01-17-2011, 11:20 | #1 (permalink) |
Freak Poster Join Date: Aug 2010
Member: 1358404 Status: Offline Sonork: N/A Thanks Meter: 47 | nokia 1202 SIMLOCK_DATA corrupted! ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00A74AD7A3BDA66 ASIC type: 11 UEM Imei: 35895601702560 Phone Type: RH-112 SW Version: V 04.03 29-06-09 RH-112 (c) Nokia Imei plain: 35895601702560-3 Product Code: 0562205 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: EL Language Pack: - not available. Imei net: 35895601702560 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! |
01-17-2011, 11:42 | #4 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: Zobi Mobile Lab Age: 35
Member: 352633 Status: Offline Sonork: Sun Set Of The Life Thanks Meter: 33 | Quote:
01-17-2011, 11:43 | #5 (permalink) |
Member: 1358404 Status: Offline Sonork: N/A Thanks Meter: 47 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00A74AD7A3BDA66 ASIC type: 11 UEM Imei: 35895601702560 Phone Type: RH-112 SW Version: V 04.03 29-06-09 RH-112 (c) Nokia Imei plain: 35895601702560-3 Product Code: 0562205 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: EL Language Pack: - not available. Imei net: 35895601702560 Version: SIMLOCK SERVER Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
01-17-2011, 11:44 | #7 (permalink) |
No Life Poster Join Date: Dec 2007 Location: INDIA
Member: 665989 Status: Offline Sonork: 100.1597348 Thanks Meter: 552 | 1.Goto IMEI & SECURITY -> SIMLOCK -> UPDATE SPLOCKINFO (* Direct Unlock) 2.PM-> Load PM -> SUPER SD -> WRITE Your problem will be solved!!! |
01-24-2011, 13:58 | #10 (permalink) |
Member: 1358404 Status: Offline Sonork: N/A Thanks Meter: 47 | 1.Goto IMEI & SECURITY -> SIMLOCK -> UPDATE SPLOCKINFO (* Direct Unlock) 2.PM-> Load PM -> SUPER SD -> WRITE Your problem will be solved!!! |
The Following User Says Thank You to QASIMMOBILE For This Useful Post: |
