04-26-2010, 18:26 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: IN GSM World
Member: 447009 Status: Offline Sonork: 100.1591307 Thanks Meter: 35 | Nokia 1203 UPP not responding ! Please Check Still DCT4 have sum bugs. see logs: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8069(22-04-2010), 1.0.0.12811(22-04-2010) Boot error: 02 FF FF 72 UPP not responding ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. In MT-Box it is Done. See Log: hone is in: Local mode Model: RH-111 (RH-111) V 4.33/19-04-09/RH-111 (c) NMP Production serial number ILR124535 Product code 0574736 Module code 0203772 Basic production code 0574271 Flash code Order number Long production SN MCU SW V 4.33/19-04-09/RH-111/(c) NMP HW 1501 PCI UEM 1328 UPP 8850 LCD adapter_bw PPM V 4.33/19-04-09/RH-111/(c) NMP/MG ADSP SW p&V 4.33\n19-04-09\nRH-111\n(c) NMP\nmg IMEI: 35605403****** User Code was: Failed to reset user code Phone is in: Local mode Full Factory Set...OK Phone is in: Local mode Model: RH-111 (RH-111) V 4.33/19-04-09/RH-111 (c) NMP Production serial number ILR124535 Product code 0574736 Module code 0203772 Basic production code 0574271 Flash code Order number Long production SN MCU SW V 4.33/19-04-09/RH-111/(c) NMP HW 1501 PCI UEM 1328 UPP 8850 LCD adapter_bw PPM V 4.33/19-04-09/RH-111/(c) NMP/MG ADSP SW p&V 4.33\n19-04-09\nRH-111\n(c) NMP\nmg IMEI: 35605403****** User Code was: Successfull, code is 12345 |
04-28-2010, 08:58 | #5 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: karachi
Member: 867259 Status: Offline Sonork: 100.1595961 Thanks Meter: 215 | Quote:
COnnect Jaf with Mxkey and it WOrks Perfect | |
04-28-2010, 12:38 | #7 (permalink) |
Member: 447009 Status: Offline Sonork: 100.1591307 Thanks Meter: 35 | Dear Frnds, First of all I don't have jaf, after seeing all this with jaf not at all. I have UB, MT, MX-Key, UFS-3, Infinity, MultiBox and Smart Clip. Thanks Regards- Libran_s26 |
04-28-2010, 12:50 | #8 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8009(15-04-2010), 1.0.0.12756(15-04-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\35799403697498_BACK.r pl). Processing file: rh112_003.100 as MCU [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00F613C9:2984DA60 Area [01000000-0100FFFF] erased in 1.328 s Area [01010000-013AFFFF] erased in 1 min 15.453 s Area [013B0000-013EFFFF] erased in 5.297 s Area [017C0000-017EFFFF] erased in 0.110 s Area [01FC0000-01FEFFFF] erased in 0.109 s Flash programming ... Programming completed in 18.640 s File Processed in 1 min 48.062 s Processing file: rh1120_nai03.10ie as CNT [DCT4,DCT4 ALGORITHM] size: 164.21 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00F613C9:2984DA60 Area [01380000-013AFFFF] erased in 3.937 s Flash programming ... Programming completed in 1.360 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.032 s File Processed in 19.579 s Processing file: rh112_003.10ie as PPM [DCT4,DCT4 ALGORITHM] size: 1.07 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00F613C9:2984DA60 Area [01240000-0124FFFF] erased in 1.313 s Area [01250000-0137FFFF] erased in 24.672 s Flash programming ... Programming completed in 8.703 s File Processed in 41.968 s Flashing completed in 2 min 50.344 s After Flash Processing ... Phone Type: RH-112 SW Version: V 03.10 21-01-09 RH-112 (c) NMP Imei plain: 35799403697498-1 Product Code: 0571497 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: IE Language Pack: - not available. Imei net: 35799403697498 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 2 min 57.031 s Success........... |
