10-14-2009, 13:18 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | nokia 1200 contact service all ok still ? ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0081F259A3BDA66 ASIC type: 11 UEM Imei: 3531070xxxxx Phone Type: RH-99 SW Version: V 4.11 10-11-07 RH-99 (c) NMP Imei plain: 35310702xxxx Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: AA Language Pack: English,Dannish,Norwegian,Swedish Imei net: 353107022sxxxx Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Invalid UEM Data, backup will not be created. self test Phone Type: SW version: ID Test name Startup Result 46 UEM_CBUS_IF Y passed 15 SLEEP_X_LOOP Y passed 3 EAR_DATA_LOOP Y !failed ! 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 39 WARRANTY Y passed 33 SIM_LOCK Y passed 10 PPM_VALIDITY Y passed 43 LCD Y passed 41 FLASH_CHECKSUM N passed 30 RF_CHIP_ID N !failed ! 52 KASUMI N passed ======================== wrote RPL ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0081F259A3BDA66 ASIC type: 11 UEM Imei: 35310702218679 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0081F259A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ... UEM programmed successfully. Phone Type: RH-99 SW Version: V 4.11 10-11-07 RH-99 (c) NMP Imei plain: 35310702218679-1 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: AA Language Pack: English,Dannish,Norwegian,Swedish Imei net: 35310vxxxxxxxxxx Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Flahsed with 4.11 5.06 and 5.80 RH-99 same result Contact Service |
10-14-2009, 13:22 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Anwar Telecom .DHAKA Age: 38
Member: 896667 Status: Offline Sonork: 100.1586139 Thanks Meter: 1,596 | try hwk before full erase then flash write pm & full unlock |
The Following User Says Thank You to dvd_anwar For This Useful Post: |
10-14-2009, 13:23 | #3 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Nadiad Age: 40
Member: 410217 Status: Offline Thanks Meter: 44 | Quote:
1st solution not work try 2nd solution 2nd.reaplace upp & flash ic. | |
The Following User Says Thank You to viral123 For This Useful Post: |
3600s CONTACT SERVICE, all ok, but security_test _fail | mantok | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 37 | 08-29-2010 12:44 |
5130 contact service all ok | chand_gee | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-14-2010 19:54 |
3110 contact service- all ok but still contact | Riteshgpt60 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 01-03-2010 09:22 |
nokia 1200 contact service | muhammad irshad | Nokia Hardware & Hardware Repair | 2 | 12-18-2008 09:29 |
Hello Everybody I Have Nokia 1200 Contact Service Plese Give Any Solution For Thinks | smcommunication | Nokia Hardware & Hardware Repair | 3 | 05-20-2008 10:19 |
