01-08-2010, 14:41 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: jodhpur Age: 40
Member: 737954 Status: Offline Sonork: Mobile Thanks Meter: 107 | nokia 1110i no network .......... mx-key log.............- Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11472, Date: 27-11-2009 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 005AFA46:2984DA60 ASIC type: 2 UEM Imei: 35367001276368 Flash Imei: 35367001276368 MasterCode: 2060370107 RPL saved to "C:\mobileEx\3.3\data\backup\35367001276368_BACK.r pl" Phone Type: RH-93 SW Version: V 6.41 06-04-07 RH-93 (c) NMP Imei plain: 35367001276368-9 Product Code: 0533039 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: MG Language Pack: - not available. ProductProfile: apac.pp Imei net: 35367001276368 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.CORRUPTED (20) 2.CORRUPTED (20) 3.CORRUPTED (20) 4.CORRUPTED (20) 5.CORRUPTED (20) BLOCK 4: 1.CORRUPTED (20) 2.CORRUPTED (20) 3.CORRUPTED (20) 4.CORRUPTED (20) 5.CORRUPTED (20) BLOCK 5: 1.CORRUPTED (20) 2.CORRUPTED (20) 3.CORRUPTED (20) 4.CORRUPTED (20) 5.CORRUPTED (20) BLOCK 6: 1.CORRUPTED (20) 2.CORRUPTED (20) 3.CORRUPTED (20) 4.CORRUPTED (20) 5.CORRUPTED (20) |
01-08-2010, 14:48 | #4 (permalink) |
Member: 737954 Status: Offline Sonork: Mobile Thanks Meter: 107 | Writing PM from Node ... Section: 1 - Key: 0, size 120 bytes written. - Key: 2, size 90 bytes written. - Key: 4, size 110 bytes written. - Key: 5, size 2 bytes written. - Key: 6, size 90 bytes written. - Key: 11, size 2 bytes written. Section: 2 - Key: 0, size 132 bytes written. Section: 4 - Key: 1, size 8 bytes written. - Key: 2, size 44 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 5 bytes written. Section: 7 - Key: 0, size 4 bytes written. - Key: 1, size 32 bytes written. - Key: 2, size 4 bytes written. - 21 skipped Section: 26 - Key: 0, size 302 bytes written. - Key: 1, size 302 bytes written. - Key: 2, size 302 bytes written. - Key: 3, size 302 bytes written. - Key: 4, size 302 bytes written. - Key: 5, size 302 bytes written. - Key: 6, size 302 bytes written. - 120 skipped Completed in 2.843 s |
01-08-2010, 14:49 | #6 (permalink) |
Member: 737954 Status: Offline Sonork: Mobile Thanks Meter: 107 | Imei net: 35367001276368 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Updating SIMLOCK ...Error 1 PhoneType:RH-93 SwVersion: V 6.41 06-04-07 RH-93 (c) NMP MCU file: rh93_06.410 Trying to find patch position ...OK, case id: 1 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 005AFA46:2984DA60 Area [01140000-0115FFFF] erased in 0.735 s Programming ... Programming completed. Updating SIMLOCK ...Error 0x16 |
01-08-2010, 14:52 | #7 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | write this pm & unlock it splock and update splock if still same check hrdware when u unlock it will ask mcu file give it |
The Following User Says Thank You to sneha For This Useful Post: |
01-08-2010, 16:59 | #9 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | bad eeprom can also caused no network. many write / unlock attemp also can make it corrupted. nothing to lose if you try to rebuild it by custom erase, select eeprom area only (advanced > get address) |
1110i no network found | Elias Khan | Nokia Hardware & Hardware Repair | 9 | 03-03-2010 18:42 |
1110i no network | pakmobiles | Nokia Digital Core Technology 4 ( DCT-4 ) | 19 | 04-02-2009 10:33 |
1110i no network access pls help? | shimul_777 | Nokia Hardware & Hardware Repair | 1 | 03-15-2008 11:24 |
1110i No network | adnanskyland | Nokia Hardware & Hardware Repair | 7 | 01-21-2008 18:30 |
