03-23-2010, 16:58 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: india up.
Member: 599228 Status: Offline Thanks Meter: 112 | nokia 1200 flishing ok no power on... (ANSWERED) Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: A57E A61A 1BBE 03E2 7D58 63E4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00547092A3BDA66 ASIC type: 11 UEM Imei: 35896201809252 Processing file: rh99_06.000 as MCU [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: A57E A61A 1BBE 03E2 7D58 63E4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00547092:2984DA60 Area [01000000-0100FFFF] erased in 0.406 s Area [01010000-013AFFFF] erased in 21.297 s Area [013B0000-013EFFFF] erased in 1.484 s Area [017C0000-017EFFFF] erased in 0.094 s Area [01FC0000-01FEFFFF] erased in 0.109 s Flash programming ... Programming completed in 18.125 s File Processed in 49.906 s Processing file: rh990_nai6.00ej as CNT [DCT4,DCT4 ALGORITHM] size: 109.24 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: A57E A61A 1BBE 03E2 7D58 63E4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00547092:2984DA60 Area [01380000-013AFFFF] erased in 1.109 s Flash programming ... Programming completed in 0.891 s Content extract fail, continue anyway ... File Processed in 31.063 s Processing file: rh99_06.00ej as PPM [DCT4,DCT4 ALGORITHM] size: 1.15 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: A57E A61A 1BBE 03E2 7D58 63E4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00547092:2984DA60 Area [01240000-0124FFFF] erased in 0.375 s Area [01250000-0137FFFF] erased in 6.985 s Flash programming ... Programming completed in 9.234 s File Processed in 24.953 s Flashing completed in 2 min 50.015 s Phone not responding ! Total time to process is 3 min 20.234 s |
03-23-2010, 17:07 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Look there is an error here --> Content extract fail, continue anyway ... you see this,, i know the solution.. i will prepare a picture and post here ok. just wait a few minutes. |
03-23-2010, 17:52 | #3 (permalink) |
Member: 1014781 Status: Offline Thanks Meter: 177 | Here is the solution for Content extract fail, it works for me. you should try it. I cant upload any file here, you should download it from here ---> 4shared.com - photo sharing - download image 1200 content extract failed solution.JPG The instruction are clearly written there. If it helps you, press thanks OK. |
The Following 2 Users Say Thank You to curvenger For This Useful Post: |
09-28-2010, 05:57 | #4 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1403387 Status: Offline Sonork: [email protected] Thanks Meter: 0 | daer sirji plz help nokia 1200 flishing ok no power on............. -------------------------------------------------------------------------------- Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: A57E A61A 1BBE 03E2 7D58 63E4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00547092A3BDA66 ASIC type: 11 UEM Imei: 35896201809252 Processing file: rh99_06.000 as MCU [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: A57E A61A 1BBE 03E2 7D58 63E4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00547092:2984DA60 Area [01000000-0100FFFF] erased in 0.406 s Area [01010000-013AFFFF] erased in 21.297 s Area [013B0000-013EFFFF] erased in 1.484 s Area [017C0000-017EFFFF] erased in 0.094 s Area [01FC0000-01FEFFFF] erased in 0.109 s Flash programming ... Programming completed in 18.125 s File Processed in 49.906 s Processing file: rh990_nai6.00ej as CNT [DCT4,DCT4 ALGORITHM] size: 109.24 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: A57E A61A 1BBE 03E2 7D58 63E4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00547092:2984DA60 Area [01380000-013AFFFF] erased in 1.109 s Flash programming ... Programming completed in 0.891 s Content extract fail, continue anyway ... File Processed in 31.063 s Processing file: rh99_06.00ej as PPM [DCT4,DCT4 ALGORITHM] size: 1.15 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: A57E A61A 1BBE 03E2 7D58 63E4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00547092:2984DA60 Area [01240000-0124FFFF] erased in 0.375 s Area [01250000-0137FFFF] erased in 6.985 s Flash programming ... Programming completed in 9.234 s File Processed in 24.953 s Flashing completed in 2 min 50.015 s |
09-28-2010, 06:12 | #5 (permalink) | |
Freak Poster Join Date: Jun 2009 Location: india
Member: 1053356 Status: Offline Sonork: 12345 Thanks Meter: 18 | choose correct bsi resistor value I think it is 5.1k Quote:
09-28-2010, 10:28 | #7 (permalink) |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | 1st flashed with easy cable fully charged battrey . if problem not solved then 1. 1st mcu flash 2sd. ppm flashed 3. unlock now your handset on if not check imei possible currupted |
09-29-2010, 00:14 | #10 (permalink) |
Freak Poster Join Date: Sep 2007 Location: cambodia
Member: 578236 Status: Offline Thanks Meter: 31 | this problem involve with software and hardware so you just try to solve with the above software solutions if not solve then try to understand with Hardware 1 all power from UEM to feed to the cpu and flash ic must be ok and accurate like vio, vann, vocore, vflash, and 26Mhz must be measurable 2 cpu must be clean and good (it possible pin cracked or cpu bad) 3 flash ic must be clean and good (it possible pin cracked or cpu bad) good luck |
