written.
 - Key: 424, size 256 bytes written.
 - Key: 425, size 256 bytes written.
 - Key: 426, size 256 bytes written.
 - Key: 427, size 256 bytes written.
 - Key: 428, size 256 bytes written.
 - Key: 429, size 256 bytes written.
 - Key: 430, size 256 bytes written.
 - Key: 431, size 256 bytes written.
 - Key: 432, size 256 bytes written.
 - Key: 433, size 256 bytes written.
 - Key: 434, size 256 bytes written.
 - Key: 435, size 256 bytes written.
 - Key: 436, size 256 bytes written.
 - Key: 437, size 256 bytes written.
 - Key: 438, size 256 bytes written.
 - Key: 439, size 256 bytes written.
 - Key: 440, size 256 bytes written.
 - Key: 441, size 256 bytes written.
 - Key: 442, size 256 bytes written.
 - Key: 443, size 256 bytes written.
 - Key: 444, size 256 bytes written.
 - Key: 445, size 256 bytes written.
 - Key: 446, size 256 bytes written.
 - Key: 447, size 256 bytes written.
 - Key: 448, size 256 bytes written.
 - Key: 449, size 256 bytes written.
 - Key: 450, size 256 bytes written.
 - Key: 451, size 256 bytes written.
 - Key: 452, size 256 bytes written.
 - Key: 453, size 256 bytes written.
 - Key: 454, size 256 bytes written.
 - Key: 455, size 256 bytes written.
 - Key: 456, size 256 bytes written.
 - Key: 457, size 256 bytes written.
 - Key: 458, size 256 bytes written.
 - Key: 459, size 256 bytes written.
 - Key: 460, size 256 bytes written.
 - Key: 461, size 256 bytes written.
 - Key: 462, size 256 bytes written.
 - Key: 463, size 256 bytes written.
 - Key: 464, size 256 bytes written.
 - Key: 465, size 256 bytes written.
 - Key: 466, size 256 bytes written.
 - Key: 467, size 256 bytes written.
 - Key: 468, size 256 bytes written.
 - Key: 469, size 256 bytes written.
 - Key: 470, size 256 bytes written.
 - Key: 471, size 256 bytes written.
 - Key: 472, size 256 bytes written.
 - Key: 473, size 256 bytes written.
 - Key: 474, size 256 bytes written.
 - Key: 475, size 256 bytes written.
 - Key: 476, size 256 bytes written.
 - Key: 477, size 256 bytes written.
 - Key: 478, size 256 bytes written.
 - Key: 479, size 256 bytes written.
 - Key: 480, size 256 bytes written.
 - Key: 481, size 256 bytes written.
 - Key: 482, size 256 bytes written.
 - Key: 483, size 256 bytes written.
 - Key: 484, size 256 bytes written.
 - Key: 485, size 256 bytes written.
 - Key: 486, size 256 bytes written.
 - Key: 487, size 256 bytes written.
 - Key: 488, size 256 bytes written.
 - Key: 489, size 256 bytes written.
 - Key: 490, size 256 bytes written.
 - Key: 491, size 256 bytes written.
 - Key: 492, size 256 bytes written.
 - Key: 493, size 256 bytes written.
 - Key: 494, size 256 bytes written.
 - Key: 495, size 256 bytes written.
 - Key: 496, size 256 bytes written.
 - Key: 497, size 256 bytes written.
 - Key: 498, size 256 bytes written.
 - Key: 499, size 256 bytes written.
 - Key: 500, size 256 bytes written.
 - Key: 501, size 256 bytes written.
 - Key: 502, size 256 bytes written.
 - Key: 503, size 256 bytes written.
 - Key: 504, size 256 bytes written.
 - Key: 505, size 256 bytes written.
 - Key: 506, size 256 bytes written.
 - Key: 507, size 256 bytes written.
 - Key: 508, size 256 bytes written.
 - Key: 509, size 256 bytes written.
 - Key: 510, size 256 bytes written.
 - Key: 511, size 256 bytes written.
 - Key: 512, size 256 bytes written.
 - Key: 513, size 256 bytes written.
 - Key: 514, size 256 bytes written.
 - Key: 515, size 256 bytes written.
 - Key: 516, size 256 bytes written.
 - Key: 517, size 256 bytes written.
 - Key: 518, size 256 bytes written.
 - Key: 519, size 256 bytes written.
 - Key: 520, size 256 bytes written.
 - Key: 521, size 256 bytes written.
 - Key: 522, size 256 bytes written.
 - Key: 523, size 256 bytes written.
 - Key: 524, size 256 bytes written.
 - Key: 525, size 256 bytes written.
 - Key: 526, size 256 bytes written.
 - Key: 527, size 256 bytes written.
 - Key: 528, size 256 bytes written.
 - Key: 529, size 256 bytes written.
 - Key: 530, size 256 bytes written.
 - Key: 531, size 256 bytes written.
 - Key: 532, size 256 bytes written.
 - Key: 533, size 256 bytes written.
 - Key: 534, size 256 bytes written.
 - Key: 535, size 256 bytes written.
 - Key: 536, size 256 bytes written.
 - Key: 537, size 256 bytes written.
 - Key: 538, size 256 bytes written.
 - Key: 539, size 256 bytes written.
 - Key: 540, size 256 bytes written.
 - Key: 541, size 256 bytes written.
 - Key: 542, size 256 bytes written.
 - Key: 543, size 256 bytes written.
 - Key: 544, size 256 bytes written.
 - Key: 545, size 256 bytes written.
 - Key: 546, size 256 bytes written.
 - Key: 547, size 256 bytes written.
 - Key: 548, size 256 bytes written.
 - Key: 549, size 256 bytes written.
 - Key: 550, size 256 bytes written.
 - Key: 551, size 256 bytes written.
 - Key: 552, size 256 bytes written.
 - Key: 553, size 256 bytes written.
 - Key: 554, size 256 bytes written.
 - Key: 555, size 256 bytes written.
 - Key: 556, size 256 bytes written.
 - Key: 557, size 256 bytes written.
 - Key: 558, size 256 bytes written.
 - Key: 559, size 256 bytes written.
 - Key: 560, size 256 bytes written.
 - Key: 561, size 256 bytes written.
 - Key: 562, size 256 bytes written.
 - Key: 563, size 256 bytes written.
 - Key: 564, size 256 bytes written.
 - Key: 565, size 256 bytes written.
 - Key: 566, size 256 bytes written.
 - Key: 567, size 256 bytes written.
 - Key: 568, size 256 bytes written.
 - Key: 569, size 256 bytes written.
 - Key: 570, size 256 bytes written.
 - Key: 571, size 256 bytes written.
 - Key: 572, size 256 bytes written.
 - Key: 573, size 256 bytes written.
 - Key: 574, size 256 bytes written.
 - Key: 575, size 256 bytes written.
 - Key: 576, size 256 bytes written.
 - Key: 577, size 256 bytes written.
 - Key: 578, size 256 bytes written.
 - Key: 579, size 256 bytes written.
 - Key: 580, size 256 bytes written.
 - Key: 581, size 256 bytes written.
 - Key: 582, size 256 bytes written.
 - Key: 583, size 256 bytes written.
 - Key: 584, size 256 bytes written.
 - Key: 585, size 256 bytes written.
 - Key: 586, size 256 bytes written.
 - Key: 587, size 256 bytes written.
 - Key: 588, size 256 bytes written.
 - Key: 589, size 256 bytes written.
 - Key: 590, size 256 bytes written.
 - Key: 591, size 256 bytes written.
 - Key: 592, size 256 bytes written.
 - Key: 593, size 256 bytes written.
 - Key: 594, size 256 bytes written.
 - Key: 595, size 256 bytes written.
 - Key: 596, size 256 bytes written.
 - Key: 597, size 256 bytes written.
 - Key: 598, size 256 bytes written.
 - Key: 599, size 256 bytes written.
 - Key: 600, size 256 bytes written.
 - Key: 601, size 256 bytes written.
 - Key: 602, size 256 bytes written.
 - Key: 603, size 256 bytes written.
 - Key: 604, size 256 bytes written.
 - Key: 605, size 256 bytes written.
 - Key: 606, size 256 bytes written.
 - Key: 607, size 256 bytes written.
 - Key: 608, size 256 bytes written.
 - Key: 609, size 256 bytes written.
 - Key: 610, size 256 bytes written.
 - Key: 611, size 256 bytes written.
 - Key: 612, size 256 bytes written.
 - Key: 613, size 256 bytes written.
 - Key: 614, size 256 bytes written.
 - Key: 615, size 256 bytes written.
 - Key: 616, size 256 bytes written.
 - Key: 617, size 256 bytes written.
 - Key: 618, size 256 bytes written.
 - Key: 619, size 256 bytes written.
 - Key: 620, size 256 bytes written.
 - Key: 621, size 256 bytes written.
 - Key: 622, size 256 bytes written.
 - Key: 623, size 256 bytes written.
 - Key: 624, size 256 bytes written.
 - Key: 625, size 256 bytes written.
 - Key: 626, size 256 bytes written.
 - Key: 627, size 256 bytes written.
 - Key: 628, size 256 bytes written.
 - Key: 629, size 256 bytes written.
 - Key: 630, size 256 bytes written.
 - Key: 631, size 256 bytes written.
 - Key: 632, size 256 bytes written.
 - Key: 633, size 256 bytes written.
 - Key: 634, size 256 bytes written.
 - Key: 635, size 256 bytes written.
 - Key: 636, size 256 bytes written.
 - Key: 637, size 256 bytes written.
 - Key: 638, size 256 bytes written.
 - Key: 639, size 256 bytes written.
 - Key: 640, size 256 bytes written.
 - Key: 641, size 256 bytes written.
 - Key: 642, size 256 bytes written.
 - Key: 643, size 256 bytes written.
 - Key: 644, size 256 bytes written.
 - Key: 645, size 256 bytes written.
 - Key: 646, size 256 bytes written.
 - Key: 647, size 256 bytes written.
 - Key: 648, size 256 bytes written.
 - Key: 649, size 256 bytes written.
 - Key: 650, size 256 bytes written.
 - Key: 651, size 256 bytes written.
 - Key: 652, size 256 bytes written.
 - Key: 653, size 256 bytes written.
 - Key: 654, size 256 bytes written.
 - Key: 655, size 256 bytes written.
 - Key: 656, size 256 bytes written.
 - Key: 657, size 256 bytes written.
 - Key: 658, size 256 bytes written.
 - Key: 659, size 256 bytes written.
 - Key: 660, size 256 bytes written.
 - Key: 661, size 256 bytes written.
 - Key: 662, size 256 bytes written.
Section: 391
Completed in 18.074 s
Section: 120
 - Key: 0, size 78 bytes written.
 - Key: 1, size 160 bytes written.
 - Key: 2, size 130 bytes written.
 - Key: 3, size 147 bytes written.
Completed in 5.104 s
FULL FACTORY... Failed! (0000)
Completed in 1.767 s
FULL FACTORY... Failed! (0016)
Completed in 20.178 s
Help Me
Old 02-17-2014, 05:10   #7 (permalink)
Member: 2097868
flas whit ATF box,,
maybe ok
The Following User Says Thank You to renol ponsel For This Useful Post:
Old 02-17-2014, 05:42   #8 (permalink)
Registered User
Member: 1179630
Sonork: 100.1644820
Thanks Meter: 80
Originally Posted by renol ponsel View Post
flas whit ATF box,,
maybe ok
Unfortunately I haven't. I'm think to buy it very useful.
Old 02-17-2014, 06:16   #9 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 523
mxbox and teem is dead
dont flash all new phone with mx
and u dont se any support teem ans u
The Following User Says Thank You to iftikhar_246 For This Useful Post:
Old 02-17-2014, 12:10   #10 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Go to Service Tab > Quick Fix Tab > Tick XGOLD2 Fix CS/Recover Simlock > Click Do Selected Job Button,
Post Reply.
BR,
ZUBER
Old 02-17-2014, 13:14   #11 (permalink)
Registered User
Member: 1179630
Sonork: 100.1644820
Thanks Meter: 80
Originally Posted by .::ZUBER::. View Post
Bro.
Post Reply.
BR,
ZUBER
I tryed Bro
it says some counter reset ok. but no luck. i return unit to customer. it still in warranty period. i think nokia care center can fix it or they will replace mb.
Old 03-16-2014, 10:43   #12 (permalink)
Registered User
Member: 1179630
Sonork: 100.1644820
Thanks Meter: 80
My Problem Solved.
Nokia Service Center Replaced the unit.
Page generated in 0.33664 seconds with 9 queries
