03-28-2012, 13:24 | #1 (permalink) |
Registered User Join Date: Jun 2011
Member: 1597393 Status: Offline Sonork: 6692766 Thanks Meter: 4 | nokia 1202 flashing problem not going in local mode after flashing Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.13946(25-02-2012) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0029BA77A3BDA66 ASIC type: 11 UEM Imei: 35694803237966 Flash Imei: 35694803237966 RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35694803237966_BA CK.rpl" Processing MCU file: rh112_004.030 [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0029BA77:2984DA60 Area [01000000-0100FFFF] erased in 1.094 s Area [01010000-013AFFFF] erased in 1 min 3.110 s Area [013B0000-013EFFFF] erased in 4.484 s Area [017C0000-017EFFFF] erased in 0.031 s Area [01FC0000-01FEFFFF] erased in 0.031 s Flash programming ... Programming completed in 17.985 s File Processed in 1 min 33.938 s Processing CNT file: rh1120_nai04.03ij [DCT4,DCT4 ALGORITHM] size: 167.29 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: 0140 0600 2000 0040 C000 4000 0002 0510 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0029BA77:2984DA60 Area [01380000-013AFFFF] erased in 3.297 s Flash programming ... Programming completed in 1.297 s Content extract fail, continue anyway ... File Processed in 54.390 s Processing PPM file: rh112_004.03ij [DCT4,DCT4 ALGORITHM] size: 1.08 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: 0140 0600 2000 0040 C000 4000 0002 0510 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0029BA77:2984DA60 Area [01240000-0124FFFF] erased in 1.078 s Area [01250000-0137FFFF] erased in 20.625 s Flash programming ... Programming completed in 8.468 s File Processed in 37.375 s Total time for flashing process(boot+erase+write) was 3 min 5.703 s |
03-28-2012, 13:26 | #2 (permalink) |
Member: 1597393 Status: Offline Sonork: 6692766 Thanks Meter: 4 | nokia 1202 flashing problem Using device: HTI, FW ver: 00.50, SN: 0000DB7B Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.13946(25-02-2012) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0029BA77A3BDA66 ASIC type: 11 UEM Imei: 35694803237966 Flash Imei: 35694803237966 RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35694803237966_BA CK.rpl" Processing MCU file: rh112_004.030 [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0029BA77:2984DA60 Area [01000000-0100FFFF] erased in 1.094 s Area [01010000-013AFFFF] erased in 1 min 3.110 s Area [013B0000-013EFFFF] erased in 4.484 s Area [017C0000-017EFFFF] erased in 0.031 s Area [01FC0000-01FEFFFF] erased in 0.031 s Flash programming ... Programming completed in 17.985 s File Processed in 1 min 33.938 s Processing CNT file: rh1120_nai04.03ij [DCT4,DCT4 ALGORITHM] size: 167.29 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: 0140 0600 2000 0040 C000 4000 0002 0510 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0029BA77:2984DA60 Area [01380000-013AFFFF] erased in 3.297 s Flash programming ... Programming completed in 1.297 s Content extract fail, continue anyway ... File Processed in 54.390 s Processing PPM file: rh112_004.03ij [DCT4,DCT4 ALGORITHM] size: 1.08 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: 0140 0600 2000 0040 C000 4000 0002 0510 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0029BA77:2984DA60 Area [01240000-0124FFFF] erased in 1.078 s Area [01250000-0137FFFF] erased in 20.625 s Flash programming ... Programming completed in 8.468 s File Processed in 37.375 s Total time for flashing process(boot+erase+write) was 3 min 5.703 s pls help |
03-28-2012, 15:02 | #6 (permalink) | |
Freak Poster Join Date: Jan 2011
Member: 1488757 Status: Offline Thanks Meter: 98 | Quote:
bor...........try...flash..file...lest..try | |
