11-07-2014, 09:54 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: aizawl
Member: 282510 Status: Offline Thanks Meter: 33 | Nokia 114 full flash, UI Failed and set is dead MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0859DFF Using device: USB ROM and HTI, FW ver: 00.50, SN: 01012F93 Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.117 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.49 EBL version: Quantum_Bootloader_10.49_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35549505882250 RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35549505882250_ back.RPL) Processing file: rm827__03.51.mcusw Downloading item CODE:rm827__03.51.mcusw_ebl_psi.fls, num block: 4, size: 26 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.359 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.359 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.813 s Erasing area 0x40280000-0x41B3FFFE ...OK Programming completed in 36.937 s Checksum verified (0xA3D4) Processing file: rm827__03.51.ppm_s1 Downloading item CUSTackage_s1.ppm_ebl_psi.fls, num block: 1, size: 3.98 MB Erasing area 0x41BC0000-0x41FBA54E ...OK Programming completed in 6.016 s Checksum verified (0xD440) Processing file: rm827__03.51.image_s1_059N217 Downloading item CUSTackage_s1_059N217.image.fls, num block: 1, size: 15.25 MB Erasing area 0x421C0000-0x43E1FFFE ...OK Programming completed in 21.031 s Checksum verified (0x0F3A) Total time for flashing process(boot+erase+write) was 9 min 10.766 s Waiting for USB device removal ... Waiting for device boot up ... Phone not found, retrying ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1530DE94 |
11-10-2014, 11:28 | #3 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | What understand that DAMAGE all you phone this Sw fake?, only DCT4 can flash right also with USF w/o Hwk as interface becouse have very old protection, all BB5/Sl3, itc...NOT TRY damage you device and after you can only repair, (if not ERASE nothingh), with Best Atf, but i not understand why peoples continue using this DEAD project. Br allumts |
